How to Make Your Hood Scoop Actually Work! A How-To!
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by canyonchaser, Jul 15, 2011.
  1. Jul 15, 2011 at 4:58 PM
    canyonchaser
    canyonchaser [OP] Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    Okay, saw lots of people say how easy it was, but atypical to the internet, nobody was "showing" how easy it is.
    So I just did this over the last couple of hours, including a trip to the Home Despot for the proper size rivets for reassembly... So here-goes...
    Here is the hood scoop in stock form. Pretty, but does nothing but catch and hold bugs and dirt. Neat. Yes?
    First step is to remove the scoop from the hood. This involves five bolts and a Philips head screw.
    This makes the hood of your truck look like this. Sure, it'll flow a lot of air, but it's quite unsightly and I suspect it'll also be really good at capturing birds and small dogs as you drive along.
    (note: do not lose the white clip you see here. It goes to the single Philips screw head.)
    This is the scoop out of the truck. It comes out by lifting up on the leading edge then sliding it gently towards the front of the truck.
    This is the back side. Fairly unimpressive.
    The plastic "bowl" is used to sandwich the metal mesh between it and the painted cowling. Three black aluminum rivets hold the whole assembly together.
    To separate everything, start by drilling out the three aluminum rivets. Be very careful to not let the chuck of your drill snag on the delicate painted lip of the cowling. This will ruin it and make your truck look nappy.
    Once all three rivets are drilled out, the internal black bits come out by sliding forward out of the scoop.
    I suppose you could stop here and simply re-insert the cowling and again, have massive air-flow with a slightly better look, but I wanted to maintain the OEM look and discourage the capture of too much water and rubbish. So I moved forth.
    I used a small screwdriver to carefully open the two-clips, then genltly wiggled the steel mesh away from the plastic backing.
    Where once there was one, there is now two! So exciting. I know!
    There are lots of ways to proceed at this point. Cut of the entire back of the plastic, lots of tiny little holes, laser etching of micky mouse, Red LED Cylon Eye with sound effects... I chose the simpler "big-hole" idea.
    I measured as close as I could to the center of each "cell" in the plastic bowl and used a sharp awl to mark the center. Then I used the largest drill bit that would work for all "cells" and, by hand, cut the holes into the plastic.
    Why didn't I use a drill? you ask. Well, thats a very good question. This type of soft plastic can catch and tear, like the grain in wood, causing the hole to creep or tear into an oval. The plastic is super-soft, so cutting it by hand allowed me to be more precise.
    I had planned to stop here, but I threw caution to the wind and ended up cutting two more holes before reassembly.
    I also took a nice file and cleaned up the holes a little bit, just for good measure.
    The whole assembly just snaps back together.
    The dogs, Sprocket and Jake, watched on in eager anticipation... Oh, the excitement of it all!
    I ran to the Home Depot because I didn't have the correct size rivets (5mm/7mm), but I couldn't stand the thought of silver colored rivets, so I sprayed them black.
    Then I re-riveted the three rivets using a small washer under the head of the rivet for extra measure and strength
    If you look closely, despite all my efforts, the hole on the far left did creep a bit and is slightly lower than the rest. I hope I can live with the asymmetry...
    Time for reassembly; This plastic bit sits on top of this. It's keyed so it really only fits one way.
    Like this
    There is also a small rubber bushing that sits top-center on the metal hood. Don't loose or forget this either.
    Now for the hardest part.... Putting it back together. Close the hood, but not all the way, then slide the hood scoop back into place. If you push down on the leading edge, it'll snap into place nicely, but DON'T DO THIS!!! Just set the scoop in place.
    Open the hood again, and carefully put the phylips screw into place and just get it started, don't tighten it. Close the hood again. Now, you can snap the scoop back into place.
    Open the hood again and tighten all the fasteners, careful not to over-tighten anything since the entire assembly is just plastic.
    In case you forgot, these are where all the nuts and screw goes.
