How to engage 4WD with manual hubs
Discussion in '1st Gen. Tacomas (1995-2004)' started by L78, Dec 30, 2020.
  1. Dec 30, 2020 at 5:28 PM
    L78
    L78 [OP] Well-Known Member
    Tony
    Nor Cal
    1995 Tacoma DLX, 2.7/Manual, 4x4, 1 family ownership
    Mostly stock, added custom wood bed rails and a Sony/Infinity stereo system
    I know I need to turn the knobs on the front hubs, but I have never done this before, and the owners manual is missing,
    1/2 turn? Full turn?
    do I need to do anything ( like reverse for 5 feet after engaging)?
    similar for returning to 2WD, anything I should know?
    probanly been years ( decades?) since it’s been in 4WD, anything I should expect?
    many problems doing this in a dry street or parking lot? Not a lot of public areas for off roading nearby.
    thanks
    Black DOG Lila likes this.
  2. Dec 30, 2020 at 6:24 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Find a spot with loose gravel, grass, dirt, or sand. Don't make tight turns in 4wd on dry pavement.
    Turn hubs lock to lock 180° start engine, MT in neutral or AT in park.
    Pull Tcase Jshift back 3" from 2Hi to 4Hi and look for green 4x4 dash light.
    Put MT in 1st or AT in D
    To shift to 4Lo Tcase shift to right and up while stopped.
    You can shift from 2Hi to 4Hi at up to 50 mph. Stop to shift into 4Lo.
    xxTacocaTxx and Taco critter like this.
  3. Dec 31, 2020 at 4:21 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Quite possible the hubs may not turn or engage just from not being used in years.
    Here in Pa that would be a given you might get lucky .
    Taco critter likes this.
  4. Dec 31, 2020 at 4:33 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Hubs marked free / lock. If you can't fully turn by hand it's time to disassemble to clean and regressed.
    Wulf likes this.
  5. Dec 31, 2020 at 4:43 AM
    Clearwater Bill
    Billy
    Largo Florida
  6. Dec 31, 2020 at 5:22 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    Turn hub from “free” to “lock” before shifting into 4hi. There should be a little arrow on the hub dial. The dial will only turn between free and lock, you can’t turn the dial all the way round.
    It’s clockwise for lock and counter clockwise for free.
    also, if the hubs are the same as my 85 4runner (I’m pretty sure they are, but I could be wrong) its definitely not a full half turn between free and lock. It’s more like a third of a turn or 120 degrees between free and lock.CA5CB6AE-213F-4D68-B6A4-E849E8340F1D.jpg
    Wulf likes this.
  7. Dec 31, 2020 at 5:45 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    all correct, except that it isn’t 1/2 turn.
    It’s 1/3 turn, or 120degrees.:anonymous:
    *i don’t think the manual hub setup will disengage at 50 mph with manual hubs I’m pretty sure you need to reverse for a couple of feet.
    It’s been a while, I use my taco far more than the 4rnr with manual hubs. But the 4rnr was my first car as a teenager.
    side note, you can swap a Nissan Pathfinders manual hubs with Toyota manual hubs.... I did it when some drunk Lady sideswiped my 4rnr in high school and cracked my hub in half. Went to the junkyard and pulled hubs off an old pathfinder. Prefect fit
    Wyoming09 likes this.
  8. Dec 31, 2020 at 6:53 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    If they haven't been used for a long time, as someone said they may be reluctant to engage. Grease gets dry and stiff. Before taking them apart, you might try raising the front wheels and use a little hand rotation while moving the dial.
    The grease can also get stiff in the Winter and not want to turn. If you drive through water when temps are cold, I have had them freeze on F150s. I haven't had the front of a Taco in water over 6" deep at low temps, so no experience with ours.
    Those dials are hard to pinch with gloves on, so I made a little cheater for Winter time engagement.
    Before someone blasts me about potential damage:
    NOT RECOMMENDING YOU USE ANY MORE FORCE THAN A SINGLE HAND CAN APPLY! This tool is just meant to keep my fingers from being abused.
    DJB1, Black DOG Lila and DiscoYaker like this.
  9. Dec 31, 2020 at 7:06 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    You know what's cool about manual hubs and 4wD? 2 Low! all good tips here. Just don't bind it up on dry pavement.
  10. Dec 31, 2020 at 7:50 PM
    L78
    Tony
    Nor Cal
    Brings back memories I had forgotten...
    Back when I was in high school , my mom bought a 1978 Chevy Blazer ( full size). 3” lift, 33” tires, 400 cubic inch, automatic. True dual exhaust, and despite being a California vehicle it had no smog equipment required!
    Previous owner installed Warn manual hubs.
    I’d put the thing into 4L which was really 2L with unlocked hubs. Very Quick! A rocket but a top speed of about 40 mph... fun times.... until I snapped the front u joint on the rear driveshaft.
  11. Dec 31, 2020 at 8:13 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Isn't there a directions label on the drivers Sun Visor on how to operate these manual hub 4x4. If memory serves me, when you take it out of 4 wheel drive, you have to back it up about 50 ft or so. Correct me if I'm wrong.
    Wulf and L78[OP] like this.
  12. Dec 31, 2020 at 8:16 PM
    L78
    Tony
    Nor Cal
    I noticed info on the visor while I was cleaning it, but I never stopped to read what it was about.
    My nephew can’t find any paperwork for the Tacoma; manuals, receipts, etc... his dad was very organized, so it’s a little baffling that he couldn’t find anything.
  13. Jan 1, 2021 at 2:03 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The backing up helps release the Torque bind so sometimes is needed sometimes not .
    the more torque bind the harder to get out of 4 high or 4 low
    The less the wheels can slip the harder to get out of 4x4
    Wulf likes this.
  14. Jan 1, 2021 at 3:12 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There were warning labels on the visor, and in the owners manual advising drivers to NOT use lo range in 2wd for that very reason. I've seen several guys snap U-Joints doing that. Now we have guys re-wiring Tacomas so they can operate in 2 lo. They are just asking for trouble.
    If there is any remote possibility of needing 4X4 go ahead and lock the hubs. You can still drive in 4X2 and shift into 4X4 and back to 4X2 as needed. Technically they should called Unlocking hubs. Original 4X4's didn't have them and the hubs stayed locked all of the time. "Unlocking" hubs were invented in order to improve fuel mileage.
    In fact it is a good idea to lock them every few weeks and drive around for a few miles to keep everything lubricated. The owners manuals have always suggested about 10 miles/month in 4X4 to keep everything lubricated. You can lock the hubs and drive on pavement with no damage as long as you stay in 4X2. And you can shift into 4X4 and drive safely on pavement for a few miles as long as the hubs are unlocked without hurting anything.
    Manual locking hubs are SLIGHTLY more reliable than the automatic locking hubs on newer trucks. But if not used regularly to keep them lubricated they will also fail to engage.
    It doesn't matter which 4x4 system you have sometimes you need to drive a few feet in reverse to get the gears to release. This is especially true when coming out of lo range. The type of locking hubs you have does not matter. This is due to gears binding in the transfer case.
  15. Jan 1, 2021 at 7:53 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Wsidr1[QUOTED] likes this.
  16. Jan 2, 2021 at 5:46 AM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    @Marshall R , very good explanation of the 4x4 system. I even back up in my 03 4x4 when switching back to 2hi.
