How-To: Steering Rack Bushing Replacement on a 1st Gen Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by turbodb, May 24, 2021.
  1. May 24, 2021 at 9:09 AM
    turbodb
    turbodb [OP] AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Step-by-Step Steering Rack Bushing Replacement on a 1st Gen Tacoma (or 3rd Gen 4Runner)
    Over time, rubber bushings wear out and need to be replaced. This happened for me recently when I Replaced All the Bushings on my Tacoma, and I figured that others could benefit from a quick little guide that shows the entire process and lists all the necessary parts for replacing the bushings in the steering rack.
    Parts
    One thing to be aware of when replacing the steering rack bushings is that 1st gen Tacomas have two different bushing configurations depending on the model year - with the change happening around the 2000 model. Earlier trucks - it seems - use a smaller diameter bolt at the center location to secure the actual rack (which is the same across all years) to the frame, while later years use a larger diameter bolt. Luckily, the good folks at Energy Suspension have included sleeves for both in this kit, as long as you purchase the kit for the '95-00 model years, regardless of the actual year of your 1st gen Tacoma.
    Note: Energy Suspension also has a separate kit for the '01-04 model years (8.10103 black | red). This kit is identical to the '95-00 kit but contains only the sleeve for the larger diameter bolt. Personally, I think it's a better idea to buy the '95-00 kit regardless, to give yourself the flexibility.
    Tools
    The tools for this job are relatively simple.
    Doing the Job
    With the parts and tools in hand, it's time to get started. For the step-by-step process (with pics), keep going at:
    Step-by-Step Steering Rack Bushing Replacement on a 1st Gen Tacoma (or 3rd Gen 4Runner) – ADVENTURETACO
    Taco1997, JudoJohn and Black DOG Lila like this.
  2. May 24, 2021 at 9:19 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  3. May 24, 2021 at 12:12 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    My '96 used the larger sleeve. I looked at the smaller sleeve and the bolt wouldn't go through. I compared the sleeve size with the original bushing and it was the larger of the two.
    turbodb[QUOTED][OP] likes this.
  4. Nov 10, 2023 at 5:27 PM
    Sam_Kupiec
    Sam_Kupiec Member
    Sam
    2000 Tacoma SR5 V6 TRD
    Ran into a MAJOR problem upon starting this job today. Originally, I ordered the Energy Suspension 8.10103G kit thinking that would work for my 2000 Tacoma. Upon reading this how-to, I decide to go ahead and order the 8.10101G kit (in the event my truck has the smaller bolt diameter).
    Wonderful Amazon decided to send me a second 8.10103G kit, but I did read quite a few people do the job without a problem on the same year of truck. Long story short, I have all of the bushing pressed out, but now I’m in a bind because I found out that I have the smaller bolt, but not the correct sized bushing.
    Has anyone else run into this same issue and found a workaround without waiting days for Energy Suspension to come through with the right sized bushing? I really appreciate anyone’s input to help get my truck back together this weekend (I’m working on having an option so it’s not my daily driver, but alas, that hasn’t happened just yet).
  5. Nov 10, 2023 at 5:47 PM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    Does your rack have 2 bushing locations or 3? Mine has only 2 and I'm having trouble myself.
  6. Nov 10, 2023 at 6:06 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I have the rwd with the two mounts....
    to make the vertical one I had to burn the center sleeve out of the original and reunse...
    and then had to shave down the thickness of the two halfs to make the driver side fit...
    Same on the 'D' bushing....had to take about half an inch out of its circumference so to cinch down without buckling.
  7. Nov 10, 2023 at 10:06 PM
    Sam_Kupiec
    Sam_Kupiec Member
    Sam
    I have a 4wd that has the horizontal driver’s side mount, the vertical mount (the one I’m having trouble with the bushing for), and the retainer on the passenger’s side held on by the bolt and nut.
    I ended up going to O’Reillys tonight and found a Dorman kit (PN 905-401) that is a polyurethane kit with two different ID’ed sleeves for the vertical mount. Turns out, the bolt in my rack doesn’t fit either (too loose on the thin walled sleeve, and doesn’t fit through the smaller ID). I’m putting all of the pieces together here in my head, and believe that Big O’ Tires is to blame here as they replaced the entire rack a couple of years ago. This was before I really started wrenching on my truck, and they threw a new aftermarket rack on there (after the reman they put on blew a hole in it not even a day after that had replaced it). My theory is that they replaced all of the factory hardware upon installation of the aftermarket rack, which would explain why even the Dorman kit (with the two variations of sleeve bushing inserts) doesn’t fit the bolt I have.
    Definitely unfortunate as it delayed me a day in the reassembly, and even with extensive research heading into the project I wasn’t able to predict this being the outcome. I think my solution for tomorrow will be to head to a parts store in the morning to get the correct lengthened 1/2” bolt I need and a nut for that center mount. All I need is one that will fit the sleeve that Energy Suspension sent me, and I should be good to torque everything back down and wrap this project up!
    To that end, would anyone have any recommendations for places they like to get Grade 8 or Class 10.9 hardware for your trucks? The bolt that came off is half threaded and is smooth shanked the rest of the way. If my theory holds that Big O’ just replaced they hardware on me, than I suppose I really don’t have to find anything that matches, just need to find something that will fit and do the job!
    turbodb[OP] likes this.
  8. Nov 10, 2023 at 10:12 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    https://www.tacomascrew.com/ generally has everything, but not sure where you're located; they are PNW only as far as I know. Could always install something to "get by" and then order online from them, I guess.
    JustADriver likes this.
  9. Nov 10, 2023 at 10:16 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Belmetric for US wide
  10. Jan 5, 2024 at 4:28 PM
    Lord Kanti
    Lord Kanti BlackJack Taco
    SoCal
    2002 Double Cab 4x4 SR5 TRD Blackout
    Deck plate gray wire Blackout De-badge Lift Tires
    Do you know what the difference is between BRK74350 and 905-401? I think 905-401 is urethane vs rubber, but I have read mixed reviews.
  11. Jan 5, 2024 at 6:47 PM
    Sam_Kupiec
    Sam_Kupiec Member
    Sam
    I think what you said is the difference. I went with the polyurethane kit over rubber for the durability factor. So far so good on the new bushings!
    Lord Kanti[QUOTED] and Wulf like this.
  12. Jan 6, 2024 at 3:38 PM
    YOTA HUNTERS
    YOTA HUNTERS Well-Known Member
    Cranston, Rhode Island
    Nice!!! Next job I have to do on my tacoma
