How To: Throttle body cleaning 2005+ V6
Discussion in 'Technical Chat' started by genxer36, May 23, 2010.
  1. May 23, 2010 at 3:30 PM
    genxer36
    genxer36 [OP] Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    This weekend I cleaned my throttle body.
    Items you will need: 10mm socket/wrench, rags, flat-head screwdriver,wire,wire cutters, Throttle body cleaner, MAF cleaner,tooth brush.
    First step: Remove the negative on your battery. I used the 10mm on this.
    Next: Remove the engine cover. There are 2 10mm nuts to remove.
    Next: Disconnect both clips on the air cleaner housing.
    Remove the air filter. If it is a paper one, replace if needed. If it is the K&N filter like mine. Clean it with the cleaning kit as per directions on the kit.
    I use wire to pull the air cleaner housing out of the way. Wrap wire around it & connect it to the base of my antenna. (The black cylinder thing on my antenna is my XM antenna)
    Next: Remove 2 bolts holding the MAF box.10mm socket
    Then loosen the screw -Either 10mm socket or phillips head screwdriver. I used the socket.
    Once the screw is loose, you need to wiggle the housing back & forth, pulling to the left. To remove the housing from the throttle body.
    Once removed. I use wire to pull it out of the way. Wrapped around the plastic neck, not the hose.
    Then I wrap it around the antenna base.
    Everything is out of the way without completely removing.
    Cleaning the MAF: I put a spare rag at the backend of the MAF housing.
    Then I spray the MAF cleaner into the housing onto the MAF sensor. It hangs down & has a circle on the end. Follow the directions on the can.DO NOT touch the sensor with the cleaner straw! DO NOT touch the MAF sensor with anything. Just spray it with MAF cleaner & only MAF cleaner. The MAF wires are very brittle & can break if touched. If you damage the MAF, it will be several hundred for a new one.
    This is the throttle body to be cleaned, inside it.
    On to cleaning the throttle body: I lay a rag on the engine below the throttle body to catch any drippings.
    Use a flat-head screwdriver to open the butterfly.
    Generously spray throttle body cleaner inside, the top & bottom
    Using a toothbrush, scrub inside the throttle body as far as you can reach. Spray & scrub. Also use a rag with your fingers or wrapped around the brush to get the gunk out.
    When finished, reverse the process to put everything back together.
    When you start your truck it may sputter at first, just give it some gas. It is burning off any TB cleaner that may have entered the engine.
    Good luck!
    Sean
    If you want to remove the throtlle body to clean it. I will have pics on the next screen below.
    Dexdawg
    found this for cleaning the MAF on an FJ, it looks identical to the Tacoma. Good find!
    http://www.youtube.com/watch?v=qiEdey2IHcc
  2. May 23, 2010 at 3:34 PM
    teambcw
    teambcw Well-Known Member
    So Cal
    Great write up....... I am loving the red arrow!!!
    Scrat, devale, Andocalrisian and 14 others like this.
  3. May 23, 2010 at 3:38 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Nice job, especially the arrow. I've seen a few write-ups where a specific bolt or clip gets described and I'm looking at it wondering "Where in the hell..."
    :D
    Scrat, devale, oretaco and 3 others like this.
  4. May 23, 2010 at 3:40 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    Nice red arrows lol. COuldn't you have just unscrewed the sensor?
  5. May 23, 2010 at 3:43 PM
    newtaco2008
    newtaco2008 Well-Known Member
    Fort Mill, SC
    08 prerunner indigo ink pearl
    nice write up... how often should we clean these two things?
  6. May 23, 2010 at 3:47 PM
    SlurpeeBlueMetallic
    I much prefer to leave the sensor attached... IMO, less chance to screw it up or let it whack into something else.
    Scrat likes this.
  7. May 23, 2010 at 3:47 PM
    genxer36
    Sean
    Bethlehem,GA
    Removing the throttle body: Remove 4 bolts
    Then you have easy access to get to the backside of the throttle body. I didn't do this the 1st time I cleaned the throttle body.
