[How to] Enable Video Bypass on Pioneer NEX Units
Discussion in 'Audio & Video' started by xguntherc, Jun 3, 2015.
  1. Apr 19, 2019 at 8:52 PM
    #81
    Desert Honda Squid
    Desert Honda Squid Fixer of stuff I broke
    Fredo
    New Jersey
    08 Silver TRD OFF ROAD 6MT
    I have successfully bypassed the 4400NEX. Here is the diff between microbypass and the corner screen hold after firmware update to v1.01
    Touch screen bypass: only good until you lose battery power or reset the radio. You will have to bypass again. Not a perm solution.
    Microbypass: permanent solution. Tricks the system into simulating the parking brake being applied. Never lose the function (unless you wired it wrong)
    I have the 4400 in my Civic and Tacoma. Bypass works on both.
  2. Apr 20, 2019 at 7:14 AM
    #82
    jeffw_00
    jeffw_00 New Member
    According to the YouTube Video "How to do the Bypass on the AVH W4500NEX" by Five-Star, and according to the microbypass guy (I emailed him) . For the 4400 you update to the 1.01 FW, ground the parking wire, and do the press at the bottom left of the screen. No bypass wiring needed or recommended. Check the video
  3. Oct 12, 2019 at 4:47 PM
    #83
    prone2xl
    prone2xl Well-Known Member
    Mississippi
    2008 Silver TRD Sport DC
    Does this work on the Pioneer AVIC x850bt? Just bought a micro bypass for it specific to navigation models. (It’s older like 2013). The part I’m confused about is the grounding after I insert this little thing. Here’s what I got
    Parking Brake Override Bypass Fully Automatic Video in Motion Pioneer Extra Wire with OEM Pin and Tool Kit https://www.amazon.com/dp/B00F6X89SG/ref=cm_sw_r_cp_tai_qwMODbVNM5C8K
  4. Oct 13, 2019 at 8:23 PM
    #84
    Texas Silver Streak
    Texas Silver Streak Active Member
    Sidney
    Texas Hill Country
    Mall-rated 2019 Tacoma SR5 DCSB
    MESO stage 1 lights, LED's in cab, Sony stereo and Rockford Fosgate speakers in the doors and Kicker subwoofer so far....
    Not sure since your radio is several years old and things may have changed. Good luck.
  5. Oct 16, 2019 at 3:14 AM
    #85
    Desert Honda Squid
    Fredo
    New Jersey
    Yes. That's exactly the one for your radio. If you scroll down you will see the list of radios it supports.
    However, this is a different design from the micro bypass that I have. You're going to have to either type or show a picture of what the instructions say exactly so I can see how the ground is supposed to be installed.
  6. Nov 17, 2019 at 4:29 PM
    #86
    prone2xl
    Mississippi
    Desert Honda Here’s what I got -
    Honestly tho I got more than i bargained for when I took off my dash today to look behind my head unit and try and do this mod plus the I simple hdmi connector. What in the world is all this mess !? Had my pioneer AVIC x850bt installed by bestbuy but damn where are the rca and video connectors ? All I see is shit that I can’t make heads or tails from. Wanted to try and connect my phone to head unit via hdmi to do screen to screen thing. Where do i tap into ? And also. Is the Navi unit supposed to have this usb like port that I’m holding in the last pic ?
    also does anyone have any tips on getting the head unit mounted back into the dash with all these wires in the back ? Feel like i had to bend and possibly warp those brackets out of whack to get it back in.
  7. Nov 17, 2019 at 6:08 PM
    #87
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    A couple things... as for why it looks that way, that’s on the installer. That being said, there isn’t a ton of room back behind the stereo to fit all of the wires/connectors ( looks like you have Sirius XM tuner too ). That’s probably how that installer was able to get it in the dash and now you see the problem that it is. As for the av rca connectors that your not sure where they are, they are starring right in pic 2. For identifying the what’s what, undo the tape because pioneer labels what they are. Whether it’s an audio input output and same with video. Yours does not have hdmi so I’m assuming that’s why your doing the medialinx
  8. Nov 17, 2019 at 6:27 PM
    #88
    Desert Honda Squid
    Fredo
    New Jersey
    First things first. Download the manual for the specific model. The manual will show you what each port does and what each wire is supposed to be. As for the USB, it's just that. A USB port. This has an extension. That is where you would plug in any USB device or phone to charge and activate the Android Auto or Apple Car play if you don't have wireless capabilities.
    If you do have the HDMI port then you will want to feed it from the passenger side, left of the blower, and up to the head unit. Plug it in that way. As for the wires......
    You have little room to work with. But there is hope. Upper left and right corners have some pockets that you can use to "tuck" the wires behind. It's a process. It's a lot easier if you kinda straddle the center console and rest the unit on your knee. Then use both hands to feed the bundles of wires into the left and right upper corners. If you really need space, tie some string to each bundle and pull it from the foot area to help tuck them in deep.
