How to remove Armor all like product from interior?
Discussion in 'Detailing' started by Chad, Jan 1, 2015.
  1. Jan 1, 2015 at 2:14 PM
    Chad
    Chad [OP] Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    So I just got my truck back from the body shop, and they have put some type of oily and greasing looking stuff on the the interior dash, plastics and steering wheel. This junk reeks to the high heavens and looks terrible as well. I'm not sure if it is armor all or not but it appears to be similar to it.
    I've already tried warm water and detergent but that doesn't appear to have done much. Does anyone know a good way or some product I can use to get this stuff off?
  2. Jan 1, 2015 at 2:28 PM
    JAGER91374
    JAGER91374 Well-Known Member
    Des Plaines
    3 TRD O/R
    OME 883's and Dakars, OME Shocks, Gray Wire, Deck Plate, Blacked Out Chrome, RAT Skids, BAMF BPV Bracket, Toytec Diff Drop, Braided Extended Brake Lines Front and Rear, In-Dash Nav.
    Start with a simple cleaner like Windex. If that doesn't work then step up to rubbingalcohol. The 91% stuff will take off anything including rain-X off your windows
  3. Jan 1, 2015 at 2:49 PM
    Chad
    Chad
    Cary, NC
    Would the rubbing alcohol not damage the plastics?
  4. Jan 1, 2015 at 2:50 PM
    SoutheastTaco
    SoutheastTaco Resident Jackass
    steven
    columbia sc
    09 trd sport dc 4x4
    rear spring tsb, 255/75/17 bfg muds
    I'd make them remove it. You didn't ask for it, correct?
  5. Jan 1, 2015 at 2:51 PM
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Windex should do the trick. Thats where I would start. Then simple green or a citrus based cleaner.
  6. Jan 1, 2015 at 2:59 PM
    Chad
    Chad
    Cary, NC
    Yes, but due to certain circumstances the body shop is 2 hours from where I live, and will not be back in that area for several weeks. They also have air bubbles in the TRD sport sticker they had to replace as well.
    I'll go pick up some simple green tomorrow.
  7. Jan 1, 2015 at 3:05 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    White vinegar and water will do it and won't leave a residue or smell.
  8. Jan 1, 2015 at 3:22 PM
    Chad
    Chad
    Cary, NC
    I'll try this before buying simple green as I have some vinegar laying around. Is it a 50/50 mix or does it really matter?
  9. Jan 1, 2015 at 3:26 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Doesn't really matter but I always use a little more water than Vinegar.
  10. Feb 17, 2015 at 9:34 AM
    TacoM3DX
    TacoM3DX Well-Known Member
    Kal
    DC
    URD DCSB
    URD SC, VBU, Spec-U headers and exhaust.
