How to hard wire dash cam to stay on when taco is off?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Franciscostaco, Apr 30, 2023.
  1. Apr 30, 2023 at 8:21 PM
    Franciscostaco
    Franciscostaco [OP] New Member
    Hi,
    hoping to get your input. Just installed a Viofo A119 dash cam and bought the Viofo hk3 ACC hardwire kit for it. Hooked it up and it powers on when I start the truck (ignition) but I don’t believe it stays on when it’s the truck is off. I believe it doesn’t stay on because the red light on the camera turns off. I also enabled the parking mode. I plugged the red wire (power) with (2) 15 amps to the USB fuse and the yellow (ACC) to the bottom left empty slot with (2) 20 amp fuses. Not sure if I’m missing something. Would appreciate the help. The more simple terms the better. Thank you!!
  2. May 1, 2023 at 7:34 PM
    caribe makaira
    Caribbean, Puerto Rico
    Both locations you have chosen are IGN source not always on (bat). Identify the sliding roof fuse. That one is always ON (bat).
  3. May 1, 2023 at 7:38 PM
    Franciscostaco
    Worked thanks!
  4. May 1, 2023 at 8:07 PM
    caribe makaira
    :hattip:
  5. May 2, 2023 at 12:46 AM
    Ensemble88
    Ensemble88 Well-Known Member
    San Diego, CA
    2017 Black OR DCLB
    King suspension, SSO bumper w/winch, Pelfreybuilt sliders, morimoto fogs
    Just a word of advice, consider getting a small dedicated battery pack for your dash cam. Otherwise it may drain your battery if you have motion sensing on all night and don't drive your car for a couple days.
    ToyoTaco25 and Tacoma Rant like this.
  6. May 2, 2023 at 12:44 PM
    Tacoma Rant
    Tacoma Rant I can’t be good all the time.
    Wisconsin
    2023 Tacoma TRD Sport Electric lime
    What he said. Get a separate power source that you can switch to
    ToyoTaco25 likes this.
  7. May 2, 2023 at 12:53 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    From a time I ran an electric lawnmower (renting a house, had to mow, wanted something more expendable) I have a Kobalt 40V Max 4.0 Ah battery. Runs the mower for 40 minutes, so a dashcam can run for days. Not saying it is the prime solution, buy for $130 of the battery if you can get the charger it would run my dashcam on battery forever, if I wanted to wire a DC adapter. About 2 lbs, 6.5 in X 4.5 in X 2 in.
    Just saying there are powerful options and since the truck already weighs 5600 lbs bare-bones ...
  8. May 2, 2023 at 1:00 PM
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    There is where I have mine hooked up.
    Did you also ground the ground wire?
  9. May 2, 2023 at 1:07 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    An over the top solution to this problem is a Blue Sea Systems M-LVD low voltage disconnect setup between the battery and the aux fuse panel where the dash cam is plugged in. The downside is that the camera will not know that the ignition has been turned off and it will stay in constant recording. I have pics of my setup in the electrical section of my build thread linked in my sig.
  10. May 2, 2023 at 1:16 PM
    RichochetRabbit
    I have not tried it, but my dashcam has a "constant monitor" mode that I think is triggered by activity but is not always recording so "loop over-record" may not occur. Something to verify about any dashcam.
    mic_sierra[QUOTED] likes this.
  11. May 2, 2023 at 7:13 PM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    I just run my dash cam to the OBD port using a connector cable with a switch that toggles between always on and only on when the truck is powered on, since the OBD port always has constant power. This lets me set to always on when parking in public but set it to off when parking at home, the cable also has a voltage cutoff sensor that stops it from drawing so much power it stops the truck from starting - I deliberately left it on for a full week while using my work truck and it still started up fine afterwards.
  12. Jan 7, 2024 at 6:34 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Any info or links to this?
  13. Jan 7, 2024 at 6:44 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The kit he’s using has a selectable low voltage cutoff to avoid that problem.
    BTL Y-Wing likes this.
  14. Jan 8, 2024 at 1:01 PM
    BTL Y-Wing
    Definitely an important consideration for sure. When my truck is parked at home all week it's in view of the cameras at the door and above the driveway, so running the camera is only when it's parked elsewhere for shorter periods of time. The OBD connector switch I use also has a voltage cutoff that turns the camera off below a certain level so the truck can still start - unintentionally tested several times when I forgot to turn the camera off after coming back late at night and the truck still started close to a week later despite having left the camera switch on.
    Similar design to this one from the same generic brand, just make sure the connector power port matches whatever your dash cam uses. I found better deals on ebay than Amazon. Despite being cheap it has voltage cutoff so the camera won't kill the started battery, powers on automatically when the truck starts and stays on for ~5min after turning off, so the switch only controls power behavior when parked at length.
    https://www.amazon.com/REARMASTER-U...4557496&mcid=5d62b631bfe0370e946538dcb8cfa244
  15. Jan 8, 2024 at 1:30 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Hey venezian, are you saying this location will stay on without the key?
  16. Jan 9, 2024 at 8:53 AM
    venezian
    Los Angeles
    2022 7545E
    Yes
    Tocamo[QUOTED] likes this.
  17. Jan 9, 2024 at 9:08 AM
    BigJanko
    BigJanko Well-Known Member
    West Columbia, SC
    2021 Tacoma TRD Pro Matte Sunflower Wrap
    Body Armor Hybrid Front Bumper w/high clearance wings Body Armor Rear Bumper Armordillo Chase Rack Diode Dynamics SS5 Flood Lights Caliraised LED Ditch Lights Rough Country 20" Light Bar Rough Country 2" LED Pods Rough Country 6" LED Bars Glowe Industries Under Glow Kit Barricade 9,500 lb Winch S&B Cold Air Intake OTT Tune N-Fab Sliders PWF Matte Sunflower Vinyl Wrap
    My dash cam has a parking mode that's supposed to turn off after a couple minutes of inactivity. Instead, it just ran all night and destroyed my battery.
    *Edit*
    Forgot to mention, it came with a low voltage hookup too. That obviously didn't work either. LOL
