How to fix P0441 Code
Discussion in '1st Gen. Tacomas (1995-2004)' started by Michael Nelson, Oct 17, 2011.
  1. Oct 17, 2011 at 2:36 PM
    Michael Nelson
    Michael Nelson [OP] Active Member
    Michael
    Warner Robins, GA
    98 Tacoma
    Throttle Body Spacer, Deck Plate Mod
    pulled code P0441 which said was a EVAP Control System Improper Purge Flow.
    Is this something that needs immediate attention or can i have it fixed in due time?
    also where exactly is this purge valve located, is it something that can just be cleaned?
  2. Oct 31, 2017 at 2:24 PM
    Luis martinez
    Luis martinez New Member
    Luis
    Tacoma 2004
    Purge valve is located ,on comparment engine on left side..close to fuse box.
    It 2 conector hoses .and conector for power.
  3. Oct 31, 2017 at 2:26 PM
    Luis martinez
    Luis
    Tacoma 2004
    I had same problem,don't buy gas cap from autozone or advance....get original one save you headaches. ...
  4. Nov 1, 2017 at 10:26 AM
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    Check your gas cap gasket for cracks.
  5. Nov 1, 2017 at 2:35 PM
    Luis martinez
    Luis
    Tacoma 2004
    Thanks .....a lot
  6. Nov 1, 2017 at 3:14 PM
    Kens04Taco
    Kens04Taco Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Start at gas cap, remove and check gasket. If cracked,dry, deformed....replace.
    Find the purge valve. Get a 9 volt battery and some leads. Blow into the purge valve. I believe it's normally closed so no air should flow. Hook up the 9 volt battery. You can find positive and negative from the other end of the electrical connector. Blow...air should flow. Also when u should hear a click. When u hook it up to the battery.
    If this works check your vacuum hoses for leaks. I just replaced all of mine because it's cheap and you can buy it by the foot.
    If this all seems to be in order move to the rear of the truck. Near the gas tank is your evap canister. Located on this black box on the top is another valve similar to your purge valve. Remove and test with 9 volt battery and inspect vacuum lines. (This was the culprit for my issue).
    If you have tested these and everything is working and functioning as it should you either have a cracked evap canister or the small diaphragm in the gas tank fill neck is fucked.
    yote, upongame619 and NvrSyNvr like this.
  7. Oct 16, 2023 at 9:08 AM
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    I had this Code get thrown on my way home from work. I followed this order of repair and started with the gas cap. Sure enough the thing was screwed off, I know it wasn’t me but I guess that’s what I get for parking in a downtown Seattle parking garage. Glad the problem was minor and easily fixable
