How to keep a TRD Pro from squatting while towing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SCJeffro, Oct 19, 2018.
  1. Nov 26, 2018 at 3:53 PM
    #141
    Mike G
    Mike G Well-Known Member
    2020 SR5 Tacoma DCLB 4x4 Red
    What PSI you running?
  2. Nov 26, 2018 at 3:54 PM
    #142
    xA101x
    xA101x Well-Known Member
    AJ
    Idaho
    2017 TRD PRO MT
    I wasn’t too worried about the squat. Drove from Upstate NY to Boise ID like this. The trailer was as full as possible.
    Photoweekender, Skull and YMMPRO like this.
  3. Nov 26, 2018 at 3:58 PM
    #143
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    I havent gotten any run time to test different pressures yet, it’s been parked since I found the leak after install.
  4. Nov 26, 2018 at 3:59 PM
    #144
    deerhntrmike
    deerhntrmike Member
    White trd sport,double cab
    Helwig air bags,predator nuff bars, xenon led lighting
    I have the Helwig airbags and one of mine leaked in the same location after it was installed. I emailed their tech department with a video showing the leak and they had a new bag at my house in about five days. It sucks having to pull everything apart to replace it. They don’t recommend putting air in the bag without the bag being installed but I threaded a male airline fitting into the hole of the new one and inflated it with 10 lbs of air. Sprayed it down with leak detector and it was fine. I don’t know why these aren’t checked before shipping them out. Good luck.
  5. Nov 26, 2018 at 4:01 PM
    #145
    Mike G
    I keep mine around 8psi when empty. When loaded up for camping and towing my small camper I run about 20psi.
  6. Nov 26, 2018 at 4:14 PM
    #146
    Hstone556
    Hunter
    Austin
    Just heard back, they are sending me out a new bag. He did act hesitant to do so, because I bought on Amazon.... I almost just want to throw the whole thing back in the box and return it and get new leafs like I originally planned.
  7. Nov 26, 2018 at 6:19 PM
    #147
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Unless you buy from an official dealer, they seem to be a PITA to deal with. Glad they are sending you a new one, though -- my last kit was missing the 2 small brackets that clamp to the frame and they wouldn't help me because I bought the kit online from Walmart. Apparently Walmart and Amazon are not official dealers. I just made the brackets myself.
    If my loads didn't vary so much, I'd consider new leafs. But half the year I am toting 500 lbs., the other half not much at all. And in the spring, or when I am helping someone move (like college daughters), I go from zero to full multiple times in a day. Bags are the best option for me, but leafs are probably better if toting a constant heavy load.
    Willawah and bagleboy like this.
  8. Nov 26, 2018 at 6:36 PM
    #148
    Hstone556
    Hunter
    Austin
    Right, I didn’t want to mess with leafs also because of varying loads. I do have a shell, HC rear bumper with swingout so I carry roughly 350-400 lbs constantly... but also tow a trailer all the time and just thought this would be the best bet. Still hopeful it works out like I thought it would.
  9. Nov 26, 2018 at 9:32 PM
    #149
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Best to get a new bag but I'm wondering if Stan's Sealant would work as a temporary fix.
    Flash1034 likes this.
  10. Jan 7, 2019 at 5:22 AM
    #150
    daltontr
    daltontr New Member
    Troy
    2015 Black Tacoma Double Cab TRD
    ARE Cap, Running boards, Bed Rug, Yakima rack, Electric brake controller, and All weather floor mats.
    I second that. I tow a travel trailer that weighs approx. 3500 lbs fully loaded. I have an Equal-i-zer WDH with 4-point sway control, which is great, but I noticed that I would occasionally get some slight porpoising over undulating surfaces, like concrete bridges, etc. So, installed the 1000 lbs Sumosprings and that made a big improvement. Plus, the truck stays level, even when I add additional weight, like a cooler or kayak.
    Install is incredibly easy. Loosen the u-bolts, remove factory bump stop, install base plate, raise the body, screw Sumospring onto base, lower and tighten to specs (52 lbs). Rinse...repeat. I did the install in my driveway in less than forty-five minutes and only with hand tools. Throw in an air gun and a lift and you could probably do it in about ten minutes.
    arnette64[QUOTED] likes this.
  11. Jan 7, 2019 at 7:35 AM
    #151
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    I have the bags. Only way to go. Variable unlike sumos.
  12. Jan 7, 2019 at 8:28 AM
    #152
    Hstone556
    Hunter
    Austin
    They’ve been great since getting my replacement bag from firestone. I had 1000 pounds of concrete in the bed a couple weeks ago while hauling my 18’ car hauler loaded with steel and all was well.
    2016Tacoman[QUOTED] likes this.
  13. Jan 7, 2019 at 11:51 AM
    #153
    BitcoinTaco
    BitcoinTaco Member
    2018 Tacoma DCSB TRD 4x4
    I’ve got a 2018 TRD OR(factory tow package)with Dakar HD leaf springs and Fox DSCs. I have my 8 year old ARB RTT mounted on bedbars and with all my camping gear, still had a little squat.
