How to reset ECU by removing fuse?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jamjar99, Jun 2, 2017.
  1. Jun 2, 2017 at 9:35 AM
    jamjar99
    jamjar99 [OP] Member
    I cleaned my MAF last night to get rid of a pesky engine code. I've read that I should be able to just unplug the ECU fuse under the steering wheel for 5 minutes, plug in back in, run the truck for another 5 minutes and it should reset the ECU.
    I've tried this but the check engine light was still on. What am I doing wrong? Should I unplug the fuse with the ignition turned to the on position?
    I ended up clearing the code with a scanner and the light has not come back on but would still like to know...
  2. Jun 2, 2017 at 9:37 AM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    On my other cars I just discounted the negative battery thermal for 5-10 minutes. These days you can but a scan tool for under $25, nice to have.
  3. Jun 2, 2017 at 9:39 AM
    willie64
    willie64 Willie64
    willie64
    BEND OR
    (slowly becoming less than) Stock '03 3.4L 4x4 TRD SR5
    144 watt led lights on front 36 watts x2 led on the back, cb, Kenwood ham, icon 3" lift, 285/75/16 Fierce Attitude tires, JoeZilla sliders, 4x innovation rear bumper, ARB front bumper. Snorkel. On the workbench: more stuff I can't afford.
    An easy way to 'reset' is to take the positive lead off the battery for about 5-10 minutes. It may NOT reset a code tho.
  4. Jun 2, 2017 at 10:21 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Disconnecting the battery worked on OBDI - the pre-95 cars where the code could be read by counting blinks of the bulb connected to the port. Post-95 cars (including all Tacomas) have OBDII where the scan tool (or adapter for PC or tablet/phone) is required to read and reset the code.
    wayfaringman13 likes this.
  5. Jun 2, 2017 at 1:32 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    The fuse you're looking for is the EFI fuse. You can pull that one for 30 seconds and it should reset any DTCs. What was the DTC you had or have?
    Wyoming09 and boostedka like this.
  6. Jun 2, 2017 at 8:17 PM
    toyota700
    toyota700 Well-Known Member
    Dan
    cos, co
    01 3RZ Reg
    Autozone loans scanners for free...
    Or yes they're cheap and everyone should have one.
  7. Jun 2, 2017 at 8:20 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I'm with the others here on disconnecting the battery.
    If it's a smog code it'll reset them.
    If it's a diagnostic code... you don't want to drive with it lit up. (Typically)
  8. Jun 5, 2017 at 9:34 AM
    jamjar99
    Thanks everyone, I ended up disconnecting the battery in the end . I tried taking out the fuse marked "ECU-IG" overnight and it had no effect. Maybe I should have taken out the one marked "ECU-B" as well....
  9. Jun 5, 2017 at 11:52 AM
    cruiserguy
    Elijah
    SEKS
    EFI fuse under the hood. But whatev. I already mentioned it previously in your thread. Maybe you missed it.
    Wyoming09 likes this.
  10. Jun 5, 2017 at 12:10 PM
    jamjar99
    oh dear whoops. Yes you mentioned it but being such a dimwit I didn't realise it was the fusebox under the hood :thumbsup:
  11. Jun 5, 2017 at 12:28 PM
    cruiserguy
    Elijah
    SEKS
    Lol, no worries. I see I didn't mention it was under the hood. It's what I use when I need to reset it and don't have my scanner on hand. Obviously the battery disconnect works also.
  12. Jun 5, 2017 at 1:41 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Pulling the EFI fuse won't clear the radio presets and clock like disconnecting the battery. If you have a fancy new radio with a bunch of settings it can be a pain to set back up.
    Dropoutjohn and Hamer95USA like this.
  13. Jun 5, 2017 at 2:43 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    this^
    I have to reset my radio EQ every time the battery is disconnected (rarely) but I can never get it to sound the same
  14. Dec 31, 2019 at 8:51 AM
    Biged_72455
    Biged_72455 Active Member
    99 Tacoma sr5 2wd 2.4
    I got a Pioneer for my Silverado and it actually has the option to save the settings. Saves having to set it all back up again even after an extended time without power. Great little “all digital media” radio. No cd, has usb, Bluetooth, Bluetooth audio, phone connect with external microphone. Works great. Every once in a while, it gets a big up it’s ass and needs to be completely unplugged from the back for a couple minutes. Plug it back in, works fine.
  15. May 24, 2020 at 11:27 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Tried this (pulled EFI-MAIN 20A & EFI 10A) with everything off but battery connected, no luck resetting what I believe to be a O2 sensor code I got after borrowing the A/F HTR fuse for troubleshooting another system. (Check Engine & TRAC OFF lights illuminated) Should I also use the "ST" fuse to short somewhere to clear any memory or something? Or does this procedure require per being on to the ECU via key in second position?
    I should add that this is a 2nd gen (2015) but didn't want to start a thread when this one is very relevant.
    Thanks for any help.
  16. May 27, 2020 at 4:28 PM
    cruiserguy
    Elijah
    SEKS
    Sorry it took so long to get back to ya man. I would have thought that fuse would reset the DTCs even in the newer Tacomas. Either way, there is enough difference between the first and second gen tacos that having a thread for it in the 2nd gen section wouldn't be a bad idea.
    Hopefully you've got this squared away or at least have a plan of attack to address it. If not, don't hesitate to chime back in and I wouldn't mind trying to hunt some info down for the second gen scenario.
  17. May 27, 2020 at 5:48 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    No prob. I did do a brief search of the 2nd gen forum only but got no good results. I just ended up pulling the battery cable. I wanted to reroute it anyway, so it was a good reason to do both. Turns out on the 2015 with the fancy stereo/info system that it must have some solid state memory or a backup battery because it did not clear the radio station presets or any of the settings/bluetooth setup data. So win/win for me. Thanks for the reply, though.
    cruiserguy[QUOTED] likes this.