    Ta Da! All back together and it looks --- well, just like it did before we started.... *sigh*
    With this mod you can expect a cooler running engine, better acceleration, a crisper throttle response and a slight increase in torque and towing capacity. You can expect all of these things plus much more... However, none of them will actually come true, despite your greatest expectations.
    But now, when your friends ask "Does that hood-scoop do anything?" You can stand up tall, puff your chest out and say with pride - "Yes! It does now!"
    Also, I did some calculations and to the best that I can figure, allowing air to flow through the hood scoop should save 0.3848 gallons of fuel over the life of the truck. Take that Priius!
    dp
  2. Jul 15, 2011 at 5:00 PM
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
    Can't tell...if...joking......:confused:
  3. Jul 15, 2011 at 5:02 PM
    rcfreak201
    rcfreak201 Well-Known Member
    cant you drill the holes without removing the block from the mesh?
  4. Jul 15, 2011 at 5:02 PM
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
  5. Jul 15, 2011 at 5:02 PM
    ColoradoTaco
    ColoradoTaco Well-Known Member
    Boulder
    2013 DCSB OFFROAD
    If you have nothing to do this is a great mod to perform cause its better than doin nothin'
  6. Jul 15, 2011 at 5:08 PM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    could you not remove the plastic piece all together since the holes that the rivets go through are in the metal also?
  7. Jul 15, 2011 at 5:11 PM
    rcfreak201
    couldnt you just plasti dip your mesh and make it work?
  8. Jul 15, 2011 at 5:12 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    From someone who has done this, it just makes your engine dirtier.
  9. Jul 15, 2011 at 5:17 PM
    canyonchaser
    Dave
    Utah
    LR TRD PRO MT
    Yes, joking a lot actually. You could remove all the guts and have lots of air come in. But lots of other things would come in too, I suspect.
    I figure the blunt nose of the Toyota would make it so air is only really going to go through the scoop at relatively slow speeds. And I figure I can always block them off at a later date. No big deal.
    dp
  10. Jul 15, 2011 at 5:28 PM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    Why?! Looks like a waste of time
  11. Jul 15, 2011 at 5:38 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    only if you have something else to do! If not, its a perfect waste of time
  12. Jul 15, 2011 at 5:53 PM
    ecupcar
    ecupcar Well-Known Member
    20 miles south of nowhere
    09 Tacoma and 99 4Runner Limited
    Leer color match cap, prodigy break controller, Thule rack, window tint, bed mat and bug deflector
    Puff your chest out and be proud. I too have the scoop and face the know it alls that ask if it's functional. And now yours is!
  13. Jul 15, 2011 at 5:54 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    skewpz iz srs biznazz
  14. Jul 15, 2011 at 5:56 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
  15. Jul 15, 2011 at 5:57 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    Why is this in the for sale section?
  16. Jul 15, 2011 at 5:59 PM
    NelsonTacoma
    Tucson, AZ
    Maybe he'll do your scoop for a small fee? :notsure:
  17. Jul 15, 2011 at 6:03 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Still not functional :rolleyes:
  18. Jul 15, 2011 at 6:08 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    "With this mod you can expect a cooler running engine, better acceleration, a crisper throttle response and a slight increase in torque and towing capacity. You can expect all of these things plus much more... However, none of them will actually come true, despite your greatest expectations.
    Also, I did some calculations and to the best that I can figure, allowing air to flow through the hood scoop should save 0.3848 gallons of fuel over the life of the truck. Take that Priius!"
    THIS IS JUST TOO RICH! LOL
    Thanks for the good laugh... and at least you hood scoop isn't fake!
    Now, do you have a mod to make it disappear so you can have more visibility?
  19. Jul 15, 2011 at 6:20 PM
    JKD
    JKD Well-Known Member
    Needs knight-rider lights.
  20. Jul 15, 2011 at 6:23 PM
    paintdiddy
    shithead
    silver bullet
    Maybe if I still had a taco with a scoop :(
