How to make 12v ports have constant power?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AleutianTaco, Jun 5, 2023.
  1. Jun 5, 2023 at 3:03 PM
    AleutianTaco
    AleutianTaco [OP] Active Member
    2022 trd taco. Is there a simple way to make the 12v charging port (cigarette lighter) have constant power?
    ORtoCOTaco likes this.
  2. Jun 5, 2023 at 3:38 PM
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    Are you looking for the how to kill your battery hack? j/k
    Youd have to run the power from a different source than the one its on. The engine bay fuse box has several constant power points. Im not sure what in the cab fuse box is.
    But most would tell you thats a bad idea, or a good way to get stranded with a dead battery.
    Better to buy a solar generator type of power supply and power what you want to. That is what most of us are doing for a fridge, charger, etc.
  3. Jun 5, 2023 at 4:11 PM
    AleutianTaco
    My Fords all have constant power, never once came back to a dead battery. Leaving your phone or flashlight charging is not going to drain your vehicle battery.
    stu8319, SmoPo16 and ernscott like this.
  4. Jun 5, 2023 at 4:27 PM
    ernscott
    ernscott Well-Known Member
    2021 Tacoma
    Hi Sir I used this in the blank spot on the left side and just ran a wire into the engine compartment for my hot. Either direct to the battery or into the fuse box. Assuming your device will charge via USB
    https://www.amazon.com/gp/product/B01CFWIXPE?ie=UTF8
    SmoPo16 and ORtoCOTaco like this.
  5. Jun 5, 2023 at 4:34 PM
    spamy
    spamy Truck guy
    NorCal
    Cant compare fords to Toyota. Cmon, fords are real trucks.
  6. Jun 5, 2023 at 4:35 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    The way to do it is remove you 12v outlet, unplug it from the factory wiring, hardwire it directly to your battery with an inline fuse, and reinstall. Then you'll have always on outlets.
    Solar generator is way overkill for charging a phone. Hell I run my iceco fridge for 3 days without starting my truck or killing my battery (admittedly my 27f AGM is bigger than what comes in 3rd gens)
    Gdeyarmond likes this.
  7. Jun 7, 2023 at 4:29 AM
    caribe makaira
    Caribbean, Puerto Rico
    If your Taco doesn't have a sliding roof, that fuse in the cab is battery juiced. NO need to run wire to engine bay.
