How to install factory bed liner clips?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Drewski, Nov 21, 2011.
  1. Nov 21, 2011 at 1:18 PM
    Drewski
    Drewski [OP] Well-Known Member
    People's Republic of Chicago
    '99 Prerunner SR5 Xtracab 4 cyl auto
    Ok, I'm sure it's obvious, but my brain is in neutral apparently. I pulled out the factory bed liner in my '99 Prerunner Xtracab so I could get the whole truck painted. So that's done now, and I'm going to put the plastic bedliner back in. It's the over-the-rails type, and there are 6 clips that hold it in along the sides, but for the life of me, I can't figure out how to hold them in the correct position while I put the damn liner back in.
    Sorry for the brain-dead question, but I'm brain-dead. Any idea?
  2. Nov 21, 2011 at 1:22 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Got any pictures of the clips, and where they would install? I pulled my under the rail Toyota linner out and it was a bitch to get it back in.
  3. Nov 21, 2011 at 4:52 PM
    tam
    tam Well-Known Member
    tam
    East Bay, CA
    Reasons to steal my truck...
    Icon Ext. Travel C/O, TC UCA, Spidertrax 1.25" spacers, CF hood, Glass bedsides, Doug Thorley cat-back, Goodyear Wrangler Duratrac 265/75/16
    Don't you just drop in the liner, pull back on it, put the clip on the rail and slide the bolt through and tighten?
  4. Nov 21, 2011 at 6:07 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I helped pyroskier re-install his OEM bedliner the other day and it seems like when you tighten the bolts, the clips rotate up into position. Only thing you have to do is have the clips started on the bolts when you put the liner back in the bed. Someone else might be able to explain it better.
  5. Nov 21, 2011 at 10:50 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I did it the other day and snapped a couple of them all to hell in my truck.
    I went and threaded them on, then installed and started turning. THe problem, is only 2 went into "place" meaning they did what everyone says as far as clicking into place.
    The rest I had to let droop, then rotate them 180*, then grab the washer, while pulling it towards the center of the truck and rotating the screwdriver.
    I really dont know how toyota does it. It was a absolute PITA, and most of my clips are broke...
  6. Apr 14, 2017 at 6:06 PM
    woulfeparade
    woulfeparade New Member
    Anyone know where to get replacement mounting clips for the liner?
  7. Apr 15, 2017 at 2:15 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I took my liner out a couple times. I thought the clips were pretty simple, all you had to do was screw it in and the latch grabs onto the rails and secures itself. That's all you really have to do, just screw forward until you feel a bite.
