How to properly level my 02 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by slowa617, Jan 25, 2017.
  1. Jan 25, 2017 at 2:35 PM
    slowa617
    slowa617 [OP] New Member
    Hi all, I have an 02 SR5 4wd Tacoma 3.7 liter V6 6 lug that is currently leveled with 2.5" blocks underneath my front coils. I've gone through 3 CV axels in the past 8 years, for which I'm blaming the leveling blocks.
    I'm looking at putting Bilstein 5100's set to the level setting and replacing my coils with new OEM coils the same size as my stock ones. Maybe eventually springing for Bilstein 5100s in the back. Any input or advice on the best way to level out my tacoma and clear 32" tires would be appreciated.
  2. Jan 25, 2017 at 11:48 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    for 32s you can get away with 1.5 to 2 inches depending on your wheels... with stock wheels, you may have some minimal rub at full articulation or on bumps and driveways with wheels turned, but it should help save the CVs...
    a wheel with 4.25" or 4" backspace should alleviate everything with 1.5 to 1.75 inch lift
  3. Jan 25, 2017 at 11:57 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Toyota only had 3 engine options for 1st gen tacomas. None were 3.7 liters.
    881 coils in the front and a toytech aal in the rear. Nitrocharger shocks on the corners.
    You'll be golden.
  4. Jan 26, 2017 at 2:31 AM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    Take out the blocks and put a 3-4 inch body lift in :headbang:
    Sorry I had to... 5100's at middle setting plus an AAL is what I'm planning on doing. Plus maybe a little trim/hammer :sawzall:
  5. Jan 26, 2017 at 3:32 AM
    ekul310
    ekul310 Well-Known Member
    Luke
    Pennsylvania
    2002 Lunar Mist Regular Cab 4x4
    Stock stock stock
    I've got 32x11.5 BFGs on my stock truck. Just trim some plastic, flatten the pinch weld, and get some flush mount fasteners for the inner fender. Also have black pro comp steelies with I think 4" BS. Mine will rarely rub. Mostly when flexed and backing up and turning.
  6. Jan 27, 2017 at 8:46 AM
    slowa617
    My bad, meant to type 3.4 liters.
    I'm probably going with bilstein 5100's all the way around with the ride height adjustables set to the 1.25" setting in the front, new stock coils in the front and spydertrax 1.25" spacers. Going to stick with my fairly new 275/65/R16s.
    Do I need anything additional in the back in order to replace the stock shocks with the 5100's? If I went for the 2.5" setting in the front I know I'd probably need to aal in the back, but since I'm just leveling it out I'm reading that new stock coils in the front will be fine...not so sure about the back though...
    My current suspension is stock (minus the blocks under my front springs which I hate) and has 178K on it. This is my daily driver and I'm never off road...FYI.
  7. Jan 27, 2017 at 12:09 PM
    SouthernYoder
    SouthernYoder If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    I don't think you should need anything in the rear since your leveling it out. Once tax returns hit I'm doing exactly what your doing, leveling it out with 5100 all around. Mine has only 121k tho
  8. Jan 27, 2017 at 12:12 PM
    SouthernYoder
    Knoxvegas, TN
    People will also recommend you to get the drop diff bracket too when it's not really needed unless you just up to 2.5+
  9. Apr 5, 2021 at 4:37 PM
    GenYota’03
    GenYota’03 Member
    2003 Tacoma 4x4 V6
    I know this thread is 3 years old, but I’m curious what you ended up doing on your yota. I have an ‘02 that I’d like to level. My question is how much of a lift do you put on the front bilsteins to level the truck if it is stock?
  10. Apr 5, 2021 at 7:11 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    You can get away with 2-2.5 before you kill cv boots on the regular. Manual hubs will cure it
  11. Apr 5, 2021 at 7:23 PM
    GenYota’03
    GenYota’03 Member
    2003 Tacoma 4x4 V6
    Im not interested in really lifting the pickup, but I would like to level the front to the back. I was just curious if anyone knew what level of lift that would be on a stock pickup. I don’t want the front to be higher than the back either so I was just hoping to find out if 2” levels from stock or 1.5” or what.
