How to diagnose front wheel bearing failure - 2nd Gen
Discussion in 'Technical Chat' started by DaVikes, Jun 11, 2014.
  1. Jun 11, 2014 at 10:57 PM
    DaVikes
    DaVikes [OP] Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    I just replaced both my front wheel bearings at 50k. I searched and couldn't find a thread on diagnosing wheel bearing failure, and the failure mode on 2nd Gen's is a little unique.
    Symptoms of front wheel bearing failure:
    1) Howl. This comes on gradually, making it hard to detect if you're running more aggressive tires. I've had worn tires sound worse than my wheel bearing just did.
    2) Vibration - initially I felt this in the gas pedal and floorboard, but it was subtle at first. Eventually I could feel it in the steering wheel. Some people report that a long turn at speed increases or decreases the vibration, indicating failure. I didn't get that symptom.
    To diagnose:
    1) Check for play in the bearing. To check this, get the front wheel off the ground, grab the tire at 12 and 6, and with force try to rock the tire. If you can, bad bearing. If you can't, try putting a pry bar under the tire and rocking the tire that way. The odd thing about 2nd gen's is that I couldn't feel any play even using a pry bar. This might be due to the more modern non adjustable style of bearing used in 2nd gens.
    2) Spin the wheel by hand and listen for clicking noises. Also compare how easy it is to spin one front wheel to the other front wheel. Sometimes this will work, but I couldn't get much out of this step. The wheel has a lot of inertia once you get it going, and the brake is still dragging and making noise. So the symptoms get masked.
    3) (Thanks to BamaToy for this tip.) Pull the wheel and the brake caliper. Using your fingers, grab a stud and spin the hub. It should spin easily, and fairly quickly, with almost no noise. Mine was difficult to move, and would stop as soon as I stopped spinning it. Also, it made some obvious clicking sounds.
    My truck has had 33's (or perhaps bigger from prior owner) for almost all the 50k miles on the truck. IMHO, Tacoma's don't tolerate larger wheels very well. The seals on my truck were in pretty good shape and the area inside the spindle/hub that the seal protects was pretty clean, so I don't think contamination caused the failure. I'll still keep my 33's, because they're not very old, but if I were buying tires I would be going the tall/skinny route just to keep the weight down, and to minimize leverage on the bearing.
  2. Jan 14, 2015 at 9:27 PM
    iflyils
    iflyils Well-Known Member
    chris
    Wa
    TRD OFFROAD
    HARROP FRONT ELOCKER, ARB BULL BAR, OLDMAN EMU SUSPENSION ARB INTENSITY OFFROAD LIGHTS, WARN 9.5XPS, 32 in BFG MUD TERRAIN KM2, ARE Overland canopy with ARB ROOF RACK Line X premium bedliner
    I think I am having the same issue with a new 2014 with only 13k on it!!! tell me more, which side was it? and anymore info would be great!
  3. Jan 14, 2015 at 9:40 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    That's good advice. The 12 and 6 position can also point towards bad ball joints. 3 and 9 for tie rods. I was taught to grab diagonally, or closer to 1.5 and 7.5 for bearing inspection.
  4. Jan 15, 2015 at 12:55 AM
    CJVant
    CJVant Well-Known Member
    Ontario/SC
    '09 TRD Off Road - MGM
    When replacing my brake pads (and machining rotors) around 80,000 kms I noticed a difference between driver and passenger side using this method... Barely noticeable though.
    Grabbed my stethoscope, set the probe on the hub and it was clear as day!
    Luckily I had 10 days left of powertrain warranty and the dealer agreed with my assessment and warrantied(?) it.
    Going to keep monitoring the right side (and eventually the left again) everytime I rotate the wheels/tires from now on.
  5. Mar 5, 2015 at 5:45 PM
    BoilerAnimal
    BoilerAnimal Welding GURU
    Alabama
    Tacoma Gen 1
    6" lift, 3" body lift, header, cold air intake, chip re program,
    My truck has had 33's (or perhaps bigger from prior owner) for almost all the 50k miles on the truck. IMHO, Tacoma's don't tolerate larger wheels very well. The seals on my truck were in pretty good shape and the area inside the spindle/hub that the seal protects was pretty clean, so I don't think contamination caused the failure. I'll still keep my 33's, because they're not very old, but if I were buying tires I would be going the tall/skinny route just to keep the weight down, and to minimize leverage on the bearing.[/QUOTE]
    Granted my truck is a GEN 1, I purchased it brand new in 2000, it had factory wheels & tires on it for possibly another week, which at that time was swapped for a set of 33's, & eventually for 35's, which is what's on it now. I just replaced the driver's side bearing about 3 months ago, at a lil over 360,000 miles. I ain't buying the,"don't like big tires" thingy, SORRY... Now I am in the process of having to replace the same bearing again, but I feel this is due to the fact that I didn't replace the hub as well, cause the local dealership told me they don't replace the hub when they replace the bearing & the shop that pressed it out told me they normally do & I listened to the dealership. But the front passenger side is still factory & I'm a firm believer in if it ain't broke, don't fix it... Now it may play out in the 1st mile after I get it going again, but at over 360,000 miles, I CAN'T COMPLAIN IF IT DOES...
