How to clear 33-12.50 tires?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drakeb252, May 29, 2023.
  1. May 29, 2023 at 6:39 PM
    drakeb252
    drakeb252 [OP] Well-Known Member
    2014 Grey tacoma TRD
    2 inch Rough Country leveling kit
    What’s the best 4 inch lift I can get for my Toyota Tacoma? I looked at the RC one but I don’t want to run spacers on my stock front shocks because I’m afraid of it being stiff. But i want to lift it enough to clear 33-12.50 tires on it.
  2. May 29, 2023 at 7:00 PM
    drakeb252
    Well I’m not clearing 33s without a lift and I’m gonna need 3.5 lift at least to clear them without chopping the cab mount
  3. May 29, 2023 at 7:17 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    285/70/16. You will need to chop cab corners
    drakeb252[OP] likes this.
  4. May 29, 2023 at 8:24 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    You'll still need to trim a bunch of fender lining and chop the cab mount to fit 33x12.5 tires. The lift doesn’t make the wheel well and larger and those tires are too wide for the wheel well. You can absolutely fit narrower 33” tires on stock suspension with the right wheel offset and alignment.
    drakeb252[QUOTED][OP] likes this.
  5. May 29, 2023 at 8:24 PM
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Yep, no matter what with 33's. Get a heat gun to mold inner fender back also. Avoid the spacers.
  6. May 29, 2023 at 8:36 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
  7. May 30, 2023 at 7:16 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    still need a CMC...no matter the lift...its a matter of geometry...UNLESS you go over zero bumps, go up any slopes, back out of your driveway, twist the body in any way shape or form and never turn your tires full lock...sure, then any 3" lift will work!
    whatstcp likes this.
  8. May 30, 2023 at 7:28 AM
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    I haven't trimmed with my 255/85/16s, if it's solely about getting 33s, though these are 33x10. :) I'm happy with 5100s and OMEs.
  9. May 30, 2023 at 7:30 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    33/10.5 fit with leveling kit
    jus sayin
    DetroitDarin likes this.
  10. May 30, 2023 at 7:30 AM
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    12” lift and solid axle. Only way.
    2015WhiteOR, MSgt O and DetroitDarin like this.
  11. May 30, 2023 at 7:40 AM
    JKO1998
    Utah
    The real question is what wheels are you guys running for 285's/ 12.50's? Can I run my stock wheels and stay off the UCAs?
  12. May 30, 2023 at 7:50 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Cemeterygate and drakeb252[OP] like this.
  13. May 30, 2023 at 8:38 AM
    drakeb252
    Some tire shops won’t mount 12.50s on stock wheels but some of them will. It is possible to do it on stocks but it’s not really recommended
  14. May 30, 2023 at 8:52 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    check out this video, on lifts and bigger tires with the Tacoma. I am running 285s which aren't big tires compared to what the Jeep guys are doing, it didn't take much work so they don't rub. A CMC is around an hour at a shop and if they are good you won't even know its done.
    https://www.youtube.com/watch?v=33VewJFda1Q
  15. May 30, 2023 at 9:33 AM
    2015WhiteOR
    Gainesville TX
    You can also spider them out like the embarrassing Dodge guys lmao.
  16. May 30, 2023 at 9:36 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    You either chop the cab mount (no big deal really) or you cut a section out of the frame for a drop bracket lift. I can't imagine why you're considering a 4" lift if you don't want to chop the cab mounts.
    If you plan to use your lift for anything other than stance, you will need to work on the front wheel openings by hammering the pinch welds flat, trimming some plastic, and chopping the cab mount. If you don't want to work on the wheel openings you could install taller bumpstops but it'll limit wheel travel and probably ride like garbage.
  17. Aug 23, 2024 at 12:31 PM
    Cemeterygate
    Cemeterygate Member
    Matty
    2022 tacoma trd pro
    Pretty satisfied at the moment
  18. Aug 23, 2024 at 2:42 PM
    Leaguer4
    Leaguer4 Well-Known Member
    Good video
  19. Aug 23, 2024 at 2:56 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    It’s all about off set the more negative the offset the more you will rub against your can mount hence why some people claim they fit 33s with no lift and no cmc (they’re most likely running a zero or positive wheel offset)
  20. Aug 23, 2024 at 3:21 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    I'm running zero offset wheels along adjustable UCAs and caster set to 4. I'm confident that anyone running a true 33" tire is going to rub if they cycle their suspension. I have a CMC and smashed the pinch weld. It rubbed bad before the CMC. When stuffed now I still rub the flares.
    This is static without compressing the bump stop.
    When I bottom at speed it rubs enough to leave melted plastic from the flare on the outside of the tire.