    Here is the link to the manual
    https://www.pioneerelectronics.com/StaticFiles/Manuals/Car/AVIC-2013_Installation-Manual.pdf
    Sadly, your unit doesn't have HDMI. I also can't find any info on if it supports screencast or weblink (the feature that allows you to cast your display onto a screen for android devices. Specifically Samsung). The 950 has HDMI not the 850.
  9. Nov 18, 2019 at 7:37 AM
    #89
    prone2xl
    Mississippi
    Thanks guys. Yeah I was mainly wondering if I needed all those wires or if some could be discarded. I figure I’ll untape them and try to make sense. I plugged my new media adapter into all the audio and video rca Ports just to see if I could get a reaction. But nothing ensued. There is one plug going from a yellow video rca to a brown one and I’m guessing that may be my backup camera ? do you think this media player can be used in my situation?
    Yeah I’m hoping I can figure out better tucks of the wires too. also, i bought one of those parking break bypasses and wondering where those wires are that I need to tap into. Man nothing looks as easy as they show on YouTube but i realize they are using a bench model
    Here’s what my bypass instructions say
  10. Nov 18, 2019 at 4:18 PM
    #90
    Desert Honda Squid
    Fredo
    New Jersey
    Do as your bypass says. Unlock and insert the black wire into that specific empty space then relock. As for ground, take the remaining ground wire (normally GREEN) and splice it to another ground wire. Or use a frame mount nut to connect it to ground that way. Your's is very simple. Mine required me to splice into 2 diff wires and snip a third.
    As for setting up auxilary video, check the link I gave you. It should walk you through what goes where after you have removed the tape. Match the bundles with the images and you should be able to find it. Also, to help you out in the future, get some masking tape and wrap a small amount over each wire to form a tag. Then write down what that wire is.
  11. Dec 28, 2019 at 10:20 PM
    #91
    spencer2423
    spencer2423 Well-Known Member
    2016 TRD Sport
    so does Demo Mode keep power running to the unit, draining the battery 24/7 ?
  12. Dec 29, 2019 at 9:55 AM
    #92
    Desert Honda Squid
    Fredo
    New Jersey
    Unless you rewired the connections in the back the radio will loose power when you take the keys out.
    It also doesn't have power when crank so it will shut off at every start up
    (I plan to rig it to stop that)
  13. Dec 29, 2019 at 9:57 AM
    #93
    Desert Honda Squid
    Fredo
    New Jersey
    Just to clear things up, you need the bypass for a permanent solution. The bottom left screen trick only works till the battery is removed. The unit also looks for a timing pattern Wich is what the bypass does.
  14. Jan 5, 2020 at 9:12 PM
    #94
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    The screen doesn’t work with my 2440NEX. I tried with the parking brake wire grounded and ungrounded..
    I just ordered a micro bypass
  15. Jan 6, 2020 at 12:09 PM
    #95
    Hans Moleman
    Bay Area, CA
    I played around with Apple Carplay today on my 2440NEX. The video quality of Carplay looks terrible. It looks all fuzzy and the colors look all washed out. Am I expecting too much?
    When in the regular non-Carplay mode, the video quality looks super clear and sharp.
  16. Jan 20, 2020 at 12:26 PM
    #96
    Desert Honda Squid
    Fredo
    New Jersey
    Understand that the unit is looking for a signal pattern to be told the parking brake is on. The bypass simulates this.
    As for carplay not looking good, I'm not sure as I'm Android and I really haven't seen any other users complain about carplay looking bad.
  17. Jan 21, 2020 at 10:41 PM
    #97
    Hans Moleman
    Bay Area, CA
    I meant the screen trick doesn’t work. I mistakenly left out the word trick in my original post. I installed the micro bypass so it works perfectly now. Not sure why the screen trick doesn’t work on the 2440NEX.
    Maybe my expections were too high on the screen quality in CarPlay since it’s only a 480p screen.
  18. Jan 22, 2020 at 2:06 PM
    #98
    Desert Honda Squid
    Fredo
    New Jersey
    I'm not sure if the screen trick is supported on the 2440. It doesn't really matter cause if you lose power (disconnect the battery) it resets and looses the "trick". Since you have the bypass it's all good.
  19. Apr 13, 2020 at 8:47 AM
    #99
    TA-5650
    TA-5650 Well-Known Member
    Wilmington, DE
    2017 TRD OR DCSB, Blazing Blue Pearl
    I had the brake wire grounded on my W4500NEX but no GPS adapter installed until recently. Now I get a warning "Brake wire connected incorrectly" or something like this. I did the on-screen bypass so I will see if this removes the error message.
  20. Apr 13, 2020 at 9:30 PM
    #100
    tacovagon
    tacovagon Well-Known Member
    Dan
    Oceanside CA
    2016 SW SR5 DCLB 4x4
    ARB Locker 5100s w OME 887s OME EL095R Camburg BJ UCAs
    I have the MicroBypass installed and did the on screen bypass. I still get the "Brake wire connected incorrectly" message and the 4500 powers off.
