how to install a 4 pin wiring harness into my SR5
Discussion in '2nd Gen. Tacomas (2005-2015)' started by doons, Jan 22, 2012.
  1. Jan 22, 2012 at 4:39 PM
    doons
    doons [OP] Active Member
    KANADIA
    2011 V6 4X4
    hey tacoma world, i have an SR5 without tow package and i wanted to install a 4 pin wiring harness to tow my 16 foot aluminum boat. how hard is this to do does anyone have a brief description?
  2. Jan 22, 2012 at 4:52 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I'd buy a kit that just plugs into the tail light harness and then it's just a couple clips and zip ties. Mount the hitch first so you know where you can secure the harness.
  3. Jan 22, 2012 at 4:55 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Make sure it has a converter for the turn signals.
  4. Jan 22, 2012 at 4:57 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, I have one of those kits for a 4 pin connector. Very simple install, no wire splicing necessary. You can install one yourself in about 15 - 20 minutes with a wrench (to remove the tail lights) and some zip ties.
  5. Jan 22, 2012 at 5:14 PM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '18 TRD Sport MGM with ARE Cap
    I have a 2010 SR5, and added a receiver hitch and a 4 - pin trailer wiring harness. It cost about $20, but included everything (even the zip ties). Just pull the tail light lense, unplug the bulbs, plug the wiring harness in between, then replug the tail light. find a handy place to secure the small converter, which came with an adhesive on the back. I found it easier to run the wiring from the bottom up into the tail light housing. I always take longer than necessary to triple check things, but the whole thing took about half an hour. Google will help you find the right kit, many online companies sell these.
  6. Jan 23, 2012 at 5:46 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
  7. Jan 23, 2012 at 10:40 AM
    reg boulette
    reg boulette Well-Known Member
    If you can afford it, the Toyota module for your truck is the best way to get trailer lights. It is pricey. I put in one of the aftermarket modules that T connect to the tail lights. It worked for about a year, but emergency flashers were non-operative. Eventually I had trouble with other things connected to lighting circuits such as ABS brake warning lights and traction component.
    Switched to the Toyota system - which includes wiring, fuses, relay, etc. and no further problems.
  8. Feb 4, 2012 at 10:45 PM
    BBYE V8
    BBYE V8 Please keep TW beautiful: search & stay on topic
    Brian
    StL, MO
    07 AC 4x4 2.7 5sp SR5
    Can you post the part # and price for this module? How difficult was it to install, or did you have the dealer install it? Thanks!
  9. Feb 5, 2012 at 2:53 AM
    xxaarraa
    xxaarraa Well-Known Member
    I got mine from Amazon for $47 and installed it in 10 minutes. 8 of those minutes was getting the ground wire installed. Easy job.
  10. Feb 5, 2012 at 9:57 AM
    BBYE V8
    Brian
    StL, MO
    Was that for the Toyota kit? If so do you have a part #? I believe the Toyota kit runs an entirely new circuit from the fuse box under the hood instead of tapping into the tail lights.
  11. Feb 5, 2012 at 11:17 AM
    Tacoma Mike
    Southern Maine
    This......
    I can't tell you how many of the el cheepo i take out on a weekly basis.
    Splicing and tapping is a great way to get corrosion started in the harnesses. The boxes go out or short.
    I know everyone wants to save a buck but Toyota's system is designed for the truck.
    Yes some will say I have never had a problem with the one i got. Good for you. But, like i said, I change a lot over to factory.
  12. Feb 5, 2012 at 11:48 AM
    curtsmith17
    curtsmith17 Active Member
    SMITTY
    ON
    09 4x4
    Bilies 5100 All Four Corners (O.85" in Front), Eibach/Toytech Springs, URD Short Shifter
  13. Feb 5, 2012 at 3:09 PM
    xxaarraa
    http://www.amazon.com/gp/product/B001EOV3JS/ref=oh_o04_s00_i01_details
    Thats what i installed and it worked on a 3.5k mile cross country trip across difficult weather. Still works and I'm happy with it.
  14. Jun 4, 2012 at 9:19 PM
    BBYE V8
    Brian
    StL, MO
    To help anyone searching for this info someday: the part # for the OEM Toyota 4 pin wire harness is 08921-04960. It includes the fuse, relay, converter assembly, wire harness, sub-harness (with the 4 pin plug), zip ties and instructions. It list for $95 but my local dealer matches internet prices so I got it for $80.75. They even had it in stock. I feel a LOT better with whatever I tow on a completely separate circuit than the rest of my lights. Oh, and it was very easy to install.
