How to turn off my tpms sensor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Savanna19, Jan 23, 2021.
  1. Jan 23, 2021 at 1:13 PM
    Savanna19
    Savanna19 [OP] Member
    Savanna
    2012 Toyota Tacoma Prerunner 2wd
    Hi ! I would like to know how to bypass my tpms sensor on my 2012 Toyota Tacoma Prerunner 2wd. Is there anyone that knows how? Or even if it’s possible.
    Slow Internet likes this.
  2. Jan 23, 2021 at 1:25 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Why?
    It is a safety device. Simple to maintain. Just read the OM for instructions and keep your tires inflated.
    Only bugabo comes during tire changes. Even then the tire shop has the ability to "teach" the truck about the TPMS sensors.
    RedWings44 likes this.
  3. Jan 23, 2021 at 1:29 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    TnShooter likes this.
  4. Jan 23, 2021 at 1:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Jan 23, 2021 at 1:38 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Small piece of electrical tape over the light :thumbsup:
    maritimer8 and MattCowsmasher like this.
  6. Jan 23, 2021 at 1:44 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Why would you want to? TPMS is one of the better ideas to come along in a while. It isn't designed to replace an air gauge, but to warn the driver of a sudden tire deflation while driving. If you've ever ran over unseen road debris at 70 mph and poked a hole in your tire you're going to be grateful for the 10 seconds or so advance warning before your tire comes apart at that speed. Just enough time to slow down and get to the side of the road.
    Sensors last roughly 10 years on average. I've seen some die at 7-8 years and some last 13 or longer. But it will only cost you $80-$100 for a new set. Doing that once every 10 years isn't going to break the bank. That's about the same cost as couple tanks of gas. Or about one value meal from McDonalds per year.
    joeyv141 and Dm93 like this.
  7. Jan 23, 2021 at 4:44 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    If I run over something at 70mph I will know long before my TPMS sensor tells me. I most certainly would not be driving on it long enough for it to come apart. On my 2011 there is no pressure readout just a light. The light comes on at about 26psi. Way lower than I want to keep the pressure at. So it really does not do me any good. What most people want is that when they air down to not have to deal with the light on constantly. I understand there are people that cannot tell when there tire is on the rim but I hope that is not Tacoma owners.
    Key-Rei and maritimer8 like this.
  8. Jan 23, 2021 at 4:51 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    You can also run over a nail in a parking lot at 5 mph but not know about it until after you’re doing 70, or 20 on a hairpin.
    joeyv141, Steve-O and TheCochese like this.
  9. Jan 23, 2021 at 7:25 PM
    sgage
    sgage Well-Known Member
    2007 Red Tacoma SR5
    This. I will say that the TPMS saved my ass at least once, and now that it's just recently started to fail, I find myself wanting to get it fixed. But I'm just trying to nurse it through for a while until I'm ready to get a new set of tires. :)
  10. Jan 24, 2021 at 4:15 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    This is what i did. At least this way you’re not disabling the system. I check my tires once a week. I have a small leak in one of the valve stems it drops about 5psi a week.and I know when I drive the truck i can tell if its down. Don’t get me wrong the tpms system is a good safety measure. But if you’re in tune with your truck you know when something is wrong
  11. Jan 24, 2021 at 6:00 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Build a cheat canister. Have a shop remove the sensors and make a little pressure tank out of some PVC. I used two 3" ABS end caps and just enough 3" tube to glue it all together. Drill a hole in one of the caps to mount the neck of the sensor and fill it to 35psi. Now your sensors think they are in a full tire.
  12. Jan 24, 2021 at 6:14 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Electrical tape over the light on the dashboard is the easiest solution
  13. Jan 24, 2021 at 6:21 AM
    Tacoma Mike
    Southern Maine
    Yeup
    ZColorado[QUOTED] likes this.
  14. Jan 24, 2021 at 6:27 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I deleted my tpms sensors 4 years ago, light is still on. Oh well
  15. Jan 24, 2021 at 6:42 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    The few times I have had a puncture the TPMS wouldn't have helped me, I could feel it before the light came on and one other time was a sudden decompression a light wouldn't have made a damn but of difference.
    The only time I have found it helpful is when it gets cold and I just forget to account for the pressure drop due to temperature.
    I was just thinking this morning given the light has been on for the last year I should just pull the cluster and desolder the LED and replace it with a resistor or something.
    I think I want to go with rubber stems all around anyway since the spare has one already and I rotate pretty frequently.
    Another reason TPMS wouldn't help is 4/5ths of the time I only have 3/4 mounted tires with TPMS.
    But then again, I don't consider myself the average driver, as a prior mechanic and someone a bit obsessive about my vehicles I just pay more attention than most folks do I think.
    So it probably is a good idea for the average bear.
  16. Jan 24, 2021 at 9:01 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Not sure if the newer ones are better but my 08 had sensors in the winter set only.
    Summer change over I’d go about 20 miles before the light would come on. :notsure:
  17. Jul 25, 2023 at 6:26 AM
    longspur
    longspur Well-Known Member
    Tim
    Western Ky.
    2015 extended cab 4x4 4cyl 5 speed
    I know this is an old thread, but just figured out an easy way to solve this with no canister, no wire cutting and took all of 10 minutes. Take gauge cluster out and under the faceplate there is little square compartments. Carefully raise the faceplate up and you will see little compartments, one for each light. Put foam( I used a foam earplug) in the spot where the TPMS light is. Put back together and is very easily reversible. No more TPMS light !
    reallifedog likes this.
