How to reset and calibrate your VSC computer - The Easy way
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Dec 30, 2016.
  1. Oct 24, 2018 at 1:25 PM
    #161
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Welcome!
  2. Oct 27, 2018 at 6:02 PM
    #162
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I had the same issue. Installed a lift last year and my alignment sleeves were seized. After prematurely wearing my new tires, I replaced alignment sleeves and front LCA bushings yesterday. I had the alignment all jacked up. On the way to the shop this morning, my steering wheel was crooked and the truck drove like crap.
    After the alignment, my VSC light was on.
    Just did the reset and the light went out!
    Great write up. Will confirm driving tomorrow but I'm confident it will be good!
  3. Dec 7, 2018 at 5:27 PM
    #163
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    I've done this countless times, even had shops and dealerships reset mine but the truck still acts erratically in corners to the point where I just pull the fuse out.
    Had this issue with icons, Kings, spring over, spring under, cranked up or not. Haha I'm almost positive I'm never getting rid of it. Though I did notice I never had the issues with a different set of tires. I find it hard to believe going from one brand of tire to another had anything to do with it. I was going to start toying with the yaw sesnor position to trick the truck at how it sits like the tundra guys do.
  4. Dec 10, 2018 at 10:57 AM
    #164
    Bic
    Bic Member
    Alaska
    2015 Bronze DCLB 4x4
    A lot of modifications...
    Great write up. I'm embarrassed to say how long I drove around with those two lights on. Fixed with a paper clip within one minute.
  5. Dec 10, 2018 at 6:38 PM
    #165
    Bic
    Bic Member
    Alaska
    Well, I got all the way to the end of the driveway before the lights came back on...
  6. Dec 27, 2018 at 3:41 PM
    #166
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    I recently reset my VSC using this mod about a month or so ago but now my VSC and ABS light won’t reset with the wire mod. The VSC and ABS lights don’t flash simultaneously (they flash intermittently) and I can’t recalibrate the VSC successfully...the ABS and VSC lights flash quickly only for 1 second and won’t shut off when I do the second part of the mod. What do you guys think? I tried to recalibrate about 5 times with the same results - VSC and ABS lights still illuminated on dash. Maybe wheel sensor is loose?! I didn’t check that yet.
  7. Dec 27, 2018 at 4:47 PM
    #167
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Never mind. I just checked and I have a severed wheel sensor cable. Going to try and fix it.
  8. Jan 8, 2019 at 8:48 PM
    #168
    TicTAComy
    TicTAComy Active Member
    98 tac
    Hello, This might be a dumb question but can you reset the VSC by using the delete code function on the OBD scanner and will it reset automatically? I am getting the code Zero Point C1210 calibration of yaw rate sensor undone. I am using Bluedriver and it is awesome. Covers the whole system. Traction control light came on after tire rotation and alignment
  9. Jan 19, 2019 at 12:01 PM
    #169
    JAYPHX
    JAYPHX Well-Known Member
    Jesse
    2019 White TRDOR
    I was also wondering if this reset works on a 2019? I’m having this issue after installing icon stage 4. I checked all cables and wires. Everything looks good. I tried the reset but couldn’t get the lights to blink as in the description. Called around and no one can read codes for a 2019?? A few places I even said 2018 to no avail. Took it to the dealership and they said since vehicle is “modified” recalibrating the VSC isn’t under warranty and would cost $165. I wasn’t going to sit there and argue with incompetence so I drove away. I’m hoping an alignment shop can take care of this once I go in. Unless anyone has any other ideas?
  10. Jan 19, 2019 at 12:25 PM
    #170
    TicTAComy
    98 tac
    https://www.amazon.com/gp/product/B00652G4TS/ref=ox_sc_saved_title_2?smid=AD7D9D1JAFECP&psc=
    I have a 2014. The link is for the excellent code reader that I bought. You download the excellent app to your cell and then you can reset the light from the app. I would follow the info given by the forum and use the scanner app to reset. Maybe you can call the Bluedriver customer service to ask if their scanner reads the 2019 codes. Must be nice to have a 2019!!!
  11. Jan 19, 2019 at 7:22 PM
    #171
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Here’s a little tip -
    If you have anything plugged into your OBD port (like a Scan Gauge or Ultra Gauge) and disconnect and reconnect the battery, it may set the VCS light off.