    Clean all around the butterfly with the TB cleaner & tooth brush, wipe with a rag.
    Also spray TB cleaner in the black piece that the TB connects too. Wipe out with a rag. Mine didn't have much gunk in it. Most of the gunk was around the throttle body itself.
    According to Chris4x4 the Throttle body bolts should be torqued to 9 ft-lbs.
    llibrm, Jmack69, Scrat and 22 others like this.
  8. May 23, 2010 at 3:50 PM
    genxer36
    Sean
    Bethlehem,GA
    Box lid cut out. LOL
    LG888 and R09ster like this.
  9. May 23, 2010 at 3:50 PM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    nice write up, this should be stickied!
  10. May 23, 2010 at 3:52 PM
    genxer36
    Sean
    Bethlehem,GA
    I am not a fan of removing the MAF. Since it can easily get broken. Best to leave it in place & spray the cleaner on it several times. Plus having it tilted, the liquid can drip off with the dirt onto the rag on the backside.
    AlCapwn, 4x4cajun and TRDSport10 like this.
  11. May 23, 2010 at 4:26 PM
    genxer36
    Sean
    Bethlehem,GA
    Thanks everyone. Glad to help.
  12. Jun 17, 2010 at 1:58 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Nice write up! Can we make it mandatory for all write-ups to have red arrows. :D
  13. Jun 18, 2010 at 5:36 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Thanks for taking the time to do this write up...very informative!:)
  14. Jun 18, 2010 at 6:07 PM
    genxer36
    Sean
    Bethlehem,GA
    You are welcome. It needed to be written up.
    I agree, it is always difficult for me to understand when someone does a write up without showing the exact location of something.
    I suck @ photoshop, so a box lid was easier.
    TRDSport10 likes this.
  15. Jun 18, 2010 at 6:31 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Gotta love how you made it Krazie proof. That is much appreciated.
    Repped!
  16. Jun 18, 2010 at 7:08 PM
    genxer36
    Sean
    Bethlehem,GA
    Thanks
  17. Aug 11, 2010 at 5:21 PM
    MXscott14
    MXscott14 Bartle Do Member
    Keith Stone
    In Front Of You
    2006 2nd generation antique
    Black Headlight, Foglight always on,
    what does this improve sorry im just wondering
  18. Aug 11, 2010 at 5:25 PM
    Duff Man
    Duff Man Well-Known Member
    Sean
    North Carolina
    09 TRD Off Road
    AEM CAI, Magnaflow exhaust, DT headers, all speakers replaced with (2) 10's and amp behind rear seats, color matched grill, grillcraft, projector headlights, 8000k HID's, DC Torque wheels, 3" Toytec lift, Bilstein 5100 shocks.
    probably cleans up oil from the filter that is built up on the MAF sensor and in the throttle body. I've heard oil from the filter can really mess up your MAF sensor if you don't take care of it. Idk about if it makes your engine run any better though, haven't done it myself yet.
  19. Aug 11, 2010 at 9:47 PM
    genxer36
    Sean
    Bethlehem,GA
    While throttle-body cleaning is good preventative maintenance, it should also help engine drivability. In fact, if you've noticed a rough idle, stumbling initial acceleration or even stalling - all when the engine is fully warmed up - a dirty throttle body could be the culprit. Once you look inside a throttle body, you will probably be surprised at the dirt, gum and varnish that have accumulated there over time.
    In severe cases, the throttle plate may start to open and close with difficulty and even get stuck. The first time I cleaned mine. I noticed the throttle plate was difficult to open.
  20. Aug 11, 2010 at 9:49 PM
    genxer36
    Sean
    Bethlehem,GA
    It makes a huge difference on how your engine runs. The first time I cleaned mine @ 80,000 miles. It was like driving a new truck. Performance improved greatly. Before the truck was sluggish on take off.
