How to remove adhesives (rain guards)
Discussion in 'Detailing' started by danteisme, Jun 14, 2016.
  1. Jun 14, 2016 at 6:40 AM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    I think this might be the right place for this. my window rain guards were pretty cracked up on the truck i'm selling soon. so i figured i would just remove them. i got most of the glue and adhesive strip off. i used a plastic scraper and goo gone. whats the best way to remove the rest of this stuff? its a little thicker on the driver's side due to the original owner's poor placement of the rain guard...
    FCF4BB3A-5AAA-4205-8B6F-81590CF0A6D9_zps_add3ba3525de5b473330df638136a6b053b053bc.jpg
    AE0E738F-31CC-4862-8AD7-412F9C33A376_zps_f4cd412439dfb921bf0190b9755f7e79126831a5.jpg
  2. Jun 14, 2016 at 12:50 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    You could try some isopropyl alcohol (IPA). When I use it for sap/adhesives on my truck, I pre-soak a small patch of a rag with IPA and have a second towel soaked in water.
    Wipe/soak a few seconds with the alcohol soaked rag, then immediately wipe it off with the wet towel. Repeat. It may take some time- I just don't like to let the IPA dwell on the paint. It shouldn't do damage unless it dwells (i.e. Don't let it get underneath any rubber trim where it can sit on the paint for an extended period).
  3. Jul 22, 2016 at 7:07 AM
    Para8291
    Para8291 Well-Known Member
    Rob
    San Antonio
    2016 Tacoma TRD Sport
    Bilstein 5100s all around, Toyo All Terrain AT II 285/70/17, Custom Car Grill, front windows tinted at 35%, door still protectors, bed Matt, tail gate lettering, center console organizer and detailed with Adam's Polishes products
    3M Adhesive Remover and elbow grease. Once you get it off you will proably have some ghosting. You'll then to buff that out with a polisher to get it all off. Hope that helps.
    NAAC3TACO likes this.
  4. Jul 22, 2016 at 7:14 AM
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    Best easiest qnd cheapest thing i have found, i used to do alot of decals, is using hot water and joy dishwashing liquid. Get a squirt bottle and fill it about 3/4 the way up with hot tap water, then put about a teaspoon of joy dishwaasing liquid in ut. Just plain lemon liquid, nothing fruity or fancy, then stir it up a little bit. Ssquirt it on smaller sections at a time, let it set a minute, saturate it pretty good, then wipe it away, take a little lbow grease but does a good job. Then when your done, just wipe it clean with a dry cloth, and maybe throw a little wax on there, and it will look good as new. Joy will do wonders washing a vehicle, but you can't use it alot, because it can and will damage the clearcoat on the vehicle. Always throw a really good coat of wax on it when you get done as well. Works wonders on tar and really hard bugs as well. I usually wash my vehicles at least once every two years in it. Just helps get any gritty stuck on residue off. Hopefully this helps you out!!
  5. Jul 22, 2016 at 7:16 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    We use this product daily at the dealership I work at. It doesn't hurt the paint and does a great job.
  6. Jul 22, 2016 at 7:19 AM
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    3M Adhesive Remover is what I use.
  7. Jul 29, 2016 at 7:48 PM
    killerken
    killerken Well-Known Member
    Philadelphia
    09 toyota tacoma dbl cab trd
    Access LE Cover Toyota Factory Nerf Bars Dynolock Tail Gate Lock
    The best adhesive remover is WD-40
  8. Jul 29, 2016 at 7:58 PM
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    WD-40 does work great
