How to make smoother off road
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sean42, Apr 26, 2022.
  1. Apr 26, 2022 at 8:58 AM
    Sean42
    Sean42 [OP] Well-Known Member
    I am looking to make my 2011 single cab into more of a dedicated off road truck. It's spent its whole life commuting on highway tires and now has 246,000 miles. The truck drives great on pavement no issues whatsoever. Problem is when it gets off-road it just seems to be a rough ride to me and I don't like it. It's riding on take off struts from a 3rd gen TRD-Offroad, brand new OEM 4 leaf pack and brand new Bilstein 4600's.
    I am really feeling the bumps in the road in the steering wheel on rough terrain. It's like every rough bump comes right through the steering wheel. I am not used to that and it makes driving off-road not fun. I had the intermediate steering shaft fixed so there is absolutely no play on smooth roads and it's all tight and good. Is there some kind of bushing or part of my steering component that may be causing this?
  2. Apr 26, 2022 at 9:11 AM
    A-Train
    A-Train Well-Known Member
    What tires and tire pressures are you running?
    ImMrCrash, b_r_o and winkel like this.
  3. Apr 26, 2022 at 9:14 AM
    Sean42
    30-32 PSI.
  4. Apr 26, 2022 at 9:19 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    That’s good for the road but off road you’ll want to lower them
  5. Apr 26, 2022 at 9:20 AM
    A-Train
    That'll do it. You need to invest in a portable air compressor so you can air down. I've got an 11 reg cab also, my 285/75s are E load rating which are stiff, but I bring them down to 15-17psi off road.
  6. Apr 26, 2022 at 9:23 AM
    A-Train
  7. Apr 26, 2022 at 9:24 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    with my E rated Stmaxx I usually bring them down to 12 psi on trails. Never had an issue with it. 30+ psi with those off-road would be torture
    treyus30 likes this.
  8. Apr 26, 2022 at 9:27 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Rough ride usually means you're going too fast.... or too slow. :D
  9. Apr 26, 2022 at 9:29 AM
    A-Train
    Ya my truck feels like it's going to rattle itself apart at 30+psi
    OilCapital2021 likes this.
  10. Apr 26, 2022 at 9:32 AM
    Sean42
    I'll definitely air down. It's normal to feel the steering wheel shake over bumps and dips? In my other cars I feel like nothing comes through.
  11. Apr 26, 2022 at 9:34 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    15-18psi, get rid of front sway bar
  12. Apr 26, 2022 at 9:36 AM
    A-Train
    By shaking do you mean the whole wheel is vibrating in your hands? Up, down, with some left and right? I get this at 30psi for sure.
    If it's strictly left to right you could investigate some other steering components like inner and outer tie-rods. I would first take it out aired down to 12-17 depending on your tire load and experience that before going down a rabbit hole.
  13. Apr 26, 2022 at 9:40 AM
    A-Train
    Ya I second the sway bar removal if you plan on making it more dedicated to off road. I had mine off for a year or so but ended up putting it back on, it didn't feel safe if I had to make an emergency maneuver at 75mph with a 350lb camper shell. It was MUCH nicer off road though.
    Alexely999[QUOTED] likes this.
  14. Apr 26, 2022 at 9:55 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    There’s for sure more body roll without it. But less so with stiffer springs. I daily drive mine with no sway bar, tow trailers, etc and haven’t had any issues. But yes there’s more potential for issues.
  15. Apr 26, 2022 at 10:18 AM
    Sean42
    I’m going to remove the sway bar and excited for the results.
    Alexely999 likes this.
  16. Apr 26, 2022 at 10:29 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    4 link in the rear +2 long travel in the front, and go fast.
  17. Apr 26, 2022 at 7:42 PM
    A-Train
    I’d still air down. For comfort I’d much rather be at 15 psi with a sway bar on than 30+psi with no sway bar. Both would be best.
    Alexely999 and cryptolime like this.
  18. Apr 26, 2022 at 7:57 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Even 20-22 psi would be a vastly better feel offroad
  19. Apr 26, 2022 at 8:06 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    how many miles ago did you replace the struts?
  20. Apr 26, 2022 at 9:13 PM
    007fodo
    007fodo Gold Member
    Ian
    Coastal North Central CA
    4X4 V6 5AT DCSB 07
    3rd gen coilovers/struts were too stiff for me in my double cab v6...
