How to splice
Discussion in '1st Gen. Tacomas (1995-2004)' started by Neviane, May 1, 2018.
  1. May 1, 2018 at 1:21 PM
    Neviane
    Neviane [OP] Member
    2001 Toyota Tacoma
    How do I splice the bumper mounted turn signal connector to the wires? What color/gauge and what wires go to which wires. 2001 Toyota Tacoma
  2. May 1, 2018 at 1:30 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Show the rest of the aftermarket turn signal, Black should be ground but I don't know why there's two positive leads unless it's a switchback for running lights.
  3. May 1, 2018 at 1:59 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    White-black is ground
    Green-yellow is 12v+
    You will have to figure out the wire colors on the aftermarket light
  4. May 1, 2018 at 2:19 PM
    spinyard
    spinyard Well-Known Member
    Black is ground, yellow it signal, & brown is running lights. Is the other side of the aftermarket light Black, green, brown?
  5. May 1, 2018 at 3:01 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I mean you can just tie the grounds together then just touch the other wires to the positive lead on the truck to see what one lights up the bulb....
    Then soder and heat shrink them together, maybe wrap some electrical tap around them afte is to just to make sure you keep the connection clean
  6. May 1, 2018 at 3:03 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Red is hot
    Black is not
  7. May 1, 2018 at 3:21 PM
    Indy
    Indy Master of all I survey.
    Black to ground, yellow to left brown to running and green to right. 14ga wires, solder and heat shrink should give a splash proof connection. Crimp connectors will work, but tape the gaps. They make a crimp connector that doubles as heat shrink as well.
  8. May 1, 2018 at 3:28 PM
    Indy
    A $5 dmm will tell you the rest.
  9. May 4, 2018 at 6:18 PM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
  10. Aug 29, 2018 at 4:16 PM
    FWAdam
    FWAdam Well-Known Member
    Indiana
    2001 Regular Cab Prerunner
    DIY Frame replacement New rear leaf springs (General Spring, stock height) Wheeler's greasable shackles Bilstein 5100 / 5125 Roll-on bedliner Poly bushings all around Leer topper Michelin Defender LTX M/S tires New drum brakes, rotors and pads, and Nickel-Copper brake lines Window tint Wheels painted black Interstate battery New spark plugs Chrome bumpers painted Bucket seats and console (soon) Emblems plasti-dipped (soon) 4x4 conversion (2017)
    Hey! I had the same issue as the OP. I ordered the replacement socket that had the 3 wires (same as OP) and some posi-twists to connect the socket wiring to the harness wiring. I have the black wire on the socket running to the white wire from the harness, and the yellow wire from the socket running to the green wire from the harness (only 2 plugs come from the harness). It worked when I first tried the signal, but the signal was still going super-fast as if a light was out (I checked, and none were).
    For good measure, I tried connecting the brown to the green, and no dice. So I went back to the green-yellow connection, and now it won't signal at all, rapidly or otherwise. And ideas for a newcomer like me on what I may need to examine more closely? All bulbs everywhere are good. Thanks.
    UPDATE: connecting both the black AND the brown wires from the pigtail to the white wire from the harness seems to have fixed it.
  11. Aug 2, 2023 at 2:41 PM
    TacoTuesday1
    FL
    what tools are you all using to shrink crimps
  12. Aug 2, 2023 at 4:48 PM
    TomYotaNH
    TomYotaNH Well-Known Member
    Tom
    Seacoast NH
    '16 Barcelona Red DoubleCab Limited
    Almost Stock - BedRug, Power Tailgate Lock, ….
  13. Aug 2, 2023 at 5:12 PM
    TacoTuesday1
    FL
    that’s what I have. Blasts the area melting everything else like my hand and switch the crimp is next to and requires an outlet not always accessible. Can’t be run off the bed.
  14. Aug 2, 2023 at 8:15 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Blast from the past!
    All connections I solder and heat shrink to those larger then 8AWG for the most those get crimped on lugs.
    Taco critter likes this.
  15. Aug 2, 2023 at 8:23 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
  16. Aug 2, 2023 at 11:27 PM
    TacoTuesday1
    FL
    thanks
    Always leaned towards Milwaukee working on cars having lots of their tools and already having batteries + charger
    probably gonna get a small butane pen style precision heater/torch
    As they have a curved shrink tube tip, are small for precision, mobile and refillable
    Tiny tool, and much cheaper
    Buddy also working on cars swears by his
  17. Aug 3, 2023 at 7:54 AM
    Puppypunter
    Johnny
    2019 Black SR
    The butane ones are nice for the smaller stuff. But since you’re team red: https://www.homedepot.com/p/Milwauk...VQgh9Ch3-YA2aEAAYASAAEgLOL_D_BwE&gclsrc=aw.ds
  18. Aug 3, 2023 at 1:48 PM
    TacoTuesday1
    FL
    thanks
    I’ve had a heat gun
    Cordless only changes power cord
    Gonna try a butane one. Not only cheaper
    But assuming it has the same 600deg required
    Small case. Fits anywhere even doing underneath dash work. Without excessive heat flying everywhere on surrounding parts like a switch, my hand, etc
  19. Aug 3, 2023 at 8:14 PM
    Bivouac
    I tried one of those butane small torches might have been the brand.
    Might have been 10 years ago or longer,
    I can hope they have improved the one I had was junk used it a few times it is around some place.
