How to replace O2 Sensors
Discussion in '1st Gen. Tacomas (1995-2004)' started by Alderleet, Dec 22, 2011.
  1. Dec 22, 2011 at 4:16 PM
    Alderleet
    Alderleet [OP] Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Alright, i decided to make this, since i just did it on both Bank 1 and Bank 2 (upstream/downstream) sensors.
    Also the "lieblweb" how-to link has no real visual reference, since the photos are blown out and tiny.
    Anyway, here we go!
    All work was performed on a 2000 Toyota Tacoma SR5 Automatic V6, NON-CA model.
    Materials needed:
    • Note: The type of transmission, drivetrain, and Emission type will change the part number for your O2 sensor.
    • Also note: OEM sensors are DENSO. Many folks have put in Bosch or "universal" only to have them fail a few thousand miles down the road.
    • Also Also Note: Line wrenches are a life saver, because more than likely the nuts holding your sensor in place are fairly rusty and corroded, and a normal wrench has a higher propensity to strip them smooth.
    Down to brass tax:
    I figured this would give a clearer picture, of "where exactly" the 2 Oxygen sensors are.
    Step 1: Unscrew the 2 nuts retaining the bad sensor.
    Step 2: Unclip harness. Use a screwdriver to pry the retaining tab off of the hook
    Step 3: Remove new O2 Sensor from box
    Step 4: Clean the area
    Step 5: Put sensor in, and apply anti-seize lube to bolts
    Step 6: Tighten nuts back on, and tighten the sensor *firm* but not to hard. Its not pressurized like a spark plug, so it doesnt need to be torqued down. Just tight with a quarter turn for peace of mind
    Step 7: Plug in connector
    Step 8: Wipe up the area, clean your hands, and enjoy a beverage
  2. Feb 3, 2012 at 6:35 AM
    BROGEO
    BROGEO New Member
    2004 Tacoma 4X4 Double Cab
    Wow, this is a great website! Thanks for the info. I couldn't be better put.
    My son is a Master Auto Tech but sees me as a Pain in the A--. last time my O2 sensors went out on my Ford he got them both wholesale for $100. Problem was he guessed which ones were bad and he was wrong. I was out the money.
  3. Feb 12, 2012 at 6:58 PM
    james
    james In over my head...
    Friday Harbor, WA: Fairbanks, AK
    '98 Tacoma V6
    Thanks for the step-by-step, Nick. I was *easily* able to the down downstream #2 sensor in about five minutes. Not so with the faulty one. The upstream #1 sensor has its electrical connection parked waaaaaaay up on top of the transmission, where the wiring is inconveniently stored. The "crux move" as we say in climbing parlance – the most difficult part of the problem – is in undoing the electrical connection parked where it cannot be seen nor easily gotten to. If I pay hundreds to a garage for the privilege, how will they eventually get at that pesky connector? How can I do it?
  4. Feb 12, 2012 at 7:09 PM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    I was able to get to the upstream sensor on a 5 spd manual 4x4 by removing the center console and taking the boots off of the shifters and going through the hole. I had to remove the sensor first and then pull the wiring up to the hole. Also had to remove the bolt holding the wire connector. A real PITA.
    Atlastrekker likes this.
  5. Feb 12, 2012 at 7:12 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Nice write up. I had to replaced an O2 Sensor previously, heat and some swearing were involved...
  6. Feb 12, 2012 at 7:27 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    iv replaced 3 of em between 2 taco's iv owned... Never been able to unthread them. Chop them off with a chistel becase they rot off in like 4 years:mad: I have clean/rust free truck envy right now.
  7. Feb 12, 2012 at 7:46 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    You don't need to use a line wrench on those bolts, the closed end of a standard wrench would work better. You only need to use a line wrench when you can't fit a closed end wrench or socket over a fastener because of the need for a slot for the wires or brake lines to pass through. You use a line wrench in place of an open end wrench because it makes more contact and has less chance of stripping than an open end wrench.
