How to Uninstall V Force Plus Performance Module
Discussion in 'Performance and Tuning' started by flatblack, May 5, 2013.
  1. May 5, 2013 at 10:24 PM
    flatblack
    flatblack [OP] Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    I recently bought a 95.5 Tacoma from a Toyota dealer
    It has a "Jet V-Force Plus Performance Module" Model 67030 that's hooked up to every freaking sensor on the truck
    (Didn't know this till after I bought it)
    http://www.amazon.com/67030-V-Force-Plus-Performance-Module/dp/B001M41516
    I want this thing off of my truck...
    I unplugged it, started the truck, and it instantly stalls out
    So... it's plugged back in
    Anyone know how to uninstall this thing?
  2. May 5, 2013 at 11:23 PM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    It doesn't really do anything (no increased performance, etc), so what's the big rush to get it off your truck? Personally, I'd just leave it alone and use it to monitor the engine and similar - about all it's really good for.
    Anyway, as far as getting it off, you need to download the users guide & optional wiring chart, and then employ those to reverse the steps used to install it. If that's above your skill level, have the dealer you purchased the truck from uninstall it. He might even cut you a deal if you let him keep it to play with.
  3. May 6, 2013 at 12:01 AM
    flatblack
    CDA
    The lcd screen is busted; so, it doesn't really do anything: including monitoring my engine and similiar
    It claims to increase "ingition advance" and such; whether or not it actually does, I'm sure can be argued;
    However, the point is... it's claiming to alter the performance of my truck... and I don't want it to
    Thanks for the links
  4. May 7, 2013 at 5:33 PM
    colby8100
    colby8100 Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    All performance modules is put the engine into cold idle which on most engines means richer fuel and minor timing advance . It can sometimes hurt performance on a torque tune engine (lean tune) which is almost every factory tune
  5. May 8, 2013 at 3:29 AM
    flatblack
    CDA
    yeah, i really don't like that thing being hooked up to my truck
    anyone have any experience uninstalling one of these?
    pretty straight forward?
  6. Aug 17, 2013 at 8:49 PM
    flatblack
    CDA
    alright; so, yesterday the fuse that runs this thing blew and it rendered my truck absolutely useless
    it was as easy as replacing the fuse to get the truck running again
    but, if this performance module ever decides to quit; then my truck is quitting with it
    i took a look at the installation and wiring pdf; and it doesn't say that anything is hooked up to the ECU - so, i would assume that just unplugging the thing wouldn't effect the truck any differently than unplugging a ScanGauge
    unfortunately the truck doesn't agree
    and unfortunately i have no business messing with a vehicles electrical system
    ANYONE KNOW HOW TO KILL THIS THING?!
  7. Aug 17, 2013 at 9:43 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    i'd take it back to the dealer and have them take it out.
  8. Aug 17, 2013 at 9:47 PM
    flatblack
    CDA
    bought it about 6 months ago
    95.5 with 200k on it
    there's no sort of warranty
    they'd probably charge me literally 1-2k to touch anything electrical
  9. Aug 18, 2013 at 4:08 AM
    flatblack
    CDA
    Figured it out
    It is just a matter of reverse installation (don't need to reprogram the Comp or anything like that)
    There was something I missed in the installation instructions; and I'm not exactly 12V electrically inclined
    They have you cut a wire from your MAF
    You then connect one end of that wire to a wire on the Performance Module - and the other end to a different wire on the Performance Module
    So, when you disconnect the Performance Module - you disconnect that wire on the MAF, and your truck gets super upset about it
  10. Aug 18, 2013 at 8:04 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    When you make any wiring changes, don't forget to disconnect the negative battery terminal while doing them so that when you're done and reconnect it, the ECU will relearn the new operating parameters.
    You can tell the ECU has rebooted fresh and is relearning because the truck will begin by operating in a default mode of which the most noticeable symptom is a low pulsing idle as if the timing is retarded. After a few cold start cycles, it will return to normal. I had a 1996 for 17 years. They're really good trucks. :)
  11. Aug 18, 2013 at 11:59 PM
    flatblack
    CDA
    thanks!
