How to Increase Bed Height with wooden Side rails
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AllGunmetalGrey, Dec 2, 2021.
  1. Dec 2, 2021 at 11:00 AM
    AllGunmetalGrey
    AllGunmetalGrey [OP] Active Member
    Koen
    2007 Toyota Tacoma 4.0 Dbl Cab Prerunner
    rockford fosgate front Speakers,
    I have been looking for forever to find the wooden side to extend my tacomas bed height so i can fit more stuff in the bed is there anything I can put on it, I can't put wood boards cause theres no stake holes like most other trucks have.
  2. Dec 2, 2021 at 11:04 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Remove your plastic bed caps and I bet you will be surprised.
    Jojee117 likes this.
  3. Dec 2, 2021 at 11:19 AM
    AllGunmetalGrey
    Koen
    I looked and they dont have any holes and if they do there small but theres no bottom to them so the wood would just wiggle around
  4. Dec 2, 2021 at 11:32 AM
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    Maybe utilize the bed mount rails. Fabricate some brackets out of metal, mount with T-nuts. Then fasten 2x4 on brackets the length of the bed and built up with what ever you like.
  5. Dec 2, 2021 at 11:57 AM
    AllGunmetalGrey
    Koen
    @RCRcer you are a freakin genius thanks
  6. Dec 2, 2021 at 12:11 PM
    Pigpen
    Northwest Montana
    For brush and firewood, I always just had plywood above the wheel wells, with 2x4 legs. I mounted plywood for the front to protect the rear window. I built them to a height so they could be laid down on top of each other in the bed, fitting between the wheel wells when not in use.
    Jimmyh likes this.
  7. Dec 2, 2021 at 12:12 PM
    RCRcer
    2015 OR DC
    Glad I could help!
  8. Dec 2, 2021 at 12:15 PM
    RCRcer
    2015 OR DC
    Depending on your use this is a great option too!
  9. Dec 2, 2021 at 3:28 PM
    AllGunmetalGrey
    Koen
    @RCRcer yeah thats a good one to, i really need it to be strong though i really need support im gonna make it to where i can just slide it out of the rails to the back out past the tailgate
  10. Dec 2, 2021 at 3:42 PM
    RCRcer
    2015 OR DC
    Sounds good!
    Post a pic when you complete it.
  11. Dec 2, 2021 at 3:48 PM
    AllGunmetalGrey
    Koen
    @RCRcer i definitely will ,(if i remember)
