How to Remove and Clean Windshield Washer Container?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wingspar, Sep 10, 2017.
  1. Sep 10, 2017 at 1:46 PM
    wingspar
    wingspar [OP] Well-Known Member
    Oregon
    2011 Tacoma 4x4 Access Cab
    Title says it all. I did a search with zero results. My windshield washer container is black inside. I put a couple of drops of bleach in and now I have a bunch of black floaters. I'd like to remove it and thoroughly clean it, but I don’t have a clue as to how to proceed.
  2. Sep 10, 2017 at 1:54 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    It's only attached by 3 Bolts.
    jackn7 and cruxofthebisquit like this.
  3. Sep 10, 2017 at 2:00 PM
    wingspar
    Oregon
    I’ve seen those bolts, but I can’t see what kind of electrical and hose connections there are and how to disconnect them.
  4. Sep 10, 2017 at 2:01 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    If you unscrew those and move it around you will get a better view though
  5. Sep 10, 2017 at 3:53 PM
    wingspar
    Oregon
    Ok, just took those two bolts off and that’s as far as I got. No idea how to disconnect the electrical connection. No idea at all and it’s not easy to reach.
  6. Sep 10, 2017 at 4:16 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Just disconnect the pigtail off the pump
    theredofshaw likes this.
  7. Sep 10, 2017 at 4:59 PM
    wingspar
    Oregon
    When it comes to electrical stuff, I’m a dummy. Googled Pigtail, but it didn’t help, so I guess a photo is in order in case what I have is different from what some may be thinking. I have two arrows in the photo. These seem like they are two different connections. Is number 1 in the photo the pigtail? If so, how does one get it off? I have no clue. It is on tight enough so that if feels like it is part of #2.
    TXpro4X4 likes this.
  8. Sep 10, 2017 at 5:06 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    1, should have a little tab where you push down and pull the connector right off.
    wingspar[OP] and TXpro4X4 like this.
  9. Sep 10, 2017 at 5:11 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    ^Yes
    In the pick the part that you press in is on the bottom side. What's the pressure you should be able to pinch it and pull it apart, kind of like the same thing that's on the back of the head lamp.
    wingspar[QUOTED][OP] likes this.
  10. Sep 10, 2017 at 6:08 PM
    wingspar
    Oregon
    With the help from this thread, a mirror and a flashlight and about 10 trips out to the truck to try an figure it out, I finally figured it out. Why don’t they put that little tab on top where someone can see it?
    Cleaning the reservoir out was a chore due to the shape and a baffle around the filler opening, but I can see the bottom of the reservoir when it is full now. Should have taken some photos of it before I cleaned it, but did not think of it. Water was black and black mold was stuck to the inside and chunks were floating around.
    I’ve used that 20/20 windshield cleaner for years and did have an old car that was so bad that the water was not only black, but smelled like a blue outhouse. A couple of drops of bleach took care of the smell. Anyone else experience this and what do people here in the forum use in their reservoirs?
    jackn7 and highriserkaiser like this.
  11. Sep 10, 2017 at 7:23 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Probably has a lot to do with how infrequently you use your washers. LOL If you use them to clean the windshield often the fluid doesn't stay in the container long enough to get moldy.
    Plus, washer fluid is cheap!
    jackn7 likes this.
  12. Sep 10, 2017 at 7:30 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    i use rainx washer fluid.. it works better than the cheap stuff. The rain beads up and rolls off.
    jackn7 likes this.
  13. Sep 10, 2017 at 7:31 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    As an aircraft mechanic...I've been asking that question for years, all while cursing the engineers that designed that damn things after busting my knuckles open
    jackn7 and TXpro4X4 like this.
  14. Sep 10, 2017 at 7:55 PM
    Bebop
    Nick
    As an auto mechanic/ aircraft mechanic/ motorcycle mechanic I've asked myself how engineers can be so damn stupid when they design this shit. I think they have office pools to see who can get the dumbest idea into production.
  15. Sep 10, 2017 at 10:36 PM
    wingspar
    Oregon
    Ever tried changing the oil filter on the rear engine of a C-337?
  16. Sep 10, 2017 at 10:37 PM
    wingspar
    Oregon
    Cause engineers do not work on them.
    jackn7 likes this.
  17. Sep 10, 2017 at 10:38 PM
    wingspar
    Oregon
    Gets used every time I drive the truck.
  18. Apr 26, 2023 at 5:24 PM
    wingspar
    Oregon
    Bringing this thread back up from frustration. I needed to replace the headlight on the passenger side and the washer reservoir has turned black from mold again, so I decided to remove the reservoir to make it easier to get to the headlight. Stupidity from not looking at this thread before starting, I totally destroyed the reservoir motor (I won’t go into how I did it) and was forced to buy a new reservoir and motor. Got it all installed, filled up and working. Next morning the entire reservoir was bone dry. Now I’m trying to remove that pigtail as described in post #8 in this thread, but nothing I try will let me disconnect that stupid pigtail. I don’t remember having problems disconnecting the pigtail last time I did this, but nothing I try works. My finger can’t take it anymore. Any tips in disconnecting that pigtail?
  19. Apr 26, 2023 at 5:34 PM
    RockfordTaco2006
    RockfordTaco2006 Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    I like to use a small flat head screw driver or a small pick. Sometimes you can get the pick to release the latch on some designs. Wiggle it while you press the tab works it the winning technique. Good Luck!
  20. Apr 26, 2023 at 6:51 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Engineers are about as good at designing for maintainability as they are at writing legible sentences.
