How to Remove Seized Wheel
Discussion in 'Technical Chat' started by hladun, Jun 28, 2017.
  1. Jun 28, 2017 at 11:10 AM
    hladun
    hladun [OP] Well-Known Member
    Alberta
    Tacoma
    If you remove the nuts and the wheel won't come off because it's seized here's the easy way to do it. Put two or three nuts on across from each other and engage three or four threads (3 or 4 rotations). Lower the vehicle and drive back and forth a few feet. Wheel will break off and then complete removal.
    boston23 and rizrox like this.
  2. Jun 28, 2017 at 1:42 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    That sounds pretty sketchy, and a good way to damage or shear off your wheel studs.
    Why not use some penetrant/wd40/whatever around the mounting surface and then give a few raps with a rubber mallet or deadblow hammer.
    NM Lance likes this.
  3. Jun 28, 2017 at 1:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    :eek:
    Dear genteel readers, please consider this as a 'what not to do'.
    Kinda like 'hey, ya'll watch this!'
    TOMB, Forshee47 and jAndyMendo like this.
  4. Jun 28, 2017 at 1:55 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  5. Jun 28, 2017 at 2:00 PM
    hladun
    Alberta
    Tacoma
  6. Jun 28, 2017 at 2:06 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Huh, they must teach engineering differently in Canada. I have a masters degree in structural engineering, and this is the hillbilly-ist thing I have seen in a long time.
    Edit: for what it's worth, our wheel studs are m12, which have a minor thread diameter of (max) 0.407 inches, and are metric grade 10.9 with an allowable shear stress of 90 ksi (not sure why we're talking about Gr 5 1/2" bolts). That works out to a shear strength of just under 6 tons each. So no, you probably won't snap off the wheel studs doing this, but they are simply pressed into the hub plate with knurling, which could bend the studs, the hub, or (most likely) damage the threads enough that your lug nuts will not thread on correctly.
    TOMB, IronPeak and jAndyMendo like this.
  7. Jun 28, 2017 at 2:09 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The OP's method is pretty common if you have ever had to remove an aluminum wheel that has bonded itself to the hub. I was fortunate enough I only had to give it a good kick.
    koditten and Plain Jane Taco like this.
  8. Jun 28, 2017 at 6:07 PM
    hladun
    Alberta
    Tacoma
    I just picked a representative value for the bolt, but by your own calculation the 6 studs have a total sheer strength of around 36 tons. So the wheels certainly and not "probably" won't shear off. Next we can do the bending calculations which will show just how silly the bending assertion is. Lastly, Toyota lug nuts are internally threaded sleeves so thread damage is another scare speculation. If you claim science you should be scientific.
    Travlr likes this.
  9. Jun 28, 2017 at 6:11 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    VW guys have been doing this for years
  10. Jun 28, 2017 at 6:11 PM
    sjwhitaker
    sjwhitaker Today Was A Good Day.
    Jake
    Berea, KY
    2010 DCSB TRD Offroad 6MT - Icon Stage 2 - 285/75/16 Falken AT3W
    The wheels on my FJ we're seized BADLY when I bought it. I tried everything I could think of and when it was all said and done the only way to get them it was a 5lb sledge hammer and beating the shit out of the tire sidewall as I spun the wheel.
  11. Jun 28, 2017 at 6:13 PM
    hladun
    Alberta
    Tacoma
    Thank you (and Dexterdog) for your confirming comments. Obviously some of the incredulous and terror-struck other posters haven't heard of this.
  12. Jun 28, 2017 at 6:16 PM
    Plain Jane Taco
    USA
    The VW guys have all 5 lugs on...but just not quite tight. Then they drive in a tight circle and it breaks the wheel off the hat. Later model VDub wheels are notorious for becoming one with the hub.
  13. Jun 28, 2017 at 6:40 PM
    jAndyMendo
    jAndyMendo i eat samiches
    Andy
    San Diego, CA
    2014 TRD 4x4 OR 2016 4Runner fake-TRAIL Edition
    is his what happens when you dont use your truck properly? my wheels come off way too frequent to ever seize to anything
    anthony250f, uhplifted, drr and 2 others like this.
  14. Jun 28, 2017 at 6:51 PM
    hladun
    Alberta
    Tacoma
    That's lovely.
    jAndyMendo[QUOTED] likes this.
  15. Jun 28, 2017 at 7:59 PM
    WBF610
    WBF610 Member well known
    Carey
    Eastern PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
  16. Jun 28, 2017 at 8:11 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Sounds like a lot of wasted time. Just hit the sidewalls a few times with a BFH and be done with it.
    joeyv141, Lawfarin and jAndyMendo like this.
  17. Jun 29, 2017 at 1:31 PM
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Then you have not had really seized wheels.
    OP's trick is easy and functional, harmless too. But remember to put some paste/grease between the center hole and hub.
    Plain Jane Taco likes this.
  18. Jun 29, 2017 at 1:34 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    VW uses lug studs tho
  19. Jun 29, 2017 at 1:55 PM
    hladun
    Alberta
    Tacoma
    And so???
  20. Jun 29, 2017 at 1:57 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    This is a pretty common trick in cold-weather climates. Sometimes it's the only way to get a cold aluminum wheel off of a cast iron brake rotor when it's zero degrees out and you don't have a heated garage to park it in (and 5 hours to wait for it to warm up).
    If you do it correctly (loosen the lug nuts just enough that they aren't contacting the wheel) you don't have to worry about breaking or damaging anything.
    Travlr and Plain Jane Taco like this.
