How to remove stripped nuts from tight spaces?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Nov 26, 2024.
  1. Nov 26, 2024 at 9:00 AM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
  2. Nov 26, 2024 at 9:17 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Is just the nut spinning or is the bolt spinning with it? I couldn’t tell
    2009Access4x4[OP] likes this.
  3. Nov 26, 2024 at 9:21 AM
    2009Access4x4
    Shane
    Only the nut is spinning. It's a flanged nut on a stud.
  4. Nov 26, 2024 at 11:10 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    A dremel with abrasive cutting blade, your cut would be at an angle across the nut, if you stop right before you reach the threads you can take a cold chisel to the cut and split the bolt open enough to slide it off.
    grizquad and 2009Access4x4[OP] like this.
  5. Nov 26, 2024 at 3:47 PM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Are you sure re only the nut spinning? If so, then it was tightened so much that it stripped the threads. Or, it broke the weld on the stud and the stud is also spinning. I'd assume #2, but a pair of pliers will tell you.
    In any event, because of the placement, I can't see how you can resolve this without removing the door panel and going at it from the inside.
    wilcam47 likes this.
  6. Nov 26, 2024 at 3:58 PM
    2009Access4x4
    Shane
    The studs are not spinning. Any idea how to remove a stripped nut? Previous poster recommended a dremel. Yes, I’ll have to remove the panel.
  7. Nov 26, 2024 at 4:26 PM
    gotoman1969
    The dremel is gonna be your best option imo
  8. Nov 26, 2024 at 4:28 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    It is a tight space to do so but get something between the flange and the metal and pry as you turn. Often this works for me. The difficulty is the access in this case and the minimal space between fastener and metal. Might try a bent-up feeler gauge or go to a craft store for a paint spatula, even a razor blade with some plyers on it to turn it.
    Or, yes, work from inside prying on the part internally as you turn the nut(s) from the door jam.
  9. Nov 26, 2024 at 5:23 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Yes about the only option.
  10. Nov 26, 2024 at 5:42 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I think it would be worth trying to grab it with needle nose pliers and try to untwist it. The threads might catch.
  11. Nov 26, 2024 at 6:39 PM
    2009Access4x4
    Shane
    I tried with vice grips already. Going to buy a dremel off FB marketplace
    Musubi3[QUOTED] likes this.
  12. Nov 27, 2024 at 6:38 AM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    Those little cutoff disks and thin and crack off easily, that's expected and they come in a pack with 10-20 of the disks. One will cut that nut with no problem, takes a little while, probably 4 or 5 min and probably 2 or 3 of the cutting disks.
  13. Nov 27, 2024 at 7:06 AM
    2009Access4x4
    Shane
    Thanks!
  14. Nov 28, 2024 at 9:51 AM
    Steve_P
    TN
    When you used the vise grips, did you try pulling on the nut, axially out, when turning? This is the only way you have a chance to get the threads to catch.
    While some sort of cutting tool will be required, I think it will be difficult to remove from the outside without butchering the paint. I would personally attack it from the inside as you will probably have to change the stud anyway.
  15. Nov 28, 2024 at 10:52 AM
    Waasheem
    Waasheem
    2007 xrunner
    There’s something called a nut splitter that might if you can get it on the nut, probably not.
    Something else to try is to pry outwards from behind the nut with a screwdriver or panel clip tool, then try spinning the nut. I’d use a small impact. I have a small blue nail puller I use for things like this. It was cheap at Home Depot. I took a grinder to the nail slot so it fits.
    If all else fails you could take a small impact to it & spin like crazy until it breaks. But this could mess up the hole.
    If you mark the stud, you’ll know for certain if it’s spinning or not.
