How to relieve fuel pressure in 2.7 for fuel pressure regulator replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Layzboy, Sep 2, 2021.
  1. Sep 2, 2021 at 10:41 AM
    Layzboy
    Layzboy [OP] Well-Known Member
    Rob
    Glendale,AZ
    99 Rerunner TRD Off Road Sunfire Red Pearl
    Just gettin started
    How do you relieve fuel pressure in line to replace fuel pressure regulator?
  2. Sep 4, 2021 at 11:31 AM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    Vehicle will start it will idle and then all the sudden it just wants to die. I tried to post videos but I can't for some reason
  3. Sep 4, 2021 at 12:12 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Just undo the banjo bolt for the fuel rail and fuel will come spilling out and the pressure is relieved.
    Bivouac and Layzboy[OP] like this.
  4. Sep 5, 2021 at 5:06 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    What makes you think it is the fuel pressure regulator?? Is it leaking ??
    Unless things changed all that does is take the sharp spikes and smooth them out.
    Already changed the filter ??
  5. Sep 5, 2021 at 6:43 PM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    It was just a hunch and it's easy to get to fuel pump has been changed fuel filter has been changed. I'm starting to think it's shitty gas from the truck sitting for a while.
  6. Sep 6, 2021 at 8:16 AM
    Bivouac
    Not getting any codes at all??
    You have checked that the injectors are indeed firing ??
    Electric side of fuel pump working ?? It almost sounds like your pump is energized when cranking but drops out on the run side of the circuit opening relay unless your getting one of the codes that shuts off the fuel.
    best of luck
  7. Sep 6, 2021 at 11:41 AM
    Layzboy
    Rob
    Glendale,AZ
    Just gettin started
    No Codes. Fuel pump is only about a year and a half old as is the fuel filter. Have No Clue how to Check injectors. Just starting to figure this out.
  8. Sep 6, 2021 at 4:58 PM
    coff33
    coff33 Well-Known Member
    5vzfe manual
    i think by pulling the fuel pump fuse and cranking the engine
