How to reset and calibrate your VSC computer - The Easy way
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Dec 30, 2016.
  1. Dec 30, 2016 at 9:21 PM
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    How to reset and calibrate your VSC (Vehicle Stability Control) computer
    Quick and easy, straight forward, no technical BS.
    This procedure is recommended by Toyota, after front end alignment adjustments are made.
    Make sure your truck has VSC before you begin.
    VSC was optional in 2005-2008 model trucks, and became a standard safety feature in 2009 and later.
    • Find a flat place to park your truck, make sure your steering wheel is straight, and then turn it off.
    • On the left side of your dash is a coin tray, beneath that is a diagnostic connector, remove the plastic cover to reveal the port.
    • Find a skinny piece of wire 2 inches in length it does not matter what kind of wire it is.
    • Bend the wire into a u-shape, you will be using the wire to short out two pins on the connector, illustrated in green.
    • The first step process is to wipe the mind the VSC computer.
    • The second step is to calibrate the computer
    • Done.
    READY??? GOOD.
    1. Turn the ignition to the on position, and then short out the pins, 4 times or more within an eight second period. If you're successful the ABS light, and the slip indicator light will flash simultaneously at a steady interval. Congratulations you just wiped the mind of the VSC computer!
    2. Turn ignition off.
    3. Very important requirement for manual transmissions... The Parking Brake must be engaged. Next, short out the pins with your wire, leave the wire in there, turn ignition to on position. Be careful not to disturb the truck, must remain very still for two seconds during calibration. Observe the ABS light and the slip indicator light they will be flashing simultaneously at a steady rapid interval, faster than before. Congratulations you've just calibrated the VSC computer.
    4. Turn ignition off, remove wire, and go drive and have fun.
    Edit: added note about manual transmission from member @abbazaba14 on 11/17/2021
    HWI, hogges, TRDSport10 and 120 others like this.
  2. Dec 30, 2016 at 9:24 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Nice job as usual
  3. Dec 30, 2016 at 9:33 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Thanks OZ. I used our old thread from 2010 on the subject. I finally had a need to do it after all these years.
  4. Dec 30, 2016 at 9:34 PM
    OZ-T
    Peter North
    British Columbia
    This one is right to the point
    Should get locked & stickied
    HondaGM, TXpro4X4, Biscuits and 3 others like this.
  5. Dec 30, 2016 at 11:35 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    That is really well done Crom. Completely agree that it should be stickied.
    Crom[OP] likes this.
  6. Dec 31, 2016 at 12:26 AM
    OZ-T
    Peter North
    British Columbia
    @tcBob
    Can you sticky this thread
  7. Dec 31, 2016 at 2:40 AM
    AZ2013
    AZ2013 Well-Known Member
    Blake
    2014 Spruce Mica DCSB
    Fantastic Nick! Thanks for sharing!
  8. Dec 31, 2016 at 6:24 AM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Can you describe what issues you were having prior to this, and if this process resolved them?
    NmapFE, Juicy Jay, ORtoCOTaco and 2 others like this.
  9. Dec 31, 2016 at 6:27 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Yes!
    Leedehua and Crom[OP] like this.
  10. Dec 31, 2016 at 6:28 AM
    ramonortiz55
    Ramon
    Texas
    stock
    this is also needed after lifting a truck
    NmapFE, tcjacado and Crom[OP] like this.
  11. Dec 31, 2016 at 7:21 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Sure.
    I installed a new front end suspension, that happened to have too much lift. I had an alignment. After starting the truck and driving for about 1 minute the slip indicator light would illuminate and stay on.
    Cycling the ignition, and driving, yielded the same behavior, so it was not a malfunction.
    This light is a dummy light. I looked into the technical manual and it explained that when this light is on, TRAC, and VSC features will not work until a calibration is performed.
    I performed the calibration procedure as explained, and it had resolved my problem, the slip indicator light never returned.
    As stated, Toyota recommends to recalibrate anytime that adjustments are made by a front end alignment. (Camber, caster, toe).
    In practice, I've owned my Tacoma for 7.5 years, lifted it at 5.5 years, and in that time I've had 20 front end alignments. This was the first time that my trucks VSC computer was not happy. After I recalibrated to confirm the issue and resolution, I then dialed in my front suspension lower, returning factory rake, had the truck realigned by shop, and I relalibrated the VSC computer again. I'm very pleased with it all.
  12. Dec 31, 2016 at 10:07 AM
    OZ-T
    Peter North
    British Columbia
  13. Dec 31, 2016 at 2:20 PM
    jnmargarit
    jnmargarit Well-Known Member
    Vancouver, B.C.
    '14 TRD Sport
    Nice. I'll have to give this a go.
    I noticed that after I changed out the suspension and lifted it, the VSC would kick in going around corners when I feel it shouldn't have.
    BOSSHOSS, tbird95, Weirich and 2 others like this.
  14. Dec 31, 2016 at 2:22 PM
    OZ-T
    Peter North
    British Columbia
    Welcome to the club haha
    NmapFE, HondaGM, PoweredBySoy and 2 others like this.
  15. Dec 31, 2016 at 3:45 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Awesome write up. Gonna have to give this a try. Like many others I got the cornering issues after lifting. Dealt with it for a while then one day for the hell of it I plugged in the computer and recalibrate it. Well the wheel must not have been perfectly straight because now turning right is fine and left turns it happens more often than before. This method seems mush faster and easier than using the obdII computer:thumbsup:
  16. Dec 31, 2016 at 4:22 PM
    jnmargarit
    Vancouver, B.C.
    '14 TRD Sport
    Glad there's a club and it wasn't my hack job of an install!
    Haha
    NmapFE likes this.
  17. Jan 2, 2017 at 8:43 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Can I make a suggestion?
    When I did this, I made a jumper harness with a single pole single throw switch in it. It makes shorting the pins easier as you can just leave the jumper in place and toggle the switch on and off vs having to remove/install the jumper wire multiple times.
  18. Jan 2, 2017 at 8:53 PM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    Exactly how this should be handled. SPST toggle switch makes this an easy process. Throw it in the toolbox when done as you'll need it again someday.
    GilbertOz and Biscuits like this.
  19. Jan 2, 2017 at 9:12 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Yes. That's a much more civilized way of operating. lol
    I'll include a picture or two for people.
    Thanks
  20. Jan 3, 2017 at 5:01 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Another suggestion -
    On eBay, I found a male OBD II connector (just the connector, no wires). I soldered a jumper wire across the 2 pins to trip ATF temp mode. All I do is plug the connector into the port, and do the dance with the shift lever to get into the temp mode.
    You could do something similar here (jumpering the correct pins, obviously) - you could even include a switch.
    The big advantage is only have to find the correct pins once, when building the connector, instead of every time you want to reset the VSC.
    Just a thought...
    GilbertOz, MTopp, Subway4X4 and 3 others like this.
