How To: Remove and disassemble side view mirrors
Discussion in 'Detailing' started by InTheRough, Mar 15, 2013.
  1. Mar 15, 2013 at 12:33 PM
    InTheRough
    InTheRough [OP] Well-Known Member
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    I know not everyone likes the look of painted side mirrors but for those of you that do here is a good step-by-step for how to do just that. It took me about 10 to take this apart and put back together. Good luck.
    Tools needed:
    10mm extended socket or short with an extension
    Small flat head screw driver
    Ratchet
    T-25 bit
    PH3 bit
    Driver
    Remove interior side view mirror cover by pulling away from the door:
    Use flat head to reveal two Philips head screws in the door panel:
    Remove electronic panel by pulling up on the front then forward and up:
    Remove plastic clip by pushing in on the center then pulling it out:
    Unplug wiring harness and adapter from side view mirror:
    Use flat head at the bottom of the mirror class to release two clips then pull mirror down and out:
    Use 10mm socket and rachet to remove the 3 bolts holding mirror to the door:
    Use Philips head to remove one screw holding plastic protector in place:
    Use flat head to remove plastic cover at the bottom of the mirror then remove 3 T-25 bolts:
    Separate base from cover carefully and remove one T-25 bolt holding the metal piece in place:
    Use Philips head to remove 1 screw at the bottom of the cover:
    Use Philips head to remove 3 screws inside the cover and remove mechanism:
    DONE!
    Repeat steps on driver side for the same results.
    Follow steps in reverse to assemble everything.
    Revelations and Less4Than8Jake like this.
  2. Mar 11, 2014 at 7:10 PM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Great info! I know its old, but I wanted to bump it so others can use this useful information
  3. Mar 11, 2014 at 7:18 PM
    InTheRough
    Kolt
    Gig Harbor, WA
    '20 Tundra Platinum
    Rock Warrior wheels
    Hey, out of 569 view, if I can help one person, that's good enough for me lol
    Glad the information could help. :thumbsup:
  4. Apr 15, 2014 at 1:56 PM
    Ernesto4
    Ernesto4 Well-Known Member
    North Hollywood
    15 Tacoma access cab 5 lug SR5
    Might not really be related to your post but I just wondering can the actual glass mirror part be purchased separately? Is there a part number for that part? Thanks
  5. Oct 10, 2014 at 4:45 PM
    tacowhisperer
    tacowhisperer Member
    los angeles
    02greentaco
    this thread helped me a lot! thank you! i needed to know how you disconnect the mirror part from the shell on my 1st gen and boom.. thanks again!!
  6. Oct 10, 2014 at 4:47 PM
    tacowhisperer
    los angeles
    02greentaco
    ernesto4 i had your same problem and no one will sell it separate so i found an oem complete one at the junk yard for 30 bucks!! woo hoo!!!
  7. Nov 5, 2016 at 7:14 PM
    mexitacoma94
    mexitacoma94 El Rojo
    Alex
    california
    06 prerunner DCSB Radiant Red
    LEDS- brakes,reverse,corners,interior/3k foglight hids,raptor style grill lights. - big country brush bars. -BFG rugged terrain (for now). -GTA audio kit.
    How did you remove the glass ?
  8. Nov 5, 2016 at 7:19 PM
    mexitacoma94
    Alex
    california
    ^ nevermind just reread your post and saw my answer thanks for the great write-up by the way gonna help me a lot when I install leds under the mirrors (like BMW's ) :D
    InTheRough[OP] likes this.
