How to know if a 2009 Tacoma has the Tow Package?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jayoh999, Sep 24, 2023.
  1. Sep 24, 2023 at 8:12 AM
    jayoh999
    jayoh999 [OP] Member
    Hello, I'm John in the Annapolis Valley of New Scotland; aka Nova Scotia. I'm about to purchase a really good looking 2009 Tacoma 4WD, automatic, that is not an SR5 or a TRD. The owner says it has the TP.
    • How do we know for sure?
    • Can a Toyota dealer look up the VIN and tell for certain?
    • Would there be a reference in the Owner Manual, if he has that?
    • What 'bout a sticker on the driver's side door post?
    I know of the different accessories that came with that package. I wish to pull a vintage Bigfoot trailer, so we need the 6500 lb TP. The Sasquatch weighs in dry at 2850 lbs.
  2. Sep 24, 2023 at 8:17 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Easy way is look up by the radiator and if you see anothe small radiator there you most likley have tow package along with a factory hitch in rear. With all that make sure you take a hammer to the frame to make sure it's not a rust bucket. Do youself a favor and look up about the frame rust issues and how to check for a good frame.
    Good luck.
  3. Sep 24, 2023 at 8:40 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Towing package includes:
    27F battery (non Tow Package has 24F)
    130 Amp Alternator (Non Tow Package has 100 amp)
    Engine Oil Cooler (mounted under the engine oil filter)
    HD fan clutch (pink in color)
    Auxiliary Transmission Cooler in front of radiator (A/T only)
    Class IV Receiver Hitch
    7 Pin Trailer Connector with Trailer Brake Control Harness in Cab (Brake controller not included)
    2012 and up models added Trailer Sway Control Programming in the VSC System
    Anyone with a TIS subscription (including dealers) can put your VIN in and see everything that was factory and port installed on the truck.
  4. Sep 24, 2023 at 8:44 AM
    Glaese
    Glaese Unknown Member
    Cris
    Country of Texas
    17 Sandy Taco Ltd
    Dm93 and whatstcp like this.
  5. Sep 24, 2023 at 8:47 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Unless they changed it back recently Toyota removed most of the detailed vehicle information from the public Toyota Owners site, as of about a year ago it only gives you basic information about the vehicle.
  6. Sep 24, 2023 at 8:50 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  7. Sep 24, 2023 at 8:50 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Get a full-sized pickup if you're towing over 6k regularly
    RTX Taco likes this.
  8. Sep 24, 2023 at 8:51 AM
    Glaese
    Cris
    Country of Texas
    17 Sandy Taco Ltd
    Still works for me using that link
    Dm93[QUOTED] likes this.
  9. Sep 24, 2023 at 9:03 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea it still shows some stuff, I wasn't sure if it still listed that or not. It used to be alot more detailed kind of like how TIS still is.
    This is what TIS gives you.
    Glaese[QUOTED] likes this.
  10. Sep 24, 2023 at 9:07 AM
    Glaese
    Cris
    Country of Texas
    17 Sandy Taco Ltd
    Interesting that looks helpful. Mind sharing a link to whatever that website is?
  11. Sep 24, 2023 at 9:24 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You have to have a subscription but it has all the factory service info.
    https://techinfo.toyota.com
  12. Sep 24, 2023 at 7:15 PM
    jayoh999
    Thanks so much to all who have responded to my plea for info! This Tacoma Acess cab has only 145,000 km or 90,000 miles. The price is excellent for me, being a senior on a fixed income. I like the extra rad cooler in front of the main rad idea. I'm aware of rust issues having owned many vehicles over my nearly 60 years of driving. While we use salt on the road here in NS, being very near the ole Atlantic, from what I can see of the images, this one looks like a honey. I've have asked for the VIN and will attempt to indulge someone who has access to the TIS. Many thanks to DM93 for the details of what is included in the TP.
    One further query, we purchased this 1987 B-17 Bigfoot and with it came an equalization hitch with arms for both sides of the tongue as well as a large ball mount with multiple holes for leveling the load. At 6500 capacity, we are well within the pull of the dry weight. I also feel no hesitation in the stopping ability with the Tacoma as the B-17 has excellent e-brakes. I had the drums turned, installing new inner and outer bearings with new BT tires.
    Dm93 likes this.
