How to remove the fuse box door/cover (interior)?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brandon78lusch, Oct 21, 2020.
  1. Oct 21, 2020 at 12:33 PM
    brandon78lusch
    brandon78lusch [OP] Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I’ve been trying to get to the fuse box for a few hours now. Gonna be wiring a lightbar and I have to use the interior fuse box to light the switch apparently. I wanna make sure I know what I’m doing before I install this. I’ve been trying to get to the fuses but no luck.
  2. Oct 21, 2020 at 12:34 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Don’t want to sound like a dick but have you tried YouTube ?
  3. Oct 21, 2020 at 12:35 PM
    brandon78lusch
    Brandon
    Can’t find anything on YouTube. Couldn’t even find the location of this fuse box until today
  4. Oct 21, 2020 at 12:43 PM
    GOTSAND?18
    stock
    helix66 likes this.
  5. Oct 21, 2020 at 12:54 PM
    AMC_Unlimited
    AMC_Unlimited For he is limitless (sometimes)
    AMC
    Ironman Tribute Edition
    Mall Crawl Control
    Work the latch from the back, pull down then forward. Might be a little tricky to reach back there,keep working it or get someone with small hands to help.
    greenmean666 likes this.
  6. Oct 21, 2020 at 12:58 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Is that meso cover easier to use?
  7. Oct 21, 2020 at 1:04 PM
    AMC_Unlimited
    AMC
    Mall Crawl Control
    Yeah I had to get it to better fit the add a fuse, since it provides more clearance for stuff in there, and it has perforated notches you can knock out to run the wiring out of.
  8. Apr 1, 2023 at 1:53 PM
    greenmean666
    greenmean666 Member
    4q
    1995 Evergreen Pearl Tacoma LX 2.4L 2WD + 2016 Black Tacoma 4 Banger Full Bed
  9. Apr 2, 2023 at 11:48 AM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Yup, one of the worst design elements of this vehicle, I broke mine within the first month. It now sits in the charging port area. Hope I don't lose it.
  10. Apr 2, 2023 at 2:20 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    meso cover absolutely worth it and much easier to remove. that OEM cover is garbage.
  11. May 4, 2023 at 9:40 PM
    applejack1
    applejack1 New Member
    Stumbled on this thread trying to get my Tacoma fuse cover off to replace a blown auxiliary power port fuse . For sure don't try to remove the cover the way the videos show in post #4. The other instructions on this thread were unclear to me, so I thought I'd post how I got mine off (without breaking it) as clearly as I can.
    It took me about a half hour pulling and pushing with no success, but almost broke the cover. I finally took some pics with my phone under the dash and was able to figure out how to get it off without breaking it. Sure, one can get another fancier cover, but who wants to spend at least 20 bucks getting a new fancy cover when no one even sees it?
    First, let's do away with this terminology of front and back, or at least clarify it. To make things clearer, lets assume a ghost is sitting in the driver's seat. I use ghost because a real person in the driver's seat would have physical legs which would get in the way of you crawling around their legs to remove the fuse cover.
    So, to remove the cover, first you lay your back on the floor mat (right on top of the ghosts feet). You look up and you will see the cover just above the ghost's left foot, under the dash.
    The cover is rectangular shaped and is fastened on two ends. One end is closest to the ghost's left knee (we'll call that the front of the cover), the opposite end is also fastened.
    You want to remove the end closest to the ghosts knee first. But, don't use a prying tool, like the videos in post #4 show. Instead there is a little slot on that end. The little slot is shown in the bottom of the pic below. That slot has a little plastic barb which keeps that end on, when it's installed under the dash (again we are talking about the end closest to the ghost's left knee). That end is the key to getting the whole cover off, without breaking it.
    To get the cover off, you want to stick a very small screwdriver in that little slot. Pictured below is the screwdriver I used to get the cover off. For the picture, I stuck it in the slot so there is no confusion.
    Once you have your screwdriver in that slot of the cover, under the dash, you want to gently pull the screwdriver towards the ghost's left knee and slightly down. Just pull the screwdriver straight back and slightly down. This will unlatch that end of the cover from the latch. It doesn't take much force. That end will drop down about an inch. Once that end is undone, take the cover and push it away from the ghost's left knee (the opposite way you pulled the screwdriver). That will release the other end.
    Here is a pic of the reverse side of the cover. You can see how the cover is held on by the ends. The right end is the one you want to release first, which will be the end closest to the ghost's left knee when the cover is installed under the dash.
    Once you get the cover off, take care this doesn't happen to you.
  12. May 5, 2023 at 7:40 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    it's a cover... pull it off, if you break it, throw it in the glove box for future reference of fuse location. Ski
    Stevie17 likes this.
  13. May 5, 2023 at 7:49 AM
    rbdudeman
    rbdudeman Well-Known Member
    applejack1: thanks for taking the time and effort to explain that. It is a pretty lame design.
    applejack1, Stevie17 and 19992021Taco like this.
  14. May 5, 2023 at 8:55 AM
    Toycoma2021
    Yup, the first thing I broke on my vehicle in the cold and snow… frustration.
    applejack1 likes this.
  15. May 5, 2023 at 11:19 AM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Thanks for taking the time to post this!