  6. Mar 5, 2015 at 5:48 PM
    BoilerAnimal
    Alabama
    Tacoma Gen 1
    [/QUOTE]
  7. Mar 5, 2015 at 5:52 PM
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    I replaced my drivers side bearing at 60k, passenger side is going now around 80k. Both of mine have caused the tires to cup pretty bad. Thats how I knew they were gone..
    fast5speed likes this.
  8. Mar 5, 2015 at 5:53 PM
    BoilerAnimal
    Alabama
    Tacoma Gen 1
    Sorry for the double post, was just trying to quote the part about big tires, MY BAD...
  9. Mar 20, 2015 at 9:10 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    A more detailed test. Jack it up.
    try to wobble at 12:00 and 6:00. If it wobbles, this is either a bad bearing OR bad ball joint.
    try to wobble at 3:00 and 9:00. If it wobbles, this is either a bad bearing OR bad tie rod ends.
    If it wobbles both directions, either you are amazingly unlucky and need both ball joints and tie rod ends, or more likely a wheel bearing.
    My '07 seemed to behave just a tad "loose" when driving. I decided to give it a check. Raised right front wheel, spun it, dead quiet. But when I grabbed it had slack in both directions. Replaced right front wheel bearing (NOT a lot of fun but not that hard) and problem went away. Left was rock solid.
    I have seen people drive with them so bad you would think the wheel would come off. I worked on a Honda Passport last year (4wd) and when I heard the noise there was no doubt what was wrong - right front wheel bearing. As I started to disassemble, all sorts of crap fell out. Individual tapered bearings, pieces of bearing spacer, metal filings, and a partridge in a pear tree. This poor guy spent so much buying a house he could not afford, that he couldn't afford to keep his vehicle up at all. He asked me to take a look at "weak brakes." Turns out he had run them all down to metal, the left rear caliper apparently wore through the metal pad backing and the rotor eventually ripped the piston out. "weak brakes". He had zero brakes as the system was dry, all the fluid having gone through the rear caliper that no longer had a piston.
    Back to the bearings. I have seen several flavors of failures. Most common allows the above play, which in the old style bearings where there is an inner and outer tapered bearing with a spindle and a spindle nut, that is the kind of feel you would get if the spindle nut is several turns too loose to preload the bearings. I have seen them not wobble but make a gross noise. Mine made zero noise but had enough slack to allow the wheel to wobble. Hit the brakes. Crack / seam in highway. Could make the wheel toe in/out slightly and cause the steering to wander a little. And there is the ultimate bearing failure where the wheel comes off. When I was very young, my dad and I were driving out to a house he was building (contractor) in an old International pickup. We were going down this long hill when he commented "wonder who in the hell lost a wheel, look at it go..."... Needless to say it was _us_. :)
    The clue was when we started to turn right and the left rear drum hit the ground. :) Funny today, but could have been tragic obviously.
  10. Apr 30, 2015 at 10:11 AM
    Ubeslife
    Ubeslife Well-Known Member
    Eric
    Orrville, OH
    05 TRD Off Road
    Level 8 mk6 17" wheels, 265/70r17 nitto terra grapplers, Powerstop Drilled and Slotted Rotors and pads, 2015 New frame swap (courtesy of toyota), Dynomax SS exhaust, Carseat
    So on a related note, When you replace a bearing, what kind of grease should you use on the backside (inside knuckle) for the bearing/joint assembly?
  11. Apr 30, 2015 at 8:14 PM
    RobertHyatt
    Robert
    Birmingham AL
    Mine was pretty well greased and ready to install. But there is certainly nothing wrong with adding some good high-quality (high temp also) grease like good old mobil 1 synthetic. I have a cute gadget to grease bearings. Looks almost like two plastic funnels that nest. Separate them insert bearing and re-nest. There is a grease fitting on the other side that hooks to your usual grease gun. Pump until grease can be seen in the gap between the two funnel parts. The grease is forced through the bearing. Not so workable if the bearing is sealed up.
  12. Dec 15, 2018 at 11:04 AM
    Kennyluu611
    Kennyluu611 Well-Known Member
    Kenny
    SoCal
    2010 Tacoma DCSB Prerunner 4x4
    King 2.5 JBA HD UCA Dakar Rear Leaf US Off Road Bumper Winch 4x4 Converted TRD Supercharger
    An additional way to diagnose the front bearing would be to jack the front with the tires off the ground. Spin the tire and grab the tie rod. If you feel any vibration on the tie rod. The bearing is starting to wear or is already worned. If no vibration is felt on the rod and its smooth while the tire is spinning. This means that the bearing is still good. An alignment shop taught it this trick.
    GilbertOz, N22WLZ and abqnurse80 like this.
  13. Sep 28, 2019 at 8:11 AM
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    Thanks for all the info.. I've been chasing vibes for awhile. Some of the above exactly what is going on with my truck. Gonna take a closer look, and probably replace both wheel bearings!!
