How to get raw throttle response
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thomasjohn314, Jan 12, 2022.
  1. Jan 12, 2022 at 7:40 PM
    thomasjohn314
    thomasjohn314 [OP] Well-Known Member
    John Cameron
    Hilton Head Island, SC
    2020 Tacoma TRD OR 6AT
    Custom VFtune, aftermarket TRD pro grille, raptor lights
    Hello,
    I’m trying to figure out how to get raw and simple power out of my Tacoma. I’ve been doing research on tuning options and aftermarket ecus. From my research I’ve learned about the “calibration” (OVtune changes it). Does this calibration adjust to the truck or to my driving style? I just want raw acceleration and good shift points. I do not want the truck to adjust to my driving style or anything like that. If the calibration isn’t affected by my driving then I’m fine with it. It’s been really hard to find any info on tuning for the stock ecu. (I would also like shift lock). I have an AT. In the end I’m asking either what tuning to do or aftermarket ecu to install to achieve these needs. Thanks!
    edit:
    I basically want to tune my truck such that the throttle responds like a gas pedal connected mechanically to the carburetor like in an old car. If that doesn’t make sense let me know in the comments.
  2. Jan 12, 2022 at 7:45 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Step 1 sell anemic minivan 3.5l
    Step 2 LS swap it.
    Alternatively:
    Full size with V8.
  3. Jan 12, 2022 at 7:47 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome. If you want real power, you need forced induction and then start modding from there. ECU tuning and bolt-ons etc are not going to give massive returns.
    Skydvrr and Key-Rei like this.
  4. Jan 12, 2022 at 7:50 PM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    Raw power, you need to remove the whole efi system and install two double barrel carbs.
    You might need a chock pull switch for cold starts.
    MannyS, vicali and rlx02 like this.
  5. Jan 12, 2022 at 7:50 PM
    thomasjohn314
    John Cameron
    Thanks for responding so quickly. I’m not really trying to increase power, I’m just trying to change throttle response. (My bad for titling thread incorrectly, I’ve changed it)
  6. Jan 12, 2022 at 7:51 PM
    Bishop84
    Bishop84 Well-Known Member
  7. Jan 12, 2022 at 8:03 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    A pedal commander will do that. Basically it magnifies however far you push the pedal in the signal to the ECU. No different than just pushing the pedal further yourself, but it feels more responsive. Not something I’d personally recommend.
    jackn7, Basic 4.9, Junkhead and 2 others like this.
  8. Jan 12, 2022 at 8:11 PM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    I went from original OEM tune, then added pedal commander, then to TSB tune, then removed pedal commander and went to OVtune beta, then to OVtune 2.0 now KDmax 7.0. KDmax is the best driving so far, and throttle is much more sensitive. Don't waste money on a controller, and get a proper tune (Kdmax isn't the only company doing it, there are a few).
  9. Jan 12, 2022 at 8:15 PM
    thomasjohn314
    John Cameron
    Thanks for the info. Does KDmax offer gear lock in S mode?
  10. Jan 12, 2022 at 8:50 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Anemic?
    44-16 Taco and shakerhood like this.
  11. Jan 12, 2022 at 8:53 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    A premium performance tune (SFOB) made my throttle response much better.
    On a drive by wire vehicle, I don’t think it’s possible to simulate throttle cable. I really do miss that though…
    jackn7 likes this.
  12. Jan 12, 2022 at 8:55 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It is an aluminum block and heads after all.
  13. Jan 12, 2022 at 9:03 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Yes.
    What does that have to do with the engine being “anemic”?
  14. Jan 12, 2022 at 9:04 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Aluminum…low iron content…anemia…
  15. Jan 12, 2022 at 9:06 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Fuck! I should’ve got that.:facepalm:
    I should know cuz my wife is anemic, true story…
    jackn7 and hiPSI like this.
  16. Jan 12, 2022 at 9:16 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    This is the way:
  17. Jan 13, 2022 at 5:33 AM
    758_Moto
    758_Moto Well-Known Member
    2004 LT Taco, 2019 Taco
    2019: Icon Coilovers/UCA/AAL, 16x8 Methods/285 Duratracs, URD Spec-U Exhaust, Nexus +P Tune 2004: Chaos LT w/Kings/62" Deavers/12" TC Shackles, Glassworks hood/fenders/bedsides, TRD SC, URD fuel mods/lightweight flywheel/10psi Pulley, JBA Headers, TT Supra MAF
    The KDMax tune with sport throttle setting definitely helps with off idle throttle response. And yes, they have an option for true gear lock in S mode, but you will lose ECT function
  18. Jan 13, 2022 at 6:27 AM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    What is true gear lock and what advantages does it provide? I rarely use my ECT after the KD Max tune will agressive tip. Really do love that throttle response and shift points.
  19. Jan 13, 2022 at 6:39 AM
    758_Moto
    When you put the truck in S mode and select a gear the truck will still downshift to lower gears if necessary but won't shift above the gear you select. With the KDMax gear lock option, it will keep it locked into whatever gear you select until you manually change it.
    Chaosh1[QUOTED] likes this.
  20. Jan 13, 2022 at 8:37 AM
    o313
    o313 Well-Known Member
    N
    2018 DCLB AT SC
    is KDMax the "New" OVTune?
    Where does one get the KDMax tune?
