How to determine optimal rear shock length selection
Discussion in 'Suspension' started by meloish, Mar 27, 2021.
  1. Mar 27, 2021 at 10:21 PM
    meloish
    meloish [OP] Well-Known Member
    hey tw. this site has been such a great resource and has helped me alot with my build. im at the point now where i want to make the purchase of some rear shocks and after reading through various threads i understand that there are proper measurements to be taken to eliminate the guesswork when sifting through the multiple shock lengths available. if someone could outline the process of taking these rear measurements for me it would be much appreciated. this will be my first time taking these measurements so all the details are welcome. thank you!
    edit: i currently have wheelers flip kit with superbumps installed. i remember seeing there was a measurement taken involving the bumps and its compressed length.
  2. Mar 27, 2021 at 10:29 PM
    Wapiti_chaser77
    Wapiti_chaser77 Well-Known Member
    IDAWHOE
    17 OR dcsb 6mt
    886’s, 90000’s, jba uca’s, ecgs, Fox 2.0 resi's and Icon rxt mediums in rear, wheelers super bumps, softopper, warrior products roof rack, smittybilt 10k, 255/85r16’s, coastal offroad front bumper, diff breather and a couple stickers
    First, find your collapsed length where your bumpstops hit your frame. Take measurements. Then flex it, find your extended length. Take measurements. Make sure your shocks aren’t the limiting factor, cause they’ll fail real quick if that’s the case. I like to remove rear shocks and let my springs tell me where their limit is...then measure.
    Edit...I’m sure there are others on here that can steer you straighter, but at some point it boils down to common sense and measuring.
  3. Mar 27, 2021 at 10:36 PM
    meloish
    @Wapiti_chaser77 hey thanks for the quick response. to do collapsed length would i jack up one side (on frame near rear tire) of truck until bump contact? at this point could i measure the extended side with shock off? newb questions for sure.
  4. Mar 27, 2021 at 10:38 PM
    Wapiti_chaser77
    IDAWHOE
    17 OR dcsb 6mt
    What setup are you running in the rear?
  5. Mar 27, 2021 at 10:40 PM
    meloish
    @Wapiti_chaser77 i have general spring hd pack now with 5100s. definitely entry level purchases. gave me about 2.5 inch of lift over stock.
  6. Mar 27, 2021 at 10:44 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
  7. Mar 27, 2021 at 10:50 PM
    meloish
    @Superdave1.0 thanks man. i definitely came across that page and it does help out. im considering upgrading to the fox 2.0 but just want to make sure im getting the appropriate length for my setup.
  8. Mar 27, 2021 at 10:53 PM
    Wapiti_chaser77
    IDAWHOE
    17 OR dcsb 6mt
    What shock setup are you looking for? Sounds like the same amount of additional height I have out back with medium dakars. I run 5125 bilstein’s and no complaints so far. But, that was after measuring collapsed and extended height. You can get a very good ballpark in your driveway. Look at the link superdave suggested. Lots of great info here.
    Superdave1.0 likes this.
  9. Mar 27, 2021 at 10:57 PM
    Superdave1.0
    SoCal
    I loved my 5125's on my Taco. Great value. Better shocks out there, but not at that price.
  10. Mar 27, 2021 at 10:58 PM
    meloish
    @Wapiti_chaser77 im leaning towards the fox 2.0s. i was thinking the 985-24-118. 15.20 collapsed 24.80 extended. just wanted to be sure they werent going to run too long.
  11. Mar 27, 2021 at 11:03 PM
    Wapiti_chaser77
    IDAWHOE
    17 OR dcsb 6mt
    Definitely better shocks out there, but you are correct, for the price.
  12. Mar 27, 2021 at 11:05 PM
    Wapiti_chaser77
    IDAWHOE
    17 OR dcsb 6mt
    Sounds about right. I need to do some more research. It’s 1205 here so im out for the evening.
  13. Mar 27, 2021 at 11:10 PM
    meloish
    Thanks for the info. there any way you or anyone can let me know which areas to measure or how i can go about doing this with a floor jack/stands?
  14. Mar 27, 2021 at 11:28 PM
    Superdave1.0
    SoCal
    Can measure after you install the lift.
    1. Measure from top of bumpstop to frame.
    2. Measure shock shaft length.
    Shock shaft should be longer.
  15. Mar 28, 2021 at 9:31 AM
    Wapiti_chaser77
    IDAWHOE
    17 OR dcsb 6mt
    This^^ make sure your bumpstops are stopping your uptravel, and not your shock. I learned this the hard way lol
    Island Cruiser likes this.
