How to Make a Bed For Your Bed! DIY Camping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by High-Gear, Jun 20, 2010.
  1. Jun 20, 2010 at 7:19 AM
    High-Gear
    High-Gear [OP] Zombie Killer
    Newton, KS
    09 TRD Off Road
    TRD Supercharger, TRD Cat Back Exhaust, DR / Icon 2.5 Coilovers, Camburg UCA, TSB with AAL, Walker Evans 2.0 reservoir rear shocks, ARB Bull Bar, Smittybilt 10K Comp Winch, ARE Camper Shell, Con-Ferr Safari Rack, 4 KC Highlights on rack, 2 KC Rallye 800 on Bumper Armortech Off Road plate rear bumper. Firestone Airbags in rear, with Firestone compressor.
    The wife and I are about to embark on our first 10 day overland exploration trip. We will be living out of the Taco as we explore 10 states and Ontario Canada. I had looked into Airbedz, and Truck Bedz, but ha a hard time justifying $165 for an air mattress which we could only use in the bed of the truck. I tried to find an air mattress which would fit, but either they were too small or too large to fit in the bed. Then I came up with this solution….Cost $0!
    I went to a local business which manufactures foam. They make all types of densities and sizes. I spoke to one of the floor supervisors and explained to him what I needed, and he told me to give him a few weeks and he was sure they would have a cut off end or other piece of scrap which would work. I did not have high hopes on this scrap, but I though I’d give it a try.
    A week later I got a call to come and pick up my foam, and to my surprise there was a 3” thick piece of black foam waidint for me, cut to 52” x 60”. This type of foam is about the same density as the foam that comes in Pelican cases and will be perfect to sleep on!
    Here are step by step instructions on how to measure, cut, and make a case for your own foam Truck Bed!
    1) I used a piece of cardboard to make a template. I measured the offset of the wheel well, then transferred the measurements to the cardboard. I cut it out and double checked the fit in the truck.
    2) I laid the foam out on the living room floor, and placed the stencil on top. Unfortunately I did not have a silver sharpie to trace the stencil, so I used a razor blade to lightly score the foam.
    4) ***Warning *** If your wife is not cool, do not attempt this step while she is at home
    Next I used the wife’s electric carving knife to cut the foam. I have used this before to make custom cutouts for rifle cases and it works great. The trick is to let the knife do the work and slowly glide it through te foam. Do not push the knife through.
    Here is a test fit:
    Save the cut off ends, as I was able to cut them down, and put them into the pillow cases, sew around them to make them tight and wound up with two camp pillows for free!
    5) I wanted to make a slip cover for the bed so I took an old queen sized sheet set and laid it on the floor . I used a marker to trace around the foam, leaving approximately a 3” space all the way around the foam. I repeated this on both the fitted sheet and top sheet, then cut them out with scissors.
    6) Now a Tailor I am not, but I turned the top sides of the sheets against each other and sewed two seams around the perimeter, leaving the wide end open. When this was finished, I turned the sheets inside out, and put the foam inside. I then sewed the last end of the slip cover closed.
    7) Here is the finished product with pillows!
  2. Jun 20, 2010 at 7:21 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Now it's a shaggin' wagon!!!:D
    nice job!
  3. Jun 20, 2010 at 7:25 AM
    4X4 aggie '13
    4X4 aggie '13 Well-Known Member
    College Station, TX
    09 4x4 TRD OR
    3" toytec spacer lift, n-fab steps
    Very nice! I also found that a twin bed mattress fits right between the two wheel wells, but fitting two people in a twin isn't fun. Why don't you just use two regular pillows?
  4. Jun 20, 2010 at 7:28 AM
    High-Gear
    Newton, KS
    09 TRD Off Road
    Because I didn't MAKE our normal pillows! :D
    Just kidding! We will take our regular pillows to sleep on, but these smaller ones I thought we'd use around the camp where they might get knocked in the dirt that way we don't have to sleep on dirty pillows. Just handy to have to prop your feet up and such. I threw them in for the photo.
