How to clean fogged up headlight covers?
Discussion in 'Lighting' started by DaytonLax14, Nov 6, 2009.
  1. Nov 6, 2009 at 1:00 PM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    I just bought a 1998 tacoma and the headlight covers seem to be really dirty/foggy and the lights don't seem to be very bright (maybe because of the foggy covers?). What is the best way to go about cleaning those?
  2. Nov 6, 2009 at 1:14 PM
    snakebite
    snakebite Well-Known Member
    Dan
    Hanover, PA
    01 tacoma xcab 4x4 AT (7514)
    2005 4runner sport wheels, jeraco cap
    toothpaste and brush. good luck
  3. Nov 6, 2009 at 1:36 PM
    DaytonLax14
    Corey
    Ohio
    for real? is there some kind of kit i can buy to clean them off? Would the fogged up light covers cause the lights to not be very bright/not shine very far?
  4. Nov 6, 2009 at 1:39 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Yes you can get a headlight lens restoration kit at Wal-Mart (Don't know the $). Yes, a really fogged lens could cause dimmed lights for sure. :)
  5. Nov 6, 2009 at 1:41 PM
    carmellocafe
    KEVIN
    N. California
    BTW-- Welcome to TW Corey! :thumbsup:
  6. Nov 6, 2009 at 1:44 PM
    DaytonLax14
    Corey
    Ohio
    thank you sir! i'm gonna go run to wal mart and see if i can pick one up
  7. Nov 6, 2009 at 1:45 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Most auto parts stores carry a kit for cleaning glass and head light lenses. The kit includes pads that are impregnated with jewelers paste that you attach to a drill motor and spray water on to activate. I got the kit from Napa Auto Parts for $12.00.
  8. Nov 6, 2009 at 2:23 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Those kits work ok. The best way is to wet sand with 1500, then 2000 grit, then use a buffing pad (on a buffer or high speed drill) then use a polish, then protect and keep them protected with a good wax or sealant
  9. Nov 6, 2009 at 2:27 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    mcguires makes a kit as well.
  10. Nov 6, 2009 at 4:04 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    What are headlight covers? Are you referring to the headlights themselves?
  11. Nov 6, 2009 at 4:29 PM
    DaytonLax14
    Corey
    Ohio
    the headlight lens
  12. Nov 11, 2009 at 6:28 AM
    Rattler
    Rattler Wandering But Not Lost
    Bay City MI
    '04 DoubleCab "3 Lift on 285/75/16s
    All Pro rear bumper with an Ironman Offroad swing-out spare carrier, Bajarack on top, blacked-out grill, Lightforce 140s Mombasa Rooftop Tent
    Seeing fogged covers is sort of a pet-peave of mine. I use Maguires mag wheel cleaner and a terrycloth rag and have not found anything that works better (even tried 3M Microfinish). That is probably all the kits consist of anyway. A couple runs over the lights and follow up with some wax if you like.
  13. Nov 11, 2009 at 6:38 AM
    macgyver
    Brad
    Canton, GA
    I have used them mag wheel cleaner as well it seems to work pretty good but you still need something to polish them up afterwards to give them a shine.
  14. Apr 26, 2017 at 10:57 AM
    Stadler
    Stadler New Member
    1998 Toyota Tacoma 4WD (Purple)
    Here's a dumb question for you: is the cleaner applied to the outside, inside, or both? It's hard to tell if the "fogging" is only on the outside?
    (By the way, I just bought a '98 Tacoma as well; it's my second one - my brother has had two as well - but the first in a long time).
  15. Apr 26, 2017 at 2:37 PM
    Rattler
    Bay City MI
    Just do the outside front part of the lens. I just use a cleaner/polish for car paint. They just get yellow again after a month anyway.
  16. Apr 26, 2017 at 3:34 PM
    mrlee
    mrlee I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
    Go to the detailer section. Lots of good info there on how some of the pros take care of lense.
  17. Apr 26, 2017 at 3:37 PM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    weather tech sells headlight lens covers that they claim keep your lens clear. I would like to know if they work. Seems like they may hold heat and I have seen a while back folks complaining about their covers melting from the daytime running lamps
  18. May 22, 2017 at 7:16 AM
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    If you get a kit that uses a drill with sanding pads use a slow speed only you can create heat by going to fast and melt the plastic and I think there is a clear coat for lenses that has a uv protectant.
  19. May 28, 2017 at 8:07 PM
    Silentwolf
    Silentwolf Well-Known Member
    2017 Tacoma SR
    Cruise Control,Led Reverse lights, Weathertech mudflaps, Weathertech headlight protectors,Lund stepbar, Interior Leds, AVS Hoodflector, AVS In-Channel Ventvisor, aFe Pro DRY S airfilter, K & N cabin airfilter, A/C drain valve, Mostplus Led Headlights
    Ive had the Weathertech Headlight protectors on since February. Supposedly they'll keep them from oxidizing but only time will tell on that. Ive read reviews that say they still look good years later. They are a bit costly and a lil forewarning they are a biiiiiiiiiiiiitttttttttttccccccccchhhhhh to put on. Had to buy a heatgun to make the process easier and it still took me about 2 hours to do, but I was really OCD about getting it the best I could.
  20. May 28, 2017 at 8:17 PM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    I have had the best results using one of the least expensive products.. Turtle Wax Headlight Cleaner and Restorer..takes a couple of minutes and cleans the headlights right up.
