How to test a Relay Fuse for Front Fog Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BES2010, Nov 30, 2017.
  1. Nov 30, 2017 at 11:48 AM
    BES2010
    BES2010 [OP] Member
    2016 Tacoma SR5
    Ok folks. I need to test my Relay that controls my front fog lights for my 2016 Tacoma SR5. Let's assume I removed it from the fuse box. Spare no details as far as how to go about doing that. I've got an older Digital Multimeter GE2524 to use. Thanks!!
    I'm a visual guy so pictures would work or diagrams if available.
  2. Nov 30, 2017 at 11:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Look around in the box. Odds are you'll find another relay just like it.
    Swap them. Do the lights now work? Does the other circuit not work?
    TireFire and dilbert like this.
  3. Nov 30, 2017 at 11:58 AM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Swap in a matching known good relay from a different location in the panel.
  4. Nov 30, 2017 at 12:22 PM
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
    For a visual...youtube "how to test a relay"
    Swapping way faster.
  5. Dec 1, 2017 at 9:26 AM
    BES2010
    BES2010 [OP] Member
    2016 Tacoma SR5
    Ok I swapped out the Front Fog Relay Fuse with the Horn Relay fuse. The Horn works but the FF Lights still don't
  6. Dec 1, 2017 at 9:31 AM
    dilbert
    dilbert AI Member
    PNW
    Sounds like the relay is good. Did you check the fuse? Is the truck still under warranty?
  7. Dec 1, 2017 at 9:36 AM
    dilbert
    dilbert AI Member
    PNW
  8. Dec 1, 2017 at 10:18 AM
    nwAdamR
    nwAdamR Well-Known Member
    Adam
    SW PDX
    2016 Tacoma TRD OR LB AT MGM
    You checked the relay before checking the fuse?
  9. Dec 1, 2017 at 10:26 AM
    BES2010
    BES2010 [OP] Member
    2016 Tacoma SR5
    I did check the fuse too and put in replacement fuse. Same result: no fog lights. Sorry for confusion
  10. Dec 1, 2017 at 10:40 AM
    BES2010
    BES2010 [OP] Member
    2016 Tacoma SR5
    I'd like to learn how to test my Relay Fuse with my multimeter.
  11. Dec 1, 2017 at 12:58 PM
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    Easiest way to do that is to take the load and supply wires off the relay. Turn switch on. Test continuity between load and supply. If meter peaks it is closed/on. Kill the switch. If meter falls to 0 it is open/off.
    Now you know.
  12. Dec 1, 2017 at 2:39 PM
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    I'm gunna stretch a guess and say you have an add-a-fuse under the dash. Another member here and myself had done this trying to hook up a switch-pro. I blew only the fog fuse. It looks like he may have fried the wiring coming out the fuse box.
  13. Dec 1, 2017 at 4:43 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