  5. Jun 20, 2010 at 7:29 AM
    swervin22
    swervin22 "Obviously, You're not a Golfer..."
    Jonas
    Chesapeake
    2004 Radiant Red Access Cab Off Road
    Did you lay on it yet? How comfy was it? Could prolly get some egg crate foam for the top of that for some extra padding, then roll it up when not in use. Either way, good job on the bed, and I hope it fits your needs!! Also, take lots of pictures of the journey!! Sounds like quite an awesome vacation!! Have fun!!
  6. Jun 20, 2010 at 7:31 AM
    High-Gear
    Newton, KS
    09 TRD Off Road
    We laid on it to test it out for firmness and space. It seems to work just fine but the true test will be how we feel at the end of the 10 days. We'll keep the egg crate foam in mind.
    I'll post a thread about the trip with pics when we return.
  7. Jun 20, 2010 at 7:32 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Dude thats bad ass! Good thinking on your part!!! Its looks amazing...in fact i'm getting sleepy just looking at it :thumbsup:
  8. Jun 20, 2010 at 7:35 AM
    JM76
    JM76 Ride On
    Jon
    SC
    2016 AC SR 4x4
    bone stock save for the block lift that came on it with the open country m/t.
    nice work! have you given it a test run as far as sleeping in it goes? Have fun on your trip and don't give those guys at the border a hard time eh? Feel free to drop my name just tell em Canada sent you!:D:D:D
  9. Jun 20, 2010 at 7:46 AM
    NAYo2002
    NAYo2002 Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    Great work! to sleep in a short bed though, you two must be short lol.
  10. Jun 20, 2010 at 7:56 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    nice work. i would have to double up the foam.
  11. Jun 20, 2010 at 8:03 AM
    el_smurfo
    el_smurfo Well-Known Member
    Yo Dawg...I heard you liked beds, so I put a bed in your bed.
  12. Jun 20, 2010 at 8:04 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    X2, a long bed wouldn't even fit me.
  13. Jun 20, 2010 at 8:06 AM
    Bullzi511Tacoma06
    Bullzi511Tacoma06 KCCO
    Southeast Louisiana
    2016 MGM Doublecab SR5
    Looks great. And you saved a good deal of money by making it yourself! Rep for you!
  14. Jun 20, 2010 at 8:13 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Nice work I like it, one thing for sure if you had a long bed you would be able to fit aero bed in that thing. Lids love the camping on the back and no need to for tent especially in rain.
  15. Jun 20, 2010 at 8:18 AM
    High-Gear
    Newton, KS
    09 TRD Off Road
    My wife is 5' nuttin'. Oh she'll tell you she is 5'2" but I wouldn't believe her!
    I'm 5'9 and sleep on my side with knees pulled up anyway so I think the short bed will work. We have a tent just in case, but I'm thinking positive!
  16. Jun 20, 2010 at 9:56 AM
    kenstar
    kenstar Get a Lil Mud on the Tares
    Ken
    Wrenching in the garage.
    10 4x4 TRD OR
    Pop 'n' Lock, EGR In-Chan, Bakflip G2, 6112, 5160, Dakar Set. Redline hood struts. WildPeak At3. TRD Pro Wheels. Apex Fab Fog lights; Other shit I can't remember.
    rofl. i like this. even busted out the sewing machine.
  17. Jun 20, 2010 at 4:37 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    This would be great for the Drive-in
  18. Jun 30, 2010 at 8:44 AM
    Trigger
    Trigger Well-Known Member
    LMAO. Pimp My Ride
    Great job btw man
  19. Jun 30, 2010 at 9:52 AM
    akdisney
    akdisney Well-Known Member
    Alan
    CA
    PreRunner SR5 V6
    Thule 422xt rack w/ XK1 rack adapter, uvw tool chest box, nerfBars
    Did you think of cut it threes or four, so you can fold it up.
    Like a Store foam mattress.
    this little more sewing
  20. Jun 30, 2010 at 10:45 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    :D Exactly what I was thinking
