How to connect my remaining cables? For my stereo
Discussion in 'Audio & Video' started by KEYBEATZ, Jun 2, 2016.
  1. Jun 2, 2016 at 11:52 AM
    KEYBEATZ
    KEYBEATZ [OP] Member
    Dani Joe Mendoza King
    2006 Ford Focus Sport 1.6
    Hello, I have bought a stereo but I'm having trouble wiring it up, I got most cables ready to be plugged but I'm left with 5 cables, I'm not sure what they are or do. I'll attract a picture of them. They are labelled like this, BRAKE-IN, AMP-CON, KEY2-5V, KEY1-5V and REVERSE-IN. Please can someone help? I'm not an electrician or anything like that.
  2. Jun 2, 2016 at 11:54 AM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    A lot of smart audio guys here...even if it's not for the Tacoma. Someone will know it
    Aw9d likes this.
  3. Jun 2, 2016 at 11:55 AM
    KEYBEATZ
    Thanks I hope your right!
  4. Jun 2, 2016 at 11:56 AM
    Aw9d
    Aw9d That one guy
    BRAKE-IN, - used for DVD player so it will play.
    AMP-CON, - used to send 12v signal to amp to turn them on
    KEY2-5V, - Steering wheel controls.
    KEY1-5V - same as above.
    REVERSE-IN - used to trigger reverse camera to turn on.
    What HU is it? Make/Model? The manual will tell all.
    EDIT: I found out the Key wires are used for steering wheel keys. I doubt they would work with the Taco and you'll need to get a kit for the steering wheel controls.
    tcBob likes this.
  5. Jun 2, 2016 at 12:01 PM
    KEYBEATZ
    Thanks for that, I bought it from eBay and I don't have any manuals with it, to be honest if it's that I don't need to watch DVDs in my car and I haven't got any cameras, so I think the one that I need to plug is the amp one, but where?
  6. Jun 2, 2016 at 12:07 PM
    Aw9d
    Aw9d That one guy
    If you have after market amps then you'll use that wire. If not then no need to connect it to anything. Just make sure you cap it off or something since the wire does have a 12v signal when HU is on. You don't want it sparking on metal.
    As for where it goes to the amp, it goes into the 'remote in' for an amp. All that wire does is act like a light switch to turn on 3rd part amp's in the truck.
  7. Jun 2, 2016 at 12:16 PM
    KEYBEATZ
    Perfect thank you so much for that!
  8. Jun 2, 2016 at 12:22 PM
    Aw9d
    Aw9d That one guy
    No Problem. If you run into issues send me a PM and I'll help you out.
  9. Jun 2, 2016 at 12:29 PM
    KEYBEATZ
    Ok thank you soo much!
