How to make audio default to USB?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Edslittleworld, Feb 12, 2023.
  1. Feb 12, 2023 at 4:46 AM
    Edslittleworld
    Edslittleworld [OP] Well-Known Member
    Tucson
    2011 Tacoma TRD/OR (6MT)
    None
    Every time I get in my Taco, the audio defaults to FM Radio. So, I have to jump thru several screens every time to get to USB. Is there a default setting that can make USB the default every time I start up the audio?
  2. Feb 12, 2023 at 8:31 AM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    For me, if I am using the USB port to play music and shut the truck off, when I start the truck, it resumes where it left off.
    Scotty61 and DES2009 like this.
  3. Feb 13, 2023 at 4:46 AM
    OldMattB
    OldMattB Active Member
    Mine defaults to no source selected. I had hoped that reordering the sources would solve this.
    Hoping we find an answer. Last year, I ripped all of my favorite CDs in WAV to a portable player and USB drives. It is nice listening to music of my own choice!
  4. Feb 13, 2023 at 4:48 AM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    In order to have it default to USB, it needs to be the last thing selected before shutoff, and there needs to be something plugged in and powered up when you start the truck. If nothing is connected, it won't consider the USB input at all.
    DES2009 likes this.
  5. Feb 13, 2023 at 5:10 AM
    OldMattB
    The USB is the source I was using when I shut the truck off. When you say something needs to be plugged in and powered up, does this mean that the audio system will start from the USB input for a player, but not a USB drive?
  6. Feb 13, 2023 at 5:14 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Mine always starts with USB. I keep all my music on a flash drive that always stays plugged into the USB port. Songs pick up just where they left off when I shut the truck off. I don't turn off the radio before turning off the truck.
  7. Feb 13, 2023 at 5:40 AM
    Yes.
  8. Feb 13, 2023 at 5:56 AM
    OldMattB
    Could the difference be with how the files on the USB are formatted? MP3 vs. WAV? iTunes? Etc?
  9. Feb 13, 2023 at 6:03 AM
    dangeroso
    Jon
    Dallas, TX
    No, it should should work with a drive. Are you using a flash drive that is at least UBS 2.0? Speed of drive reading might be a factor.
  10. Feb 13, 2023 at 6:26 AM
    OldMattB
  11. Feb 13, 2023 at 6:32 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
  12. Feb 13, 2023 at 6:34 AM
    dangeroso
    Jon
    Dallas, TX
  13. Feb 13, 2023 at 6:37 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
  14. Feb 13, 2023 at 7:17 AM
    OldMattB
    I have a 2020. I checked the USB drive - I have 183 gigs on it, 6,058 files. Given what the manual quote says (thanks!), it may be the difference between MP3 and WAV that prevents my system from starting up automatically.
    EDIT: I tried it with a USB drive with MP3s, and it started automatically. At least in my case, it seems to be an issue of WAV vs MP3.
    DES2009[QUOTED] and dangeroso like this.
  15. Feb 13, 2023 at 7:28 AM
    RagingZenDog
    RagingZenDog so many questions....
    Jeff
    2023 SR5 DCLB
    Plain old SR5, for now
    I'm the same way with FLAC files... Does not remember the source (USB) but once chosen DOES remember exactly where it was mid-song when shut off. Drives me a little crazy.