    I also tow an Airstream occasionally so I decided to use the Roadmaster Active Suspension Kit that’s basically a variable coil tension spring that bolts on top of the leafs to help support them. They’ve worked great so far and they’re pretty simple mechanically so there’s not much that can fail, especially catastrophically.
    I love airbags and have them on my lowered vehicles but didn’t want to worry about a potential leaking bag, airline, faulty controller, tank, valve, etc while towing a 5,000lb Airstream trailer with the taco.
    The sumo springs are ok and are basically just big progressive bump-stops but I didn’t want to have to take them off every time I wanted to go wheelin, then reinstall my custom bump stops. The sumo springs are about $200 if I remember correctly.
    The Roadmasters are about $450 but I think you get a lot more benefit out of them for the money spent... A better ride that’s adjustable, they also limit axle wrap, wheel hop, vehicle sway and forward & side body roll.
    Also weight distributing hitches can be your friend. It still amazes me when I see people pulling huge boats and trailers close to maxing out their gross tongue weight,with a basic ball hitch. Just my 2 cents
  14. Jan 7, 2019 at 11:58 AM
    #154
    daltontr
    daltontr New Member
    Troy
    If you require variable height control, they certainly would be the best option. However, after weighing all the pro's and con's, I couldn't justify the additional cost.
    Okay, truth be told, when I pitched the idea of air bags to my wife, she coyly said, "Well...okay...if you think we need that, then go ahead. Seems kind of expensive though...you'd think if the Tacoma was such a great tow vehicle, they'd have equipped it with a proper rear suspension." Ouch!
    Yea, I didn't need to be reminded of that for the rest of my life, so I took my gift card, the $53 in Amazon credit and ordered the Sumo's. I think I ended up paying about $108 dollars, less shipping and everyone, including my wife is happy. ;-)
    beers@1600 and arnette64 like this.
  15. Jan 7, 2019 at 1:11 PM
    #155
    2016Tacoman
    J
    Towing was down on the list of people's preferences.
    Funny how people will drop a grand on wheels just because they look good though.
    BitcoinTaco likes this.
  16. Jan 7, 2019 at 3:07 PM
    #156
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I assume boat trailers rarely using WDH is due to surge braking not playing well with a weight distribution hitch. Yes there are some models out there that do both, but it seems pretty rare, and I have never seen one in person. And dont want to put electric brakes into some saltwater...
  17. Jan 7, 2019 at 9:31 PM
    #157
    BitcoinTaco
    BitcoinTaco Member
    Nope, equalizer has been making surge brake compatible WD hitches for 70 years. I think it’s a matter of cost and need...and you really only need a WD hitch if you’re hauling a boat that weighs close to half of what your tow vehicle weighs, for the most part. Also many boat manufacturers run electric brakes on their trailers now as they’re easier to install, cheaper and easier to maintain. Thankfully Insulated wire, heatshrink and waterproof connectors have come along way.
  18. Jan 8, 2019 at 6:23 AM
    #158
    Mountain2018
    Mountain2018 Well-Known Member
    Harpers Ferry/Leesburg VA
    2018 4x4 SB gray
    On the Firestone air bag front have any, some, (most?) At some point installed new extended shocks to help with an empty bed ride? I like the air bag setup (though need to trace a small air leak this week) and they work great with a decent load on my dual axle utility trailer, (very glad went with a dual axle as tongue weight is lighter).
    BUT, unloaded I have tried everything from 5- 22 psi and still getting the harsh ride where certain conditions cause a sharp hit to suspension. I am considering 5100's all around. (Keep in mind its an SR with the worst shocks in the lineup)
    Recently resorted to always leaving a couple hardened bags of ready mix in the bed, which helps but not the long term answer. Thoughts welcomed.
  19. Jan 8, 2019 at 9:26 PM
    #159
    bagleboy
    Scott
    Norcal, Santa Rosa
    For your situation the solution might be a lighter leaf pack tuned to your bed when empty then the bags would be there to prevent bottoming with additional load.
    An empty bed will ride harsh because it's simply not enough mass to stay put and force the suspension to move instead. What air bags excell at is adding the ability to adjust the total spring rate(leaves plus bags) to match a variety of additional loads beyond what the leaves alone can carry and allow adequate travel without bottoming.
    My base model has rediculously soft springs, possibly shot since I bought it used and with the cap and nothing in the bed my minimum pressure is 20psi to prevent bottoming. The ride is too soft. I should really either replace the springs or add a leaf so that the ride when empty and the bags are at 5psi is tolerable.
    Mountain2018[QUOTED] likes this.
  20. Jan 8, 2019 at 10:08 PM
    #160
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Every trim truck has the same ducking shitty Toyota springs. Those are the first thing anyone should upgrade.
    Airbags with cradles are probably the best compromise for towing and off-road but still just that. A compromise and slanted towards towing
    Mountain2018 likes this.
