How to remove spare tire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PatinoTheLatino, Sep 18, 2016.
  1. Sep 18, 2016 at 10:57 AM
    PatinoTheLatino
    PatinoTheLatino [OP] New Member
    Alejandro
    2008 Trd sport Tacoma
    I got a flat on the front Passenger door , I jacked up my truck and removed the tire but am having trouble on how to remove the spare tire underneath the truck.
    Thanks.
  2. Sep 18, 2016 at 11:10 AM
    10trdtaco
    10trdtaco American Infidel *DON'T TREAD ON ME*
    Shayne
    Lynchburg, VA
    2010 Tacoma TRD Sport DCSB
    4" lift 33-12.50-17 Atturo Trail Blade M/T 17" HELO TRD Satoshi Blackout Grill Tinted headlights with caliraised led headlights ... More to come
    Your wheel removal kit builds to be a tool to lower it, there is a slot near your rear license plate that you stick that fully assembled rod into and lower it, if you get under the rear you will see where it grabs into to lower the tire... it's very simple.
  3. Sep 18, 2016 at 11:15 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Just crawl under there and you'll see. The chain slips through the center of the wheel
    nono0221 likes this.
  4. Sep 18, 2016 at 11:17 AM
    WATaco
    WATaco Well-Known Member
    Ed
    Seattle-ish, WA
    '14 Tacoma ORD
    Leer, AllPro sliders, Prinsu, OME, JBA UCA
  5. Sep 18, 2016 at 11:49 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Well OP, you've been viewing this thread for a hot minute. Did you figure it out?
    Stryker420 likes this.
  6. Sep 18, 2016 at 7:18 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Wow! Unbelievable.
    When all else fails read the instructions ( owners manual ).
    Thebubble, Stryker420, ABNFDC and 3 others like this.
  7. Sep 18, 2016 at 9:13 PM
    PatinoTheLatino
    Alejandro
    I got it, thanks guys it took me a while to find the whole because I had extra break lights covering the whole near the tailgate .
    Thanks a lot!!
  8. Oct 3, 2018 at 6:09 PM
    Dcox
    Dcox Well-Known Member
    Dave
    Oregon
    2018 Tacoma Sport AC MT
    Grill swap, level, tires and wheels, bed lights, tailgate actuator
    I know this is an old thread but figured I would add a tidbit for other new Tacoma owners. The hook on the rod doesn't actually hook on anything. There is a cup the shape of the hook above the spare which the hook slides into / up against. I must have spent 20 minutes trying to hook an eye screw before just trusting the instructions and simply turn the shaft when I felt resistants. Also, there is a plastic retainer clip from the factory that will brake the when you first turn it so you need to put some muscle into getting it started.
  9. Oct 3, 2018 at 6:11 PM
    Bishop84
    Bishop84 Well-Known Member
    I would encourage people to simply check it prior to a road trip and make sure it has air as well.
    Good shops like mine will top them up with a special chuck, but we never really use the mechanism.
  10. Oct 3, 2018 at 6:22 PM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    Pulled the spare out of my 2000 4Runner, 0 psi. Had to use pliers to get the cap off the stem. Next time I replace the tires that old one will be going.
  11. Oct 3, 2018 at 6:31 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    What about your dad making you practice putting the spare on in the driveway when you got your learner's permit? Is that still a thing?
  12. Oct 3, 2018 at 6:40 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    No because most dads can’t check their tire pressure, let alone swap a tire out
    everymanalion, DGXR, Harry and 4 others like this.
  13. Oct 3, 2018 at 7:00 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    The more I help people fix simple repairs on thier vehicles or motorcycles, the more I realize I've taken all the skills/knowledge I conciously and subconciously learned from my father over the years for granted. The way motorized things work or how they most likely should work comes pretty second nature at this point.
    I've fairly recenly taken the drivers courses in California (2012), and I definitely think that there should be morebasic "emergency" or maintenence instructional parts to getting a permit.
  14. Oct 3, 2018 at 7:42 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Literally first thing I did after getting it was drop the spare so I knew how to do it in the dark.
    Biscuits and DGXR like this.
  15. Oct 3, 2018 at 9:27 PM
    Dcox
    Dave
    Oregon
    In the 80s the Tacoma didn't exist and the tool used to drop the spare was a gigantic flathead crowbar. Maybe I'm the only one that figured a hooked tool should hook on something, least that's what my dad taught me.
    Biscuits and b_r_o[QUOTED] like this.
  16. Oct 3, 2018 at 11:08 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It does hook onto something... The Bottle Jack crank...
    Biscuits, Bebop, PzTank and 6 others like this.
  17. Oct 4, 2018 at 6:08 AM
    badger
    badger Well-Known Member
    07 SR5
    Correct....Maybe check with your grandpa. Dad's aren't what they used to be.
    Stryker420, Blockhead and DGXR like this.
  18. Oct 4, 2018 at 6:29 AM
    nobescare
    nobescare Well-Known Member
    Mark
    43.5448° N, 80.2482° W
    2019 Highlander SE
    My 2005 prerunner had frame failure Aug 2024
    and another thing, you should lower it at least once a year and grease the chain, cable and mechanism. i've actually had to have someone hang from the wheel from underneath while trying to turn the mechanism to free the wheel. especially if you're in a salt use area like i am
    Biscuits and PzTank like this.
  19. Oct 4, 2018 at 6:58 AM
    TheBigKahuna
    TheBigKahuna Well-Known Member
    Regarding the spare.
    I've owned pickups for almost 30 years.
    I only had to crawl around in slush once before I moved the spare into the bed.
    I got my Tacoma less than 2 weeks ago and that was the first thing I did.
    I will be adding a cable with lock.
    nobescare and Alexely999 like this.
  20. Oct 4, 2018 at 7:05 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Or a camper shell :cheers:
