How to diagnose a bad wheel bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plasmech, Dec 13, 2021.
  1. Dec 13, 2021 at 4:55 PM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    The tech at the dealership that I have work done at told me that my right rear wheel bearing is starting to go. I trust this particular 20+ year master tech and this dealership.
    I can't hear or perceive any issue whatsoever, though.
    What is the diagnostic procedure?
    It's expensive as hell to replace, so I don't want to do it unless it's absolutely necessary.
    Thanks for any help.
  2. Dec 13, 2021 at 5:00 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Usually noise and/or looseness are the main signs of a failed bearing, if its leaking gear oil from behind the brake drum it's likely just the axle seal.
    You can set the rear axle on jack-stands and check for looseness and even run it in the air to listen for noises.
  3. Dec 13, 2021 at 5:50 PM
    Plasmech
    I was going to ask: is the wheel bearing live lubed by the differential gear oil?
  4. Dec 13, 2021 at 5:54 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Pull the drum and rotate the axle.
    Use a screwdriver as a stethoscope.
    Hold the tip near the bearing housing and put the handle against your ear. You will hear the gravelly sound if it's bad .
    henryp likes this.
  5. Dec 13, 2021 at 5:55 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The rear outer axle bearings are not, they are sealed ball bearings with an additional seal on the axle shaft to prevent oil leakage.
    The inner differential carrier bearings are.
  6. Dec 13, 2021 at 5:58 PM
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    https://youtu.be/l-Y1yIEwEXw if you jack it up and it does this.. .. It's really really bad.....
    Don't ask how I know
    Edit..... This Is on the front
    Hawapino and MadDaddy like this.
  7. Dec 13, 2021 at 5:59 PM
    koditten
    Kirk
    Central Michigan
    It's not a hard job changing the bearings.
    It is money ahead to pull the axle along with backing plate and just take the whole assembly to a machine shop. Let them press off and press on a new bearing. The axle and backing plate is only Heald in place with four bolts.
    The hardest part is removing the brake and park brake assemblies.
  8. Dec 13, 2021 at 6:00 PM
    koditten
    Kirk
    Central Michigan
    The tears are never side to side sloppy.
  9. Dec 13, 2021 at 6:01 PM
    pmstoy10
    hudson valley, ny
    Yeah.... Posted and then thought about that. Oh well . My bad. Just ignore my presence ;)
    koditten[QUOTED] likes this.
  10. Dec 13, 2021 at 6:02 PM
    koditten
    Kirk
    Central Michigan
    We must be related.
    Neither one of us can type for fuck all .
  11. Dec 13, 2021 at 6:03 PM
    pmstoy10
    hudson valley, ny
    Stupid fat fingers
  12. Dec 13, 2021 at 6:04 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    I paid $600 for one axel. Not cheap. With repair manual and right tools (including a press) anything is possible.
    edit: not one axel, one bearing.
  13. Dec 14, 2021 at 9:34 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The job in itself is pretty straight forward. Except for the the need for a “good” jig to remove and replace the bearing. It’s pressed on. You could cut the bearing off, but beat the new one on with a pipe. But that a hack job way of doing it. And you are asking for trouble.
    If the shop you have doing it doesn’t have the right equipment or know how, you could end up with a bent axle. Just ask @Larzzzz
    This isn’t a job you want to go to the lowest bidder. You need to make sure they have experience and the right equipment.
  14. Dec 14, 2021 at 11:02 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @TnShooter that's right. Just rip the scabs off that wound and pour some alcohol on it... :rofl::rofl::thumbsup:. It's all good.
    But ya, not a job for those lacking in common sense.
  15. Dec 14, 2021 at 11:14 AM
    TnShooter
    Deogee
    STOCK
    Sorry buddy. But I remember that mess.
    I still haven’t figured out what they did to bend the axle. Maybe they didn’t remove the big C-clip when trying to press it off?
    I still feel bad for you. That’s one of those cases where:
    You know if you do it yourself you’ll f**k it up. So you pay someone to do it for you, and it gets f**led up anyways. So now you paid someone tear up something you could have done yourself for free. That’s my luck too:(
  16. Dec 14, 2021 at 11:14 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
  17. Dec 14, 2021 at 11:24 AM
    Larzzzz
    Larry
    MA
    @TnShooter that is exactly what happened.
    The saving grace was another axle from the junkyard diff that made the removal tool (s).
    Live and learn.
    TnShooter likes this.
  18. Dec 14, 2021 at 2:42 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Noise using a screwdriver as a stethescope is one way to tell. Any "whobblyness" of the wheel from side to side or up and down is a sign it's been bad for a while and you are on borrowed time. I made a thread somewhere on hear on the R&R, it's not that hard of a job but a bit time consuming and you need to make or buy a couple speciality tool for pressing the old bearing off.
  19. Dec 14, 2021 at 2:50 PM
    TnShooter
    Deogee
    STOCK
  20. Dec 14, 2021 at 3:04 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Larzzzz and TnShooter[QUOTED] like this.
