How to inspect water pump for replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by coff33, Aug 28, 2021.
  1. Aug 28, 2021 at 6:09 AM
    coff33
    coff33 [OP] Well-Known Member
    5vzfe manual
    On tight budget. Truck has 200,000 miles. Want to change coolant soon. Thought I'd take a look at the water pump before I do it. Do not want to replace pump unless necessary. What exactly should I be inspecting on the pump once I have it out?
  2. Aug 28, 2021 at 6:20 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    no sure fire way to inspect
    back off the tension on belt wiggle front shaft for play
    most pumps goin south will leak a little............leak a lot
    test the presure cap b4 changing out fluid
    under normal environs a healthy pump will provide good pressure
    unfortunately it can go at any time
  3. Aug 28, 2021 at 8:35 AM
    Bubba’sTaco
    Bubba’sTaco Virtually-Known Member
    Spencer
    Ogden Utah
    Toyota XJ
    Only thing I’d add is to get a good light and inspect every little nook&cranny for the leaks. I didn’t have any noticeable warnings before mine went out. First indication was the temp gauge rising when the housing cracked.
    It happened during the winter so looking back I think the short heating/cooling cycles of the engine from quick trips in single digits might’ve played a role.
  4. Aug 29, 2021 at 6:06 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Has the original water pump / timing belt replaced before? V6?
  5. Aug 29, 2021 at 6:14 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Ok, I edited since I lack the ability to read. You change the WP with the timing belt job. If you notice coolant leaking from the area or that the truck is beginning to over heat, then it's time to do that job. It's recommended every 90k miles, which at 200k, it's close to time if it hasn't been done. Most the time there is a sticker on the timing cover that says when the last time it was done. If not, I'd default to that it hasn't been done.
    jrallan26 likes this.
  6. Aug 29, 2021 at 6:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    Does the weep hole on the bottom have any 'tracks' of coolant?
    Does the shaft have any play?
    Yes to either suggests changing.
  7. Aug 29, 2021 at 6:44 AM
    coff33
    5vzfe manual
    unknown. yes.
  8. Aug 29, 2021 at 6:50 AM
    jrallan26
    Iowa
    If unknown then replacement is needed. Buy the timing belt / water pump kit. Comes with everything needed.
