How to line up shock mount and lower shock hole?
Discussion in 'Suspension' started by trdracing5, Nov 21, 2010.
  1. Nov 21, 2010 at 8:51 AM
    trdracing5
    trdracing5 [OP] Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    Does anyone know the trick to getting the studs in the top shock mount to line up exactly right with the lower shock hole? Want to make sure it is lined up correctly because I know it will be tough to fix once the coil is depressed.
  2. Nov 21, 2010 at 9:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I use a 9" long, 3/8" ratchet extension, inserted into the lower shock mounting hole, and with the shock loosly mounted at the top to the vehicle, turn the lower shock until it lines up with the lower shock mount.
  3. Nov 21, 2010 at 12:40 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    x2 and just to clarify this is after it's assembled. It's a little tough to twist it but by all means doable.
  4. Nov 21, 2010 at 1:29 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Mine were lined up pretty good when they were assembled, but still a bit off when I went to put them in...I used a large phillips screwdriver through the bottom hole, and gave them a little twist...worked great!
  5. Nov 21, 2010 at 1:47 PM
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    Exactly what I did. When the coils are assembled onto the struts, it's best to get the top studs lined up as close as possible with the axis of the lower mount hole +/- a few degrees. Then when you install the coilovers on the truck, hand tighten the 3 top stud nuts and do exactly what chris suggested with the ratchet extension to twist the lower strut body the final few degrees to get it lined up. Best to use something as smooth and large diameter as possible inside the lower shock hole so as not to damage the interior bushing sleeve. Definitely wouldn NOT want to use something knurled or a square shafted screwdriver :p
  6. Nov 21, 2010 at 3:28 PM
    trdracing5
    Elizabeth City, NC
    2003 Tacoma SR5
    Damn that is exactly what I need. I wonder if Craftsman makes a good one!
