How to remove radiator cap?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crackerman, Feb 24, 2022.
  1. Feb 24, 2022 at 1:12 PM
    crackerman
    crackerman [OP] Member
    2021 Metallic Grey
    Bakflip MX4, Meso lights, Expedition Essentials Rail
    During the 20% off sale I bought a TRD Oil Cap and TRD radiator cap. (Need 0/10, Personal happiness 10/10)
    I can't get the radiator cap off of the radiator (not the overflow tank). I can turn the cap and the parts that hook onto the neck seem to be in the correct slots to pull off, but I can't get the cap to come off.
    Any trick I am missing?
  2. Feb 24, 2022 at 1:22 PM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Push down on it as you unscrew it....
    skeletron, hiPSI and davidstacoma like this.
  3. Feb 24, 2022 at 1:24 PM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Push down while turning.
    skeletron, Junkhead and Tacospike like this.
  4. Feb 24, 2022 at 1:34 PM
    KCU Beor
    KCU Beor Well-Known Member
    Ala.
    2022 Super White TRD Off Road M/T
    On a somewhat related note - I did receive my skid this TRD evening from Franklin...seems the 20% thread got removed.
  5. Feb 24, 2022 at 1:50 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Since no one is being helpful, push down and twist until it stops (lock tabs are lined up) then wiggle / twist as u pull up. Sometimes the tabs get bound up on the plastic.
  6. Feb 24, 2022 at 1:58 PM
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    That are what responses should to be like. Helpful!
    crackerman[OP] likes this.
  7. Feb 24, 2022 at 2:02 PM
    eurowner
    eurowner Duke Sky
    Scoty
    IIRC it was tight-fitting when I removed my OEM cap and installed the TRD version.
    "Enhance performance in high-rpm or high-load conditions with the TRD radiator cap.
    • Releases at higher cooling system pressures than factory caps, raising the coolant boiling point to help protect the engine @ 18.5psi"
  8. Feb 24, 2022 at 2:08 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Tbf, I've had my fair share of shit talking as well lol. I'm just as guilty haha
  9. Feb 24, 2022 at 2:13 PM
    Clearwater Bill
    Billy
    Largo Florida
    Just be sure the truck is cold-ish when doing this.
    Safety first. And easier when system is not pressurized. :thumbsup:
    Tacospike likes this.
  10. Feb 24, 2022 at 2:18 PM
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    Funny responses. Only try to remove when cold. Try tapping the cap with the handle of a screwdriver. Then push down and turn. A small piece of sandpaper will give you extra grip
  11. Feb 24, 2022 at 2:26 PM
    crackerman
    2021 Metallic Grey
    Thanks, that worked.
    Now that it done, keep the shit talking going. I get its a lame question but I appreciate the correct answer first.
    Last couple of cars have only had the overflow tank.
  12. Feb 24, 2022 at 2:28 PM
    Tacospike
    Two Trucks
    Oh, we know
    you little :devil:
    :fistbump:
    StayinStock and Skydvrr[QUOTED] like this.
  13. Feb 24, 2022 at 2:29 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    You figured it out and we all had some fun. That's the beauty of this forum!
    davidstacoma likes this.
  14. Feb 24, 2022 at 2:34 PM
    Taco75605
    Taco75605 Well-Known Member
    Blake
    2022 Tacoma TRD Sport RWD
    As we say in Texas, How many Aggies (Texas A&M Students) does it take to remove a radiator cap? It takes 21. One to hold the radiator cap and 20 to pick up the vehicle and turn it.
    vivid02 likes this.
  15. Feb 24, 2022 at 2:34 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
  16. Feb 24, 2022 at 3:45 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I swear your posts even sound like Cosmo Kramer! lol
    Bonus comment- I bet more than a couple posting or reading this thread have never removed a radiator cap and are thankful to have learned something before they tried lol.
    skeletron and Skydvrr like this.
  17. Feb 24, 2022 at 5:01 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Radiator caps are childproof...
  18. Feb 24, 2022 at 5:03 PM
    rnish
    Tacoma 2nd gen
    Lighten up people. Somebody had to teach all of us how to use a spoon.
  19. Feb 25, 2022 at 11:09 AM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    :D
    This one time in band camp……
    Bronxguy, FL_TRD Sport and hiPSI like this.
