How-to: Rebooting a Tacoma CV Axle
Discussion in '1st Gen. Tacomas (1995-2004)' started by turbodb, Apr 15, 2019.
  1. Apr 24, 2019 at 8:22 AM
    tyjoja
    tyjoja Well-Known Member
    Oregon
    2008 off road trd, Rugged Trail
    lift
    thanks again turbodb... if my boots slip again i will definitely try the moog clamps
    turbodb[OP] likes this.
  2. Apr 24, 2019 at 10:11 AM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I had one factory shaft blow a boot after about 8-9 years and swapped it with a Napa. Still running that Napa shaft after ~10 years now. My other OEM shaft lasted about 16 years. I replaced it last year with another Napa. For the price the Napa shafts are hard to beat.
    rpdorgan[QUOTED] likes this.
  3. Jul 3, 2019 at 5:40 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    @turbodb Hey dan, Zane (@Speedytech7 ) sent me to your write up for a reboot on a 4wd axle. I was very well documented as there is not one. I assumed the axles would be the same from 1st to 2nd gen and they basically are. The only thing i would like to point out incase another second gen person is in here looking at doing the reboot is that once you have the differential side tulip off and you are removing the 3 bearing head there is only one clamp ring which is does not require the snap ring tool you used on yours. Also once thats remove you then have to use some sort of punch/chisel/large screw driver and 4lb hammer and pound off the 3 bearing head, i couldnt find that detail anywhere and sat looking for awhile thats why im sharing it. Then you reboot and pound it back on, i used a 32mm socket which reseated it then put the snap ring back on.
    I used a pick to remove the top clamp ring. Then i used a flat air chisel hammer bit and 4lb sledge to pound off the 3 bearing head, pounding on the collar and not the 3 knobs where the bearings mount.
    Hope this helps anyone else.
    Dan your write up is killer for 1st gens and ALMOST was perfect for second gens if they had not changed it a tiny little bit.
    Now you have all the info incase you need to upgrade to a 2nd gen!
  4. Jul 3, 2019 at 9:38 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    :rofl:
  5. Sep 23, 2024 at 3:21 AM
    mk5
    mk5 Probably wrong about this
    SoCal
    '05 access cab 4x4
    Fucking god dammit, Dan, I read this whole thing, then nonchalantly popped the tripod off my axle and dropped it on the floor, without indexing anything to anything else. I don't even know which way was up!
    Popped 5 boots this year -- getting sick of paying for reman axles. So... here's to the sixth, when this one inevitably explodes because I installed the bearings twelve degrees off and upside down. At least I didn't pay $300 this time.
    Pretty sure it fit like this, right?
    This is entirely your fault.
  6. Nov 26, 2024 at 3:44 AM
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    What clamps is everyone using now?
    The linked clamps see to be no longer available.
  7. Nov 26, 2024 at 8:22 AM
    turbodb
    turbodb [OP] AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Drainbung likes this.
  8. Jan 11, 2025 at 5:45 AM
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    Question on these clamps.
    If you do the boot slide mod with current boots and just cutting off clamp and sliding boot 3/8 inch will these clamps hold or will the worm type be better.
    I can see rebooting and keeping a peice of old boot clamped in grove with boot clamped again after that it wouldn’t take much because the old clamp in the groove.
    I may reboot in the future if needed.
  9. Jan 11, 2025 at 8:42 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    These clamps work just fine with the boot slide mod.
    Note, however: I am not a fan of the boot slide mod, as it puts additional strain on the boots by stretching them beyond their intended position. People like this mod because it makes it so the fins don't rub, but in my opinion, it puts even more strain on the rubber. The right way to make your CV boots last longer is to run a lift that results in reasonable CV angles. Anything in the 2.75" or under and you're fine. More than that and your CV boots are the least of your problems anyway, since the extremely high resting height will mean very little downtravel, poor ride quality, and a higher likelihood of significant strain - to the point of cracking - on the shock tower.
  10. Jan 11, 2025 at 8:54 AM
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    Mine is 2.25 with 6112s and ribs are touching some.
  11. Jan 11, 2025 at 8:57 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Post up a pic of your CV angle. Generally, I'd ask:
    1. Are you sure you're at a 2.25 inch lift? (and how did you verify this number)
    2. Are you having issues with eating through boots? (having them touch isn't necessarily bad)
  12. Jan 11, 2025 at 9:26 AM
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    I’m probably just overthinking it,being proactive.
    The driver isn’t touching but the passenger is touching just a little bit .
    turbodb[OP] and Drainbung like this.
  13. Jan 11, 2025 at 10:53 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    I'd run that as is. Angles don't look too bad (though I wouldn't add more lift...not that you were going to.) You'll put more stress on those boots by stretching them IMO.
  14. Jan 11, 2025 at 10:54 AM
    Coopsdaddy
    Quinton
    2012 dclb tacoma
