How to rekey door locks
Discussion in '1st Gen. Tacomas (1995-2004)' started by koenbro, Feb 9, 2025.
  1. Feb 9, 2025 at 9:31 AM
    koenbro
    koenbro [OP] Well-Known Member
    Phoenix, AZ
    2001 Tacoma SR5 Xtended cab 3.4L 5Spd
    I am replacing the ignition lock cylinder (with an OEM replacement) and would like to use the same new key for the door locks and the airbag on-off switch in the dash. How could I do that/ Will a locksmith be able to do it? Thanks for any advice.
  2. Feb 9, 2025 at 9:50 AM
    02hilux
    Planet: EARTH
    Locksmith. Will be cheaper of you bring the lock cylinder up then to change. It will cost more of they perform the entire work
    ABA180 and koenbro[OP] like this.
  3. Feb 9, 2025 at 10:21 AM
    koenbro
    Phoenix, AZ
    Great suggestion. I did remove the liner of the driver door recently, then removed the whole mechanism to clean the latch so I might remember how to do it; if not there was a useful YT video. That gave my door handle/latch a second wind.
    Will remove both door cylinders and the airbag one and have them rekeyed.
    Will wait for the cylinder to arrive from Camelbck Toyota first.
    Thanks man!
  4. Feb 9, 2025 at 10:27 AM
    koenbro
    Phoenix, AZ
    BTW there are videos online claiming that the door mechanism is poorly designed and you should replace it due to age. Mine refused to open at some point with the outside handle (would open OK from the inside).
    But after I cleaned it it works well, and I did not replace the outside door handle as there was nothing visibly broken or worn on it.
    The passenger side of course is far less affected.
  5. Feb 9, 2025 at 10:40 AM
    02hilux
    Planet: EARTH
  6. Feb 9, 2025 at 10:41 AM
    02hilux
    Planet: EARTH
  7. Feb 9, 2025 at 10:56 AM
    koenbro
    Phoenix, AZ
    Does Toyota sell new door cylinders? Wondering if I shd replace those as well. Thanks for the handle recommendation btw, have ordered them.
  8. Feb 9, 2025 at 11:02 AM
    02hilux
    Planet: EARTH
    I’m not sure. Mine still work fine from 2002. Just ask the locksmith to clean and oil them during reassembly.
    i wouldn’t replace what’s not broken
  9. Feb 9, 2025 at 11:17 AM
    CenCalWheeler
    CenCalWheeler Well-Known Member
    2003 Toyota Tacoma TRD
    None yet
    I wonder if these are any more difficult than rekeying locks for your home. I know that they're double-sided but it's not hard to rekey things yourself if you look online and you get the equipment to do it. Honestly cheaper to do it yourself even buying the equipment for a one-time job.
    I re-keyed five locks in my home never having done it before and I was able to do it and a long afternoon. Actually enjoyed it... I'm sure it's a similar procedure for cars.
  10. Feb 9, 2025 at 11:36 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    They can be rekeyed at home, but you have to be patient with it. If you take them out and take them to the locksmith the price is usually pretty reasonable.
  11. Feb 9, 2025 at 11:51 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I had one rekeyed for my wife's old Rav4, $20 well spent and a fast job for them.
    koenbro[OP] likes this.
  12. Feb 9, 2025 at 11:09 PM
    CenCalWheeler
    None yet
    That is not a bad price..
  13. Feb 10, 2025 at 11:38 AM
    ABA180
    East Bridgewater MA
    I brought the new cylinder and old key in on Friday about 4:30, picked it up the next day before noon. Took it home, swapped it out, replaced the window switch panel in the process. Done and done.
    That vehicle didn't have a fob so she had to unlock from the passenger side, then walk around to get in the driver's side. A bit of a pain.
  14. Feb 10, 2025 at 12:34 PM
    Capt Pie
    Capt Pie Well-Known Member
    sacramento
    sr5 V6 4WD
    yes they do. I did mine a few months ago. Had new lock cylinder keyed to the same as the rest of the car
