How to replace vacuum hoses ...
Discussion in '1st Gen. Tacomas (1995-2004)' started by George_taco1995, Jun 1, 2019.
  1. Jun 1, 2019 at 5:38 PM
    George_taco1995
    George_taco1995 [OP] Member
    Jorge
    White Pearl Tacoma TRD 1995 4x4 stick shift
    Hello everyone, I'm new on the forum,who knows the measurements of the vacuum hoses of the engine 3.4, I want to change mine and I can not find any information, thank you very much for your help.
    GQ7227, Running Board Man and Hobbs like this.
  2. Jun 1, 2019 at 5:46 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Hi George/Jorge! Welcome to The Forum!
    Not sure what you mean by measurements. Find the inside diameter (like 1/8" or 3mm or 1/4") and buy a roll of it. Or buy 10' at a time until you are done. You should have an emissions label under the hood with (hopefully) a vacuum hose diagram on it. Good luck!
  3. Jun 1, 2019 at 5:57 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck
    Welcome to TW! :hattip::wave:
    Check it out, @Frontier Man
    Another white ‘95 Taco!
    GQ7227 and Running Board Man like this.
  4. Jun 1, 2019 at 6:48 PM
    George_taco1995
    Jorge
    Sorry for the previous question, it was not well formulated, but thanks for answering, I actually look for the diameter of each vacuum hose of the engine to change, thanks for the help.
  5. Jun 1, 2019 at 7:26 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
  6. Jun 1, 2019 at 10:47 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    @Luv my yota recommended a nice hose kit recently to make everything look top notch, its late and I don't recall which one
  7. Jun 2, 2019 at 1:15 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    When I replaced vacuum hoses dealing with the EVAP system for my Supercharger, I just cut some pieces of different diameter tubing as a sample and went to AutoZone and bought 5-10 feet of each size depending on how much I was replacing.
    TacoJohn4x4 likes this.
  8. Jun 2, 2019 at 2:29 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If your not sure of the size ID take the hose to your Auto Parts vendor to match up
    I just buy the hose by the largest roll I can get it gets used
  9. Jun 2, 2019 at 3:58 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    Yeah, you could dig through ancient threads but here’s a great solution www.siliconehoses.com. They have a kit in 3 colors red,black,&blue enough vacuum hoses of different sizes in the 50 dollar kit I believe it’s called the shop pack and will replace every roached hose under the hood except for coolant. I went black because Ca smog doesn’t allow color hoses, these hoses don’t melt Or harden and are still supple. I almost can’t believe it and I got them 5 years ago when they were only 30 bucks for a box of hoses.
    jammer and GQ7227[QUOTED] like this.
  10. Jun 6, 2019 at 10:10 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    @Luv my yota
    That's a helluva clean engine compartment you have!!! And I mean CLEAN! The only "dirt" I could find was inside of the hood prop clip at the lower right of the photo... and that's probably a shadow. :thumbsup:
    Luv my yota and GQ7227 like this.
