how to fix a flashing check engine light
Discussion in 'New Members' started by Delta Thesis, Dec 25, 2016.
  1. Dec 25, 2016 at 12:58 PM
    Delta Thesis
    Delta Thesis [OP] New Member
    Alfred
    Corsicana
    1998 purple Crystal Pearl Tacoma SR5 2.4L
    Cool air filter and two 12in electric fan
    1998 Toyota SR5 2.4 liter Flashing check engine light I put new wires new plugs new radiator and still having problems can anyone help me please
  2. Dec 25, 2016 at 1:01 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    you need to go to Advanceauto they can read the code for free, then you can fix it. if you want to shut it off disconnect your Neg . battery cable
    Delta Thesis[OP] likes this.
  3. Dec 25, 2016 at 1:08 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Only time mine flashes is when I'm approaching an oil change interval.
    I'm going to assume this isn't the case with your truck
  4. Dec 25, 2016 at 1:12 PM
    Mush Mouse
    mush
    2013 SR5
    advanceauto or autozone will read it for free and give you a printout on the codes and what part to replace, or get the codes and use the search button here. if you turn off the CEL with the neg. batt. cable, the codes will still be stored in the ECU to read later
  5. Dec 25, 2016 at 1:17 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    :notsure: Fix the engine
    T4RFTMFW likes this.
  6. Dec 25, 2016 at 1:18 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The reason for your flashing check engine light is a misfire. A HEAVY one. You may want to make sure your ignition coil is good. You may also want to consider checking your head gasket to make sure it's not damaged. From what I remember, those engines are good at blowing head gaskets. Especially in the higher mileage range.
  7. Dec 25, 2016 at 1:19 PM
    Mush Mouse
    mush
    2013 SR5
    the 3.0 v6 blows head gaskets, the OPs 22R is solid as a rock
  8. Dec 25, 2016 at 1:19 PM
    Mush Mouse
    mush
    2013 SR5
    :santa:
  9. Dec 25, 2016 at 1:20 PM
    T4RFTMFW
  10. Dec 25, 2016 at 2:35 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Maybe I was thinking of bent valves. One of the 4 cylinder toyota engines that is in the trucks eithet blows gaskets or bends valves.
