How to torque front wheel spacers without second person to brake?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trogdyr, Jul 23, 2015.
  1. Jul 23, 2015 at 11:51 AM
    Trogdyr
    Trogdyr [OP] Member
    Noob here. "Welcome to the forums, Trogdyr!" I have a 2015 TRD Sport 3" lift with factory 17" wheels and 285/75/17 Toyo ATii's. The bigger tires still rub on the UCA as I approach a full turn. I'm putting on 1.25" Spidertrax spacers to make them not rub.
    I don't want people to weigh in on getting spacers or not getting spacers. I know there are plenty in both camps. Thanks though :)
    First off - I searched and couldn't find anything.
    My question that I haven't quite figured out is this; how does one torque the front wheel spacers without someone there to put the brakes on?
    I've engaged 4WD and that adds a little resistance but I can't think of a way to do it by myself without using another wrench to hold onto and potentially throw off the torque of another spacer nut while torquing.
  2. Jul 23, 2015 at 4:24 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    Four wheel drive and set the parking brake. Or stick a screwdriver into one of the vent holes along the edge of rotor near caliper
  3. Jul 23, 2015 at 4:25 PM
    Trogdyr
    Trogdyr [OP] Member
    Thanks!
  4. Apr 15, 2020 at 12:43 AM
    CaveCreekTacoma
    CaveCreekTacoma New Member
    Chase
    2003 Tacoma 4x4 v6
    Blistein coils, 3 in body lift, tube bumper, and many cosmetic mods.
    Quick question, I’ve searched and couldn’t find a thread with the answer. I have a 2003 xtra cab tacoma and I just bought 2in spacers for all 4 wheels. I just don’t know how much I’m supposed to torque them down. Like what are the torque specs for the spacers and wheels on these trucks?
  5. Apr 15, 2020 at 3:19 AM
    Big2Customs
    Big2Customs Well-Known Member
    2007 Tacoma TRD Sport. Indigo Ink
    Bilstein 5100 front Bilstein 5100 rear
    1) use a breaker bar or pry bar accross the studs to hold and stop the hub from rotating while tightening the lugs nuts on the spacer.
    2) use a jack stand under one of the studs at 3:00 to 4:00 position while it's rotating clockwise, tighten the lugs on the spacer.
    mojojojo78, DG92071 and Larzzzz like this.
  6. Apr 15, 2020 at 4:22 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Good idea. I'd go so far as to throw a lug nut on to torque against that instead of the threads.
  7. Apr 15, 2020 at 5:29 AM
    DG92071
    DG92071 Well-Known Member
    It doesn't damage the threads at all.
  8. Apr 15, 2020 at 5:34 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I'd expect you would torque them the same as the wheels. I believe that's 83 ft lbs.
    b_r_o likes this.
  9. Apr 15, 2020 at 9:57 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yup thats what i would do. Also just put a piece of wood between the brake pedal and the driver seat, and slide the seat forward to hold down the pedal.
    racerX969 and b_r_o like this.
  10. Apr 15, 2020 at 9:59 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    depends, when I bought spidertraxs the little booklet in the box said to torque the spacers to 100
  11. Apr 15, 2020 at 10:00 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yep. That's what I torgue my wheel spacers to. Round up to a nice 85.
  12. Apr 15, 2020 at 10:03 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Maybe they updated their instructions since then, but it says 90.
  13. Apr 15, 2020 at 10:08 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    I use battery impact wrench and torque sticks
  14. Apr 15, 2020 at 12:24 PM
    kfs90
    kfs90 Well-Known Member
    BR, LA
    2013 Prerunner V6
    Yea. 90 with red loctite, then check them again after 50 miles at 80.
  15. Apr 15, 2020 at 1:30 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I think spidertrax recommends the loctite but i stopped using it over the years. It just gumms up the threads and then you have to clean em up to get a smooth torque the next time
    6 properly torqued nuts should have no problem holding the spacer on. I use to check the torque when i rotated the tires but then i even stopped doing that because they were always fine lol
    Island Cruiser likes this.
  16. Apr 15, 2020 at 1:58 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    This is what I did. Has held up for years so far.
