how to fully take apart and clean out heater with mouse in it
Discussion in '1st Gen. Tacomas (1995-2004)' started by colonelforskin, Oct 20, 2015.
  1. Oct 20, 2015 at 3:04 PM
    colonelforskin
    colonelforskin [OP] New Member
    01 tacoma 4x4
    i realize there are several threads on the subject of determining whats wrong in regard to banging noises and smells of dead mouse in the heating system and mice prevention, but im looking for more specifics on how to take apart the system to give it a proper clean out after the fact... dont currently have a manual, aside from figuring it out, any pointers/details on a full clean out/disassemble would be appreciated. i assume he/she is in the blower as it makes a knarly grinding banging noise when turned on.. and it is very dead hence the smell (hopefully in one piece).
  2. Oct 20, 2015 at 3:56 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    On the passenger side up under the dash on the plastic venting system you will find the fan held in with screws. Unplug the fan and remove the screws and drop out the fan. Inspect, remove deceased critter if present and other debris.
  3. Oct 20, 2015 at 3:57 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    :popcorn:
    GQ7227 likes this.
  4. Oct 20, 2015 at 8:29 PM
    MainahWithaYota
    MainahWithaYota Well-Known Member
    Dallas, GA
    04 DC v6 4x4
    This exactly. I had the same problem a couple winters ago. Turned my blower on and it was grinding and making all sorts of noises. I figured it needed to be cleaned but it was too cold to open it up. Summer came around and DAMN didn't that thing smell. Dropped 3 or 4 screws and unplugged the blower motor/fan, pulled it out of the dash and used a flat head screw driver to pry Mickey's body out of the blower cage.
    Buzz4X4 likes this.
  5. Oct 20, 2015 at 9:03 PM
    Caligula
    Los Angeles, CA
    We will be expecting pics of whatever is making that smell. :popcorn:
    tacojim02 and GQ7227 like this.
  6. Oct 21, 2015 at 10:55 AM
    colonelforskin
    01 tacoma 4x4
    thank you CD20H did just that, found a dead mouse pressed into the blower and a comfortable looking nest... disinfected it and ran the system a bit, good as new.. sorry Caligula no pics, not up to speed with that yet.
  7. Oct 21, 2015 at 11:30 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    better not let PETA find out about this Tacoma mouse trap or they will want to recall our trucks as cruelty to mice lol.
    GQ7227 likes this.
  8. Nov 17, 2015 at 1:58 PM
    Bar None
    Bar None Member
    Vincent
    2012 Tacoma 4x4 regular cab
    None
    CD20H,
    Thanks for the info. Had mice in my 2012 Tacoma blower just like I had in my long gone 2001. Now I need to search for where I need to put the hardware cloth for the blower inlet and maybe for the air cleaner inlet like I did for the 2001. Think Toyota would have fixed this problem by 2012.
    Loaded up my wannabe Indian and migrated to Southwest Florida for the winter.
  9. Mar 16, 2020 at 7:51 AM
    EJW27
    EJW27 New Member
    EJ
    98 Tacoma TRD 3.4L V6
    Very helpful thread! I attached photos of the fan that CD20H referred to. As well as, the mouse causing the smell and clicking :)
    Three 5/16 bolts. It helped to remove glove box and interior side paneling near door to access one of the bolts.
    GQ7227 likes this.
  10. Mar 16, 2020 at 7:55 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard new member
  11. Mar 16, 2020 at 8:26 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    oh my my, that is one dead critter
  12. Mar 16, 2020 at 1:33 PM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    Mine started making some noise the other day, will have to drop it and check. Hopefully no mouse. Anyone have a pic of where they get in from there? I'd like to screen it off.
  13. Mar 16, 2020 at 1:34 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i think they crawl in through the windshield cowl area where fresh air comes in at
    Bridge4[QUOTED] likes this.
  14. Mar 16, 2020 at 1:36 PM
    Bridge4
    MA
    Thanks, shouldn't be too hard to pull that off and see where the hole is.
  15. Mar 16, 2020 at 1:38 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    the hole is most likely covered by sheet metal
    i am looking for a pic i grabbed off of TW awhile ago
  16. Mar 16, 2020 at 1:39 PM
    Bridge4
    MA
    Sounds tricky to cover then! Pic would be huge help.
    GQ7227[QUOTED] likes this.
  17. Mar 16, 2020 at 1:40 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this is probably it here