    I did this the other day when I was doing upper control arms.
    Removed the battery to get the UCA bolt out, reinstalled everything and the VSC light came on. Thought I stretched a wire or something stupid causing to come on. After resetting the VSC a half dozen times and it still coming back, I realized my Scan Gauge wasn’t displaying anything.
    Unplugged it. Plugged it back in. It worked. The VSC light went off and has stayed off.
    Something in the OBD plug shorts when you leave the gauge plugged in and disconnect and reconnect the battery.
    Should of realized / remembered this because this wasn’t the first time I had this happen.
  12. Jan 20, 2019 at 9:19 AM
    #172
    JAYPHX
    Jesse
    2019 White TRDOR
    Thanks for the response. I’ll try some of these today. If all else fails, back to the dealership. Or maybe just try replacing the ABS lines to the rear wheels. It seems the issue took place when we dropped the rear axle to add the icon leaf. Does anyone know if dropping the axle actually Triggers some type of VSC sensor?
  13. Jan 27, 2019 at 4:23 PM
    #173
    LowFourJoe
    LowFourJoe Well-Known Member
    Joe
    SoCal - Yorba Linda
    2015 DCSB Silver Tacoma TRD Sport
    5100 Billies & OME 886s 2" lift, 1.25 Spidertrax spacers on all 4, 265/70R17 Falken Wildpeak AT3/W
    Hey Nick, just wanted to pop in and say thank you. I had to do this today after an alignment and rotation.
    The only deviation from the instructions was the location of the The sensor connector. The connector thingy on my 2015 is actually located just above the e-brake, under/behind the dash. I used a paper clip to short it out and your instructions worked flawlessly.
    These forums are an incredible resource because of contributors like you. Thanks again!!!
    Joe
    Drainbung likes this.
  14. Jan 27, 2019 at 4:24 PM
    #174
    Phoosa
    Phoosa I never saw nothing.
    Truck
    Did mine couple days ago. Excellent write-up.
  15. Jan 30, 2019 at 3:02 PM
    #175
    Thesandaddict
    Thesandaddict The dude
    Harley
    West Covina, CA
    2010 tundra bro-dozer
    Quick question. Did this. ABS light flashed, not VSC. Tried it a dozen times and could never get the VSC light to blink. Any input?
  16. Jan 30, 2019 at 3:33 PM
    #176
    JAYPHX
    Jesse
    2019 White TRDOR
    I tried this several times on my 2019 and couldn’t get it to work. But then again I had a short in my rear left ABS line so that could have been the issue.
  17. Jan 30, 2019 at 3:48 PM
    #177
    Thesandaddict
    Harley
    West Covina, CA
    Yea I'm just worried during my lift install that I messed something up and that's why its not resetting
  18. Jan 30, 2019 at 4:29 PM
    #178
    JAYPHX
    Jesse
    2019 White TRDOR
    That’s exactly what happened to me when I installed my icon stage 4. Ended up just barely pinching the rear left ABS line. $250 cable unfortunately for me. If you have a 2015 you’re probably in luck for a cheaper aftermarket as there are no after market for mine yet. Lol dealership wanted 300 bucks to install the cable harness. Took me 30 minutes on my own.
    Travlr likes this.
  19. Jan 30, 2019 at 4:35 PM
    #179
    Thesandaddict
    Harley
    West Covina, CA
    How did you know it was the abs cable? My abs light isnt on, it's the VSC/ traction control light. And I cant disable the TRAC or anything until the light goes off. So no offroading until this stupid thing is resolved
  20. Jan 30, 2019 at 4:54 PM
    #180
    JAYPHX
    Jesse
    2019 White TRDOR
    Mine had the ABS/VSC/traction control lights on. I pretty much knew it was the ABS cable because I remembered potentially putting a bit too much pressure on the cable when I was installing the add a leaf. I took it to a shop that was able to run diagnostic and it did say it was left rear abs cable. Autozone etc wasn’t able to diagnose mine because they don’t have 2018/2019 diagnostic info on their computers. Dealership should be able to diagnose but unsure if they’ll charge. They were my last resort even though I’m under warranty. They like to blame everything on “modifications”.
    Thesandaddict[QUOTED] likes this.