    You normally do need to use a line wrench on most oxygen sensors though. That's because most of them look like this
    The design used on tacomas is actually much better IMO, eliminates the need for a line wrench wrench or special socket which is actually a big deal in cars that have O2 sensors in hard to reach areas.
    anti seize is a great idea, and putting some dielectric/silicone grease in the electrical connectors is a great idea as well to protect from corrosion.
    Also, anytime you're removing ANY exhaust fastener, soak that shit with some penetrating oil and let it sit for a few minutes first. If your truck is pretty rusty, I'd soak it several times leading up to when you want to remove it. Decreases the chances of breaking/rounding fasteners and lots of swearing.
    Mine actually just went bad yesterday. This was the best deal I could find on the OE denso part. http://www.amazon.com/Denso-234-9003-Oxygen-Sensor-Ratio/dp/B000C5UFU8
    I would have paid more to get one at a local parts store immediately, but all of them only had the lowlier bosch sensors in stock.
    jgutweiler likes this.
  8. Feb 19, 2012 at 2:56 PM
    james
    '98 Tacoma V6
    This was the best advice. Thanks. Everything worked out great.
  9. Feb 19, 2012 at 6:59 PM
    tacoma04
    Bruce
    Tennessee
    Glad it helped. I sure couldn't figure out any other way, but I am sure there is a one, lol.
  10. Feb 20, 2012 at 7:07 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Thank you for this! This is on my list of things to do. Anyone know where the best place to get the sensors besides Amazon?
  11. Feb 20, 2012 at 8:51 AM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Awesome write up OP. Some green love to ya!
  12. Jul 12, 2013 at 5:26 PM
    Westbound
    Westbound Member
    Thank you very much for the suggestion. I followed your method and it worked... i didn't have to remove the bolt holding the wire, but finally the connector was disconnected after lots of cursing and struggle....
  13. Jul 13, 2013 at 7:03 AM
    tcrhino
    tcrhino Active Member
    Twin Cities, MN
    4x4
    3" toytec suspension lifted
    awesome! thanks for the step by step with photos! this should be a sticky :p
  14. Jan 11, 2014 at 10:22 AM
    Madjik_Man
    Colorado Front Range
    This is by far the dumbest fucking design flaw I've encountered on this truck.
    If they just moved the clip, where the sensor ties into the wiring harness, back 2" this would be a five minute job.
    Instead they decide to make the fucking clip impossible to reach from either under the truck or through the hole in the tranny hump.
    How you were able to remove 14mm bolt holding the harness, let alone get to the clip is beyond me. I can get a socket on the bolt but there is no way to move the driver because of the stick shift and body prevent any movement.
    I can barely fucking touch the goddamn clip with my fingers let alone even fathom out to unclip the sensor from it and insert the new one. It's as if you have to drop the fucking transmission to get to this fucking clip.
    What a pitiful design by Toyota. Meanwhile the downstream sensor wiring clip is right there next to the sensor. Easily accessible. Imagine that.
  15. Nov 7, 2014 at 10:47 AM
    JT1521
    JT1521 Well-Known Member
    Is it ok to put anti-seize on the bottom of the o2 sensor gasket? I ask this because my friend who helped me install this did this before I could say anything lol. I hope the anti-seize doesn't leak into where the o2 sensor is.
  16. Nov 7, 2014 at 1:31 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Looks easy to do, thanks for the writeup! Should become a sticky so we can find it easy when we need it moderators.
  17. Nov 7, 2014 at 1:38 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    as long as its not a crap ton, you should be fine. if it freaks you out just pull it off and wipe it clean.
  18. Nov 7, 2014 at 4:10 PM
    JT1521
    One other thing. Is the gasket reversible? Can it go on either way? Thanks.
  19. Nov 7, 2014 at 10:59 PM
    paquu
    paquu Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    I asked the parts guy at the dealers counter. He said you can put it either way. I tried to put the new one on the same way the old one came off.
  20. Nov 8, 2014 at 7:51 AM
    EdFlecko
    EdFlecko Well-Known Member
    Ed
    Sacramento, California
